dmg4
- Jan 22, 2022
- Geneva, NY
Tis the winter season and my 1993 240 Classic wagon is off the road until Spring and road salt is gone, and so this is a good time to work on various issues.
Chief among these is that the car runs beautifully, but 0-60 times might be better measured with a calendar than a stop watch. It is a normally-aspirated engine, automatic transmission, with 145,000 miles. I have performed all of the customary stage 0 maintenance: plugs, wires, distributor cap, timing belt, coolant flush and change, oil and filter change, transmission flush and fluid change, new air filter, cleaned MAF filament, new O2 sensor, new injectors, new flame trap and breather box and all associated vacuum hoses, all with quality parts from IPD. Tires are 205/70/14. Speedometer is dead-nuts on. One passenger: me (155 lbs). Gas tank was full (87 octane). Timing was with a digital stopwatch.
Average of ten 0-60 times was 15.4 seconds after the above.
I installed the IPD VX cam (by the book), checking and confirming all valve clearances on a cold motor.
Average of ten 0-60 times was 15.3 seconds after the VX cam. Not what I was hoping for. Aside from the idle being ever-so-slightly lumpy on a cold start, and then smooth, all is as before. Gas mileage is average: 22 mpg highway at 70 mph on cruise control. I?m not sensing any ignition breakdown at high RPM. There are no drivability issues. It?s just a slug after leaving 1st gear. Second climbs smoothly but slowly, and it shifts into 3rd just shy of 60 mph and..........................................................finally we reach 60 mph.
I have read the TB post on performance upgrades to NA 240s. I will reroute the preheat tube to cold air as suggested, give Seafoam a try, and report later. Might restriction in exhaust be an issue?
Other than that, do you have any suggestions as to what I should try next? I had expected more from the VX camshaft. I?m trying to keep my expectations reasonable, but what can one expect from this car with the above. The VX cam is advertised as generating ca 10% more HP. I just don?t feel it.
