Old 08-13-2022, 05:09 PM   #1
Fawnzee
Default 1975 245 B23+T - The Fastest Hunt in the World
Thanks to @122power and the other tbrickers on here, I'm now the proud owner of a teal '75 245. CA smog referees, you can't hurt me anymore
Current status:
1975 245 teal on teal interior with the perfect amount of patina
Headless B23 shortblock with an '83 jtype m46 that's 90% of the way in (needs auto aluminum spacers to drop a bit, and driveshaft installed)
4.10 rear axle
K Jet harness and intake box
Stage 0 intentions to get it running and see if I'll get bored of the b23+t :
Get a head, throw on all of my 940 turbo bits
Normal stage 0 stuff, filters, plugs, oil, etc
Finish the m46 install
IPD Turbo cam
RSI Stage 2 Turbo Cam
MaxxECU Race Install
Currently pondering what I'm doing for engine management, while I wait for the SoCal heat wave to go away.
It needs an LH2.2 maf, ECU/EZK, and wiring harness. My concern is that NOS MAFs are unobtanium, and buying known good MAFs would just be kicking the can down the road.
I'm heavily considering just going straight to MS and converting to an easily accessible GM MAP, plus it would allow for a higher ceiling in terms of what I could do if I do decide to go whiteblock/v8. Seems like a buy once, cry once situation, compared to getting everything together for LH2.2, just to swap it out later down the road. Open to any insight on that end.
1975 Teal 245
Fawnzee is offline   Reply With Quote
Old 08-13-2022, 05:28 PM   #2
white855T
Nice. Looks real solid.
Old 08-13-2022, 05:31 PM   #3
- Stock PSI Or Bust -
Default Don't Panic / Remain Calm
Buy a Bosch remanned MAF for dirtt Dogg cheap from Johnathan.
https://forums.turbobricks.com/showp...31&postcount=5
how psi stock cna sprout?
Old 08-13-2022, 09:58 PM   #4
James M
Bored member
James M's Avatar
Congrats, that's the much nicer twin of the car I never got you pictures of (my bad)
^ the above maf and 2.2 before your elbow deep in a swap and haven't even driven the car
Old 08-14-2022, 08:27 AM   #5
Chuck W
Chuck W's Avatar
That is a nice looking starting point!
It would be much more fun to drive it while you gather parts for a swap, IMO.
'78 264GLE
'97 854 T5 (Manual swap/DIY M4.4/COP/16T/P2R brakes)
'80 264GLE (B21FT/M46/MS) - SOLD '77 242DL (B21F/M45) - SOLD '75 245DL SOLD '85 244GLT DEAD
'83 Tbird Turbo (2.3T/T5/MegaSquirt) - '85 Marquis LTS (Canadian LTD LX)
My feedback thread
Old 08-14-2022, 09:57 AM   #6
2 old for this
I used to have one just like that. Original owner gave it to me. I sold it to a postman for a pov use on his rout.lost track of it years ago. Any owners manual in it ?
Old 08-14-2022, 02:27 PM   #7
Toybox
mostly lurking
Toybox's Avatar
You lucky dog.
Old 08-14-2022, 02:47 PM   #8
mattd1205
mattd1205's Avatar
Super jealous. I’m also in California and I’d love to have a 245 that I could modify without being subject to smog tests. Good luck with the project!
mattd1205 is offline   Reply With Quote
Old 08-14-2022, 05:21 PM   #9
Fawnzee
Full maintenance records til ~60k, has all 3 books, but it was an Oregon car before 122power had it, and then sat for ~6 years
Old 08-14-2022, 05:22 PM   #10
Fawnzee
Thanks for the suggestion! Sent a pm to pick up one for the white wagon as I'm chasing down a stumble when snapping throttle plate to WOT and freerevving
Old 08-14-2022, 05:26 PM   #11
Fawnzee
That's a good point; however, given that it's still missing the head and all of the 2.2 components (ecu, harness, ezk), it is pretty much the same starting point for ms or 2.2. If it were further along, I'd absolutely just slap it together as an na 2.2 car, but at its current state, I feel like I'd be putting it together just to pull it apart further down the road
Old 08-15-2022, 06:12 PM   #12
swedishiron.com
I sell Volvo parts!
