Old 06-07-2021, 10:08 AM   #1
Beep beep zip tang
Default 5 bar oil pressure gauge wiring
I know there was just a thread about this but I can't find it. I have power going to the gauge, when I hook up the one terminal on the sender the gauge jumps a little then sits on 0 psi. If I put it on the other terminal it pegs out below 0, could I have the power reversed? I got the gauge and sender from pick and pull so I don't know if the wiring is factory. I have + going to blue/ red wire and - to the black wire and green coming from the gauge terminal.
Old 06-07-2021, 10:32 AM   #2
oldschoolvolvo
oldschoolvolvo's Avatar
OE 52mm gauge?
Looking at the back of the gauge:
-12v to the bottom spade terminal
-ground to the side spade terminal
-sender connection to the top spade terminal
How is your sender connected at the engine? Does it have a good ground to the block (no sealant on threads)?
Also FWIW, the 5 bar gauge I have needs a tap or two with my finger to "wake up" when the car is first started.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 06-07-2021, 10:51 AM   #3
Beep beep zip tang
I checked for good continuity to the block for the ground, I'll check and see how the wiring on the gauge is connected.
Old 06-07-2021, 04:00 PM   #4
Khrrck
Professional Amateur
Which sender do you have?
The dummy light sender which comes stock won't work with the 5 bar gauge, you need the big cylindrical VDO sender for it.
Here's the recent thread:
https://forums.turbobricks.com/showt...15#post6190115
'87 240 budget wagon.
Old 06-07-2021, 04:07 PM   #5
James M
Bored member
James M's Avatar
They also make different sensors for different ranges, make sure you got the right PN
Old 06-07-2021, 10:18 PM   #6
Beep beep zip tang
I got both parts from a junkyard car, it's definitely a gauge sending unit, it's got the G and W terminals. No chance to mess with it today had to get a free warranty battery from Walmart for the 780 and also put some a/c repair in.
Old 06-08-2021, 09:40 PM   #7
Beep beep zip tang
Wiring appears correct, the letter markings on the sender are hidden by the heater pipe. When I put it on one terminal i get 0psi when I put it on the other I get negative psi. Maybe it didn't work for the junkyard car either. When I put it to KP2 the needle jumps up to 0 from resting.
Old 06-08-2021, 10:57 PM   #8
spock345
spock345's Avatar
I know they have a 3 bar, 5 bar (80psi-ish), and a 100psi one. With a couple versions of each with different resistance ranges.
All of them should though produce some activity on the gauge even if the gauge/sender combination is wrong.
Have you got some resistors on hand to test the gauge with? The sender is really just a variable resistor between the gauge and ground (the engine).
1967 122s, B20F, M40
Old 06-08-2021, 11:29 PM   #9
James M
Bored member
James M's Avatar
G should be to the gauge (sending unit portion) and W should be for the warning light (switch). I'm sure you could find a chart of resistance values vs pressure and check between G and ground, if its within spec its probably the gauge.
Old 06-08-2021, 11:39 PM   #10
The Librarian
You need to remove the sender and check the part number. It might have the wrong sender.
Some of the 2 terminal VDO senders have a floating ground. They look like the sender for a gauge and a light but one terminal is for ground, not a light.
Old 06-08-2021, 11:48 PM   #11
James M
Bored member
James M's Avatar
Couldn't you still check for ground engine off/on at W to see if it's for a warning light or ground input?
Although I wouldn't think a floating ground sending unit would be able to peg the gauge with only one connection
Old 06-09-2021, 12:08 AM   #12
The Librarian
OP says he can't read the letters on the terminals but the gauge sits at 0 connected one way and it pegs below 0 when switched to the other terminal.
Old 06-09-2021, 12:35 AM   #13
James M
Bored member
James M's Avatar
Ah I see, I only read the flip, not the flop.
Id'e still expect (correct me if I'm wrong, working off the diagram never used one) that a floating ground sending unit wouldn't move the gauge at all without a ground hookup as it's just an open circuit without it.
Old 06-09-2021, 01:03 AM   #14
The Librarian
I think you're right but electricity will do weird things when it can't find a path to ground.
I think the sender may be faulty. It shouldn't be too hard to test with a DVOM.
Old 06-09-2021, 07:17 AM   #15
mikep
The MP
mikep's Avatar
John, I still have the VDO gauge and sender I got from you. If you need them I will mail.
I did that with this one, used an air pressure regulator to apply pressure, measured resistance.
Not sure I still have it but it was easy to do.
Old 06-09-2021, 07:53 AM   #16
Beep beep zip tang
Mike, thanks but I don't think that was me, maybe Aaron? I'll check it with a meter, probably not today though is supposed to be rainy after work.
Old 06-09-2021, 12:38 PM   #17
dalek
Benchracer Tribe
dalek's Avatar
I don't know if this helps but with a resistor and 12V you could fake the sensor to the gauge:
https://vdo-webshop.nl/en/pressure-s...590691262.html
Feedback!
