Old 05-21-2021, 11:49 PM   #1
8587turbo
Default Front sway bar 30mm?
Just came across a 745turbo (89) with a 30mm front sway & a 25mm IPD rear sway bar. Did IPD make a 30mm front sway ? no tag but could be black in color. has lowering springs .. RR spring broke when car was jacked up & its looking more like a parts car than a fixer. Thanks for info.
8587turbo is offline   Reply With Quote
Old 05-22-2021, 09:54 AM   #2
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
https://forums.turbobricks.com/showthread.php?t=341371
A clue, perhaps?
Any pics? How is it mounted?
I sell chips for LH 2.4!
Old 05-24-2021, 12:51 PM   #3
Stiggy Pop
Stiggy Pop's Avatar
you sure it's not 28?
'79 242
943 pickup
Old 05-25-2021, 12:09 AM   #4
8587turbo
Took a close look at it today & it has a IPD tag . Measured 30mm, but will confirm that once It's wiped down. Looks like a complete IPD sways & lowering springs. My trusty HF caliper read 1 1/4" dead on 30mm. Will double check & advise.
Old 05-25-2021, 10:50 AM   #5
mikep
The MP
mikep's Avatar
1.25" x 25.4 = 31.75
Smells fishy.
Clean and re-measure, make sure you zero the dial/digital caliper.
Old 05-25-2021, 07:46 PM   #6
redblockpowered
I don't even think they made 28mm front sway bars for 700/900s like they did for 240s. Does it look way bigger than the rear one?
Old 05-25-2021, 10:09 PM   #7
mikep
The MP
mikep's Avatar
Maybe it’s custom. I used to bend bars, but not that big.
Old 05-26-2021, 03:13 PM   #8
could be a random alternate application bar stuffed onto a 740.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
