Old 05-29-2021, 07:34 PM   #26
mikep
The MP
mikep's Avatar
I am going to stop and see him when I tow the duett to Aaron. I would love to see where he works, but that's asking a bit too much.
Old 05-30-2021, 08:29 AM   #27
Swedbrick
Swedbrick's Avatar
Just add some sketchy mounting interface and some batteries:
https://www.thunderstruck-ev.com/curtis-ipm-system.html
That's a pretty sweet setup, our local electric superbike used one of those for their first bike. 32kw would be pretty comfortable for hybrid usage
Old 05-30-2021, 08:40 AM   #28
Swedbrick
Swedbrick's Avatar
Originally Posted by bobxyz View Post
Oh, that's not much of a budget. A LS swap is much more, and that's _just_ an engine swap.
Yes that is true, that why I'm wondering if there would be some way to affordably hybrid with something OEM. A full EV conversion is expensive, and you might as well get a Nissan leaf for the price with reliability included.
Adding an e-Alternator seems like it might work, and would give better acceleration from standstill. What sort of Hybrids are showing up in your local salvage yards these days, and do any of them have anything somewhat bolt-on?
Most have the stuff included in the gearbox in some way, which makes the e-alternator such a nice option. I've also seen rear differentials with the motor included, which might work with a irs Volvo. As far as I'm aware BMW and Volvo are some of the few who still have 4wd hybrids with a driveshaft, most just go fwd, with a hybrid drivetrain in the back
Whatever you do, I'm guessing that you'll need a new aftermarket motor controller (think MegaSquirt for electric motors), unless someone knows of good tuning package and/or hacked production controller??? That's hundreds, or more, of your budget.
Most motors appear to have 3-fase designs, so hopefully those controllers are somewhat universal. If torque from standstill is required it will need to know the orientation, to get the phasing of the motor correct, which might cause some compatibility issues
Old 05-30-2021, 12:10 PM   #29
The new t8 Volvos have a complete electric rear axle. Its actually quite marvelous. I believe the motor is around 100 hp with 300 ft/lb of torque. When you have the car in electric only mode, its got plenty of grunt to have fun. 100 hp... and lots of torque. seems like it would be right at home in a 240.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 05-30-2021, 03:29 PM   #30
mikep
The MP
mikep's Avatar
or an 83 corolla?
Old 06-02-2021, 11:30 AM   #31
cwdodson88
The bigger hybrid GM SUVs used a very nice Remy electric motor. That’s getting into the power levels to move along a brick well enough (150 peak HP I think?).
Using an automatic without a torque converter would go a long way into extending the operating/speed range, as well as extending the battery run time.
I’m waiting for cwdodson88 to come in here and tell us where all the cheap e-motors and controllers are
I know the company he works for sells AEM interfaces, and I assume they work with their controllers.
Going to have to define cheap
Borg Warner (Remy/PDS Anderson) motors are tits for efficiency if you can keep them cool. They're also insanely power dense. 160# motors that easily break the 400hp mark. Now, from PDS there are a few off the shelf flavors, only downside, they are drysump or oil flooded. So you need to work out oil res, pumps, and cooling. Cascadia offers a self contained system that integrates oil pump, cooler, wet sump, so all you need is the end heat exchanger to cool your water and an electric water pump, you'd need this anyway to cool a decently power dense inverter/controller of any sort.
AEM interface - ouch, thats a spicy meatball. They're absolutely awesome, and look great, but that comes with a cost. Be prepared for a VCU, PDM, and Dash to set you back 5-9K.
The Cascadia stuff will run of simple analog, as well as CAN command logic controllers. Great for hybridizing your MS3 powered whatever. Set up an N02 table or boost by gear table to deliver a 0-5v output, run that to the VSM Analog inputs, and now you have MS controlling a 'Torque table" based off your ICE's current state. Talking to both controllers with a PiDash and some fancy DBC integration, and you can get realtime viewing/logging of both the e-motor controller, and your ICE. I have some plans for this in the near future with a TTR hybrid 1st gen Honda
Just did some costing for a friend who wants to do an Austin Healey, aiming for low budget, 200mi range, and similar to stock hp... well ok, I wouldn't put less than 300hp in that car if I were to do it
Motor: AC motor with integrated oil handling, 300kw output. ~9k
Inverter: 3 phase water cooled, capable of 150kw continuous 300kw peak ~3k
Battery/BMS/Charging: Tesla Model3 modules, ~100kwh to leave you with enough overhead for that "Oh sh!t" moment when you find your self in BF nowhere and have to limp to a plug in. That'll run in the neighborhood of 12-15k.. all prices are in USD
To try to do a conversion under 20k, you have to either pull the range back to 60 miles or drop the power down a lot. Personally, I would find a used Leaf. Buy a motor and inverter for about 11-12k and you have a 24-35kwh pack/charger/bms, a setup that will put down ~350hp all day, since the motors we are talking about "Knee" at about 6krpm, you dont need a multispeed gearbox, and can get away with a "2nd gear" plus final drive.
