Old 10-23-2018, 09:48 PM   #601
Atom D&D
Atom D&D's Avatar
Got the pan welded back together and added some -6 AN fittings onto an OE rail.
I built a table to section the bellhousings. I’ll take some pics tomorrow. It’s supremely overkill, but I made it out of leftover junk from the shop.
Atom D&D is offline   Reply With Quote
Old 10-25-2018, 11:12 AM   #602
Atom D&D
Atom D&D's Avatar
Ok, so here’s the table for cutting. I used two thick a$$ plates of aluminum with a lazy Susan bearing between them, put it on some slides with a chunk of allthread (I know it technically should be acme thread, but I’m using scraps) with some nuts welded to the end for adjusting. I welded some C channel uprights and made a fixture to bolt to my angle grinder using the spots where the handles go. That bracket isn’t really square, so my plan was to c-clamp it in place and adjust until I got it to the desired height and level with the table then drill for bolts to “pin” it at that height. Seemed to work alright.
Then on to the cutting. I started by just making a “contact” ring most of the way around so I could be sure that as I cut deeper I could verify the disk wasn’t deflecting or diving. Then I cut through in most spots, leaving a few areas NOT cut all the way through so it wouldn’t pinch the wheel. Then I laid the trans on its side and finished off the last bits.
The rings line up pretty good. I’m going to make a few mounts so I can stand my block on it’s nose, bolt the 960 bellhousing ring in place then put the trans section on and start welding. I plan on putting “straps” of aluminum across the weld to help tie everything together. We’ll see.
Old 10-25-2018, 11:25 AM   #603
matt b
That's wild. Safe to say most of us wouldn't know where to start on modifying a trans like that. Why change the fittings on the fuel rail ? Were they not compatible with BMW hoses ?
Old 10-25-2018, 11:30 AM   #604
Atom D&D
Atom D&D's Avatar
No. BMW are all raw hose, and also use a return system while Volvo is returnless. This way I can add a decent regulator and adapt whatever I need pretty easily.
Old 10-25-2018, 12:59 PM   #605
vwbusman66
Stößelstange über alles
vwbusman66's Avatar
Inspired by Deboss Garage's audi trans build?
Very nice work!!
Old 10-25-2018, 02:15 PM   #606
Atom D&D
Atom D&D's Avatar
Very nice work!!
I saw this thread. Following his lead. Just making small changes.
https://www.bimmerforums.com/forum/s...d-to-fit-a-M73
Old 10-25-2018, 08:24 PM   #607
Atom D&D
Atom D&D's Avatar
So, while sticking the two together, I was a little worried about alignment knowing that the trans input shaft has a bit of slop. I took two precautions. I made a sleeve of thin aluminum that I put around the splined portion of the input shaft and slid it into the throw out guide sleeve and I made basically an extra thick pilot bearing sized block of aluminum hoping that having more engagement on the output shaft would help align things. Then I put everything together and started with some sturdy tacks, then longer welds, then all the way around (where they meet at the moment) and lastly added the “straps”. I’m going to let that sit over the weekend and weld the inside next week. Then before I assemble anything for good, I’m going to take a scrap plate of aluminum and make a fixture so if I need to duplicate this down the road, I don’t need a spare engine laying around.
I’m also going to make some filler plates to cover the gaps between the two.
Old 10-26-2018, 02:39 AM   #608
NONHOG
equal opportunity car guy
NONHOG's Avatar
You didn't happen to video the tool cutting did you? Be cool to watch that.
Nice work!
Old 10-26-2018, 05:13 AM   #609
Shifted
Shifted's Avatar
I always read the title of this thread as "Atom's *Amazing* Wagon Project Update Thread".
You do great work.
People just aren't smart.
Doing something because you enjoy it is a must in life.
Originally Posted by ME II View Post
Without mistakes there is no learning.
Originally Posted by miguels244 View Post
Yeah...buy cheap crap and watch your kid's jobs evaporate.
"The table is tilted folks, the game is rigged. And nobody seems to notice, nobody seems to care..." -- George Carlin
Shifted is online now   Reply With Quote
Old 10-26-2018, 08:50 AM   #610
PeaceEngineered
Sarcastic Optimist
PeaceEngineered's Avatar
I love all the updates on this thread, but I read with hesitation as I want to attempt bits and pieces of what you do. I just know that it will end up in the alley and crushed.
