Old 02-12-2020, 04:10 AM   #1
WTF99
Default Search how do it myself short shifter m90
Hello
I search a tutorial for do it myself a short shifter for m90
I have listen that a need to extend the pivot point around 1cm but I have egaly listen 4cm what is the best length for reducing the maximum without have a shifter to hard how I need 2 arms for change gears LOL.
Thanks
Sorry for my bad level in english
WTF99 is offline   Reply With Quote
Old 02-12-2020, 05:02 AM   #2
How does the throw compare to a stock m46/m47?
I extended my m47 shifter 15mm, and it’s what I feel is a good OEM throw now. Next one will be 20mm I think.
The limiting factor is usually the rubber joint on the transmission and driveline, as the bottom of t shifter gets close to that.
Old 02-12-2020, 05:20 AM   #3
WTF99
No idea if the m46/m47 can be compared at the m90
Have you measure the movement before and after ?
Old 02-12-2020, 05:27 AM   #4
Yes, but Iím on holiday and the numbers are in the shop. Itíll be about 10 days until Iím back there.
Old 02-13-2020, 09:34 AM   #5
bugjam1999
My m90 short shifter was extended by 15mm below the pivot ball - feels good to me, I donít think Iíd want it to be any shorter.
Cheers
bugjam1999 is offline   Reply With Quote
Old 02-13-2020, 12:19 PM   #6
WTF99
Cheers
Thanks for the information
Have you measure the approximate length that's you have win ?
Old 02-13-2020, 05:46 PM   #7
bugjam1999
The approximate length....now? No, I havenít- but I have a couple of photos I can email you, pm me your email address and Iíll send them over.
Cheers
Old 02-13-2020, 09:34 PM   #8
WTF99
Share the pics directly of the thread that can help other people's with the time
Old 02-14-2020, 06:17 AM   #9
crogthomas
crogthomas's Avatar
I too extended 15mm below the pivot on my M90.
4cm sounds too long, I'd expect you'd end up hitting the driveshaft.
Old 02-14-2020, 11:39 AM   #10
WTF99
The guy who told me 4cm is a CENSURED is for this I prefer ask here for have conformation and feedbacks
I test 15mm or maybe 20mm but not more
Is some one have the measure from the movement before and after is appreciate.
Old 02-15-2020, 08:50 AM   #11
Swedbrick
Swedbrick's Avatar
The stock length from pivot ball to the center of where the shifter fork attached is about 30-40mm, so adding 15-20mm would result in about 2/3 of stock travel.
I added about 20mm, feels about right, on my brother's car we did a little more ~30-35 but changed it back since the force required for shifting was a bit too much;)
Volvo 745 - IPD springs, Sways, K-cam, LH2.4, M90 swap, 3.94 diff, track/daily
Old 02-16-2020, 03:13 AM   #12
WTF99
Thanks for the feedback.