So say the Volvo second is like 2.35:1 and 3.73:1 rear diff, you could run a 6-7:1 edrive gearbox that would make the car feel like its in second gear all the time up to the "knee" where your torque taper begins.
We have also just released a pretty cool (Not shiny billet, but still cool) combination unit. It offers 700nm of tq on the shaft and huge rev range with a high knee speed. These are running about 11k, fully self contained, just plug in DC and a water radiator and go. This unit is being paired with some proto gearboxes, as well as off the shelf boxes, offering ratios from ~2:1 to 8.3:1.
The Build Thread
SVEA - PUSHROD TURBO!
Old 06-03-2021, 09:29 AM   #32
^^^ Thanks! That's great info - I'll need to spend some time looking up those parts. I guess an e-conversion on a TBricks budget, or most anyone's budget, is out of the question at this time. Do you know if there are Federal/State tax credits available for hobbyist conversions (full electric) that could reduce the costs significantly?
Old 06-03-2021, 10:49 AM   #33
cwdodson88
As far as I know, there are not, but its worth doing some more research on.
For a conversion, it really just comes down to the pack. If you really needed to keep the budget down, just upgrading the inverter is a huge gain for most setups. Using salvage parts for the motor, gearbox, and battery could save money, and if you want more power, typically OEM stuff is only inverter limited. There are battery limits as well, but they generally are well above the inverter limits.
For motor selection, synchronus AC motors are very "tuneable" so upgrading the inverter can increase power output/throughput by a significant amount with the right amount of homework.
Old 06-03-2021, 11:39 AM   #34
Swedbrick
Swedbrick's Avatar
Thanks for all the info, sounds like my guesstimate budget was pretty far off. In terms of hybridization, the e-alternator seems to still somewhat fit the bill with a small power pack requirement, and the belt probably being more limiting than the inverter in that scenario. Possibly adding a blower belt could be a workaround, although I suspect the thing to get hot quick, given the small coolant lines.
I found this one online for some better pictures, it appears to have the inverter and controller integrated as well in the unit, just requiring a 48V input from the battery:
http://mbspecialist.com/mercedes_web...2649001100B01/
The later cars appear to have moved to this unit in the bellhousing, which might offer slightly more power:
https://www.youtube.com/watch?v=ntqukRvIMzA
Old 06-03-2021, 12:05 PM   #35
cwdodson88
You'd be surprised at how well they can be cooled. Using a 10 row oil cooler with water in it, 5/8" lines, and a bosch itty bitty pump, we've been able to keep a 146mm 48v motor cool running it at 350v and 60-80nm load for 10 minutes constant at like 10krpm shaft speed. So 50% torque at 50% shaft speed, and more than twice as long as you'd push something like that in the real world.
The thing about them is that they cool off really quickly whens unloaded, and op temp is right around engine bay ambient, 160-195F. Now if you can find one, or make one that is oil cooled... that would keep it way more stable, but requires some dissection, and properly orientated drilling.
The other option is to go non driven wheel. So a TTR (through the road) style hybrid. You dont need a large pack, or a large motor, or super powerful inverter, just a bump for tip in when you need to pass, or just a pulse/coast when cruising to maintain speed in an area where your ICE can be leaned way out for extra MPGs. Also, gain some control over brake bias and charge the pack up under braking.
Old 06-03-2021, 12:15 PM   #36
cwdodson88
And on the plus side of performace, that 48v system could also be pulled in to an e-turbo as well. Shared DC bus, and an e-turbo, and you could effectively gain in all areas. That being range, horsepower, fuel economy, and the steady hard pull of huge displacement out of a tiny little engine.
Old 06-04-2021, 03:57 AM   #37
Swedbrick
Swedbrick's Avatar
That's pretty neat, that is sounding pretty doable. Are there any e-turbos available on the aftermarket already? I mostly ran into Garrett OEM parts, or descriptions of what they could offer.
Old 06-04-2021, 12:00 PM   #38
hk 40
Banned
hk 40 is offline   Reply With Quote
Old 06-04-2021, 01:50 PM   #39
cwdodson88
BW has some involvement as well in the OEMs, but I do not believe there is a consumer retail variety yet. I can say that there are several European cargo vans equipped with e-turbos, but I do not have a list of exact year/make/model.
