Old 05-06-2021, 07:52 PM   #1
spock345
spock345's Avatar
Default Oil for an M410
Any recommendations on oil for an M410? I assume it has the same GL-4 restriction as the M40/41 for gear oil. Does redline MTL work or should I just go pick up some SAE 30?
Anything I should do with the gearbox before I pop it into the car?
Edit: I just noticed I put this in performance, if a mod sees it please move it to maintenance.
1967 122s, B20F, M40
Old 05-06-2021, 10:30 PM   #2
planetman
planetman's Avatar
Volvo recommended 30wt engine oil and we prefer to use 30wt non-detergent.
Eric
Torrance, CA 90502
planetman is online now   Reply With Quote
Old 05-06-2021, 10:49 PM   #3
M410 oil is the new performance.
how psi stock cna sprout?
Old 05-07-2021, 10:48 AM   #4
mikep
The MP
mikep's Avatar
repost
http://forums.turbobricks.com/showthread.php?t=360210
Old 05-07-2021, 10:49 AM   #5
mikep
The MP
mikep's Avatar
moved to where the real automotive geniuses hang out.
Old 05-07-2021, 03:05 PM   #6
Off topic is the new performance.
Old 05-07-2021, 04:35 PM   #7
spock345
spock345's Avatar
Maybe everything is performance?
Old 05-08-2021, 07:48 AM   #8
Beep beep zip tang
Every MT I've put Pennzoil Synchromesh in has worked better afterwards.
Old 05-08-2021, 07:54 AM   #9
leecatd8209
This or Redline MTL is all I've ever put in anything.
MTL is somewhat temperature sensitive, if you live in a cold climate it likes a little warm up time.
leecatd8209 is offline   Reply With Quote
Old 05-08-2021, 08:54 AM   #10
mikep
The MP
mikep's Avatar
If any archaic spec ever calls for engine oil in a trans, use motorcycle oil (4T). Many automotive oils do not play nicely with transmissions. Use the MB spec (not compatible with wet clutches) for any brass/bronze etc synchros. Or you can use ATF like I do. or transaxle lube, MTL, etc as long as you know it is compatible with your type of synchros.
If you have synchros with friction material, use 4T MA (compatible with wet clutches).
Old 05-08-2021, 01:56 PM   #11
OttoB
Im going to try Mobil Delvac on my M410. Positive comments from wet-clutch motor-cycle guys, so why not
Old 05-09-2021, 06:48 AM   #12
mikep
The MP
mikep's Avatar
If you mean the sae 50 transmission oil, sure. But the wet clutch guys are lying to themselves or have no power.
Old 05-09-2021, 11:49 AM   #13
spock345
spock345's Avatar
I am assuming the M410, given its relation to the M40/41 has synchros that are susceptible to GL5 eating them. I don't think there is any friction material.
Although I do wonder how the 4T oil plays with the cone clutch in the overdrive.
Old 05-09-2021, 06:32 PM   #14
Beep beep zip tang
It's the sulfur in the GL5 EP gear oil that eats up bronze synchronizers, I made that mistake with my Toyota Matrix but the manual called our GL4 or GL5, Toyota rebuilt the transmission under warranty. The oil was very pretty, like Goldschlager in the drain pan.
Old 05-09-2021, 07:20 PM   #15
mikep
The MP
mikep's Avatar
I can try it out.
When I worked on British cars we used sae90 or ATF, depending on how hard it would be used. (atf for abuse, 90 for quiet operation in show cars). And we shifted them into OD without the clutch, under power.
Old 05-10-2021, 01:02 AM   #16
c1800
Redline MTL
Old 05-10-2021, 01:51 PM   #17
Harry Tuttle
Originally Posted by sbabbs
just gutless low compression k-junk
Old 05-10-2021, 03:32 PM   #18
90volvo
yelp I tried every kind of oil/fluid in my m47 back when I was running it. The pennz synchromesh worked better than any expensive stuff out there.
B230ft rebuilt -MS-Turbo-E85
1985 240 Work in progress.
Old 05-10-2021, 09:39 PM   #19
mikep
The MP
mikep's Avatar
good to know. I like finding new stuff to try.
Old 05-16-2021, 03:42 PM   #20
spock345
spock345's Avatar
Non detergent SAE 30 was on sale at the local Napa for ~$2 a quart. So I just stocked up on that.