I agree!
Here's my feedback thread:
http://forums.turbobricks.com/showthread.php?t=25568
I ship small packages/purchases on Fridays, and larger ticket items via FedEx in the middle of the week.
swedishiron.com is offline   Reply With Quote
Old 08-16-2022, 12:45 AM   #13
I vote just get it running with a red block. I owned a gutted 75 244 and it was fast enough to smoke the front brakes with just a basic turbo engine.
You are going to have plenty of work just getting it, and it keeping it, on the road with HVAC, suspension, and electrical.
Driving a soggy old 1975 240 down the freeway is not fun.
Old 09-05-2022, 08:20 PM   #14
Fawnzee
Been accumulating a few parts, and made a decision regarding EMS.
After some convincing, I decided to go with a MaxxECU (Race), as I can run it for pretty much any engine I could throw into this, and my LH2.0 woes with the white wagon have turned me off from ever investing into another LH Jetronic system.
I also picked up an RSI Stage 2 turbo cam off fb marketplace, which I'm excited about.
When I got the car, I kept looking for a head, or scouring junkyards. Somehow, I managed to forget that I have a perfectly usable head from the 940 turbo donor... So the good news is, I've got pretty much all of the parts that I should need for this. Bad news is that it's been averaging 100+ for the past few weeks, and my landlord let me know that their construction plans (turn the garage into a duplex, expand the driveway) will be starting in about 2-3 weeks time. So unless I can strip the 940 turbo, bolt it all up onto the b23, drill an oil return in the b23, and wire up a standalone EMS, I'm probably gonna be stuck for 6-8 weeks, as I don't want to deal with every other weekly street cleaning for 2 non-running cars.
Silver lining is that it gives me time to answer a few questions for the build.
First being, do I go straight to DSM CAS using the yoshifab adapter? I do have a 60/2 sts flywheel, but I want to avoid benching the m46 until I really have to, and at that point, I'd probably be upgrading the transmission anyways.
Second being, do I build the head, or just get it decked and cleaned. Leaning towards decked and cleaned, because I'm feeling like building the head is gonna turn into a 4 month long downtime.
Finally, do I go e-pedal and fly-by-wire from a v70, and also, what kind of IAT sensor/where should I put it.
Once the temps cool down, I'm gonna get into cleaning up the interior, but I'm probably gonna leave the exterior dust to try and mitigate any sun exposure.
Side note, scored a sweet accessory foglight grill, brackets, and switch from a sad 75 242 that made its way into the local pyp, as well as a pea green flat hood for the white wagon.
Old 09-06-2022, 12:04 AM   #15
James M
Bored member
James M's Avatar
TLDR: Whiteblock swap?
Old 09-06-2022, 01:35 AM   #16
Fawnzee
Not out of the picture, I do love the sound of a t5, but I'm retaining redblock for a minimum of 1 month Jk, I'll run redblock for a while, can't make that decision until I feel a b23+T with an m46 behind it, and proper suspension.
Old 09-07-2022, 06:01 PM   #17
TheMenaceSD
Where in SoCal are you at. I'm in Escondido and its awful out. Can't work on my project either.
TheMenaceSD is offline   Reply With Quote
Old 09-08-2022, 02:48 AM   #18
Fawnzee
In the Riverside area, it's been heinous. Hopefully this is the last big one for the year, been itching to get outside
Old 09-08-2022, 11:52 AM   #19
TheMenaceSD
Yea, same here. Need to get it done so I can enjoy cruising around and going to meets. Hate showing up in the Kia >.<