Old 06-05-2021, 07:16 PM   #40
Swedbrick
Swedbrick's Avatar
Originally Posted by hk 40 View Post
Now that they are at a real budget your should consider the fact that You are an engineering student and can use your professional professors to help you. The academics can certainly get you there and may have some financial support for such DIY projects
I've actually already competed in a hydrogen car project previously, and am in the process of graduating, so starting a new team or project is out of my interest. I might end up buiding a motor at some point, but for now I'll take a quick and dirty first attempt. The first year of our hydrogen car also used cheap chinese hub motors and drivers for the first iteration and evolved to custom motors and GaN drivers over the years
Thats pretty rad, I didn't know those were in production yet in europe. I used to drive a lot of cargo vans for work, and the powerband on small displacement turbo diesels would probably greatly benefit, 500rpm of torque and power doesn't haul cargo well.
Old 06-06-2021, 10:02 AM   #41
HiSPL
Fanking Champion 1993
HiSPL's Avatar
And if you wanted to go crazier, use a 960. You can swap in a FWD engine and trans from an early S70 or 850 and then do a direct drive electric on the stock 960 rear diff. Go big DC motor for launches or drifting, but you wouldn't need a massive battery pack for range because the gas engine would handle that.
The only downside to this would be using it as a constant-loss system for the electric unless you figured out a way to charge it from the ICE. Which could be done, but there would be efficiency trade-offs. Not to mention the lack of space.
Beets taste like buttfeet.
Originally Posted by Lando
88 244
06 XC90 V8
03 V70
Old 06-06-2021, 05:14 PM   #42
dalek
Benchracer Tribe
dalek's Avatar
People claim the transmission of a Lexus GS450h (~282lb) can do 1000hp in short bursts (https://www.diyelectriccar.com/threa...3/post-1065808), but I have never found supporting docs.
Feedback!
Old 06-06-2021, 06:21 PM   #43
HiSPL
HiSPL's Avatar
The 450H is a gold mine for DIY EV's. The CVT transmission is an overgrown prius unit, in RWD format. And the AWD the suv model (RX450H) had a fully self contained differential with it's own electric motor that was in parallel with a prop shaft. It is fully able to be used with or without the prop shaft there.
So dual motor EV, series hybrid, parallel hybrid, whatever.
And you can buy wrecked 450H's pretty cheap.
Old 06-06-2021, 07:04 PM   #44
dalek
Benchracer Tribe
dalek's Avatar
I really want to like the 450H transmission. I really want to put it in my Volvo, but the part that gets to me is that the most power your engine can ever provide to the wheels do is whatever the M1 motor can counterbalance -- at the expense of using battery power -- in the planetary gear. In other words, the gasoline engine is second citizen.
Old 06-06-2021, 07:27 PM   #45
HiSPL
HiSPL's Avatar
I tell ya whaat.
A VW TDi motor connected up to one of these transmissions would be dogs bollocks. 200 lbs/ft from a mildly tuned TDi, match that with the electric, then top it all off with the little kicker motor in the diff. Could easily top 400 HP and near that in torque, and it would probably get 45 mpg or more.
Old 06-07-2021, 07:23 AM   #46
dalek
Benchracer Tribe
dalek's Avatar
HISPL there was a guy here who put a TDI in a Volvo.
Old 06-07-2021, 11:26 AM   #47
HiSPL
HiSPL's Avatar
I'd love a 245 TDi. I am just not made of money, free time, and space to park cars.
Old 06-07-2021, 11:30 AM   #48
Probably wouldn't be a huge amount of money. ALH motor, Toyota pickup trans, adapter.
No help on the free time and parking space issue though, lol.
I've occasionally pondered a TDI swap into my PV.
Old 06-07-2021, 12:28 PM   #49
That would be a great swap, especially with how much smaller (dimensionally) a VW 4cyl is over a redblock. They're so cute and tiny!
Old 06-07-2021, 12:35 PM   #50
cwdodson88
Thats where you'd use an AC system with tunable regen and low cogging torque. Then under braking, it applies progressively harder braking torque charging up you system, and under cruise applies the pulse and coast method to maintain pack levels at peak. The whole time, its using the road as power connection between the front wheels (ICE powered) and rear wheels (electric motor generator unit).
I believe this has been done with DC motors, but its not exactly tunable, and has inherent efficiency problems. With synchronus AC, you can manage the direction of current a lot better, more efficiently, and with more resolution when it comes to implementing it with other variables.