Awesome stuff!
2013 Audi Q5
Sold- 2006 V70R
Old 10-26-2018, 03:45 PM   #611
Atom D&D
Atom D&D's Avatar
Very nice work!!
So, I looked up Deboss Garage and now my day off has been wasted. I can’t turn off his channel. He’s a smart guy with some serious skills.
Nice work!
I didn’t. I did the cutting early before work and there’s no one around to hold the camera phone. I did post a spinning video on the Facebook page, but not while cutting.
You do great work.
Pretty much every time I see someone’s post that says has Amazon in it I see that too.
Awesome stuff!
Oh, I’ve made plenty of mistakes and scrapped some stuff. I just don’t show anyone that stuff.
Old 10-26-2018, 04:53 PM   #612
M.H. Yount
M.H. Yount's Avatar
Castings look pretty thick - did you bevel before welding?
Old 10-26-2018, 05:22 PM   #613
Atom D&D
Atom D&D's Avatar
I did on a percentage of it. I was concerned about beveling the whole thing and then the bevels not aligning and therefore the two not mating perfectly flat. So, I beveled, then left flats. My plan is to dig into the junction from the inside before I weld that as well. I can say that I welded it pretty hot, it was pulling stuff out from deep in the metal. When I make the fill plates for the remaining openings I’m gonna add ribs too. I’m confident in it.
Edit: if you look at the seventh and eighth pic (the first two with the trans sitting on the engine) in my last post you can see the bevels between the ribs where the blue squares are. It’s beveled all the way to the inner side of the housings.
Old 10-26-2018, 06:45 PM   #614
M.H. Yount
M.H. Yount's Avatar
Never doubted your thoroughness - just wanted more detail on approach. As usual - nice work.
Old 10-30-2018, 10:36 PM   #615
Atom D&D
Atom D&D's Avatar
Couple of pics with the pan on too.
Once I’m for sure done welding stuff up, I’ll make the trans and pan match the engine.
I’m pretty sure I can get by with the rear sump pan if I make a few modifications to the front crossmember and flop sides on the sway bar.
Old 11-02-2018, 10:42 AM   #616
Atom D&D
Atom D&D's Avatar
PCV spacer/Oil filter blockoff/Motor mount plate (future)/Alternator adapter (future). Only got one side done. The second side should be much easier since there’s no PCV in the way.
Stoked to test fit things this weekend. Not stoked to do it in the rain (as usual).
Modified crossmember (still need to add some bracing, but want to check fitment first.
Old 11-02-2018, 10:44 AM   #617
Atom D&D
Atom D&D's Avatar
Crossmember braced up a bit.
Old 11-02-2018, 04:48 PM   #618
Vol242vo
Keep it clean...
Vol242vo's Avatar
Love the updates and progress. Fun one to follow.
Derek
1 Owner - 85k mile 1980 242
-Project Thread-
Follow on IG: @vol242vo
Vol242vo is online now   Reply With Quote
Old 11-03-2018, 01:12 PM   #619
Atom D&D
Atom D&D's Avatar
Tent city set up. Got fixturing to do before I can even start playing.
Old 11-03-2018, 03:25 PM   #620
Atom D&D
Atom D&D's Avatar
Well, sits a little tight to the firewall. The trans mount and driveshaft are adjustable though, so I’ll probably slide it forward just a hair. The good news is the modified crossmember clears the 960 pan without having to cut into the sump any more. Sway bar might be tough. I made a fixture to locate where it ends in stock configuration, so I’ll flip it and see where it lands on the front of the pan.
Anywho...
Plenty of room to the core support
Overall height comparison (without the top half of the Volvo intake
Maybe it’ll transfer some weight back??
Old 11-03-2018, 05:28 PM   #621
M.H. Yount
M.H. Yount's Avatar
On weight redistribution - Bimmer block cast iron or aluminum?
Saw this one today at our local C&C --
Old 11-03-2018, 06:21 PM   #622
vwbusman66
vwbusman66's Avatar
That would be TB member slick70's
Old 11-03-2018, 07:52 PM   #623
Atom D&D
Atom D&D's Avatar
As far as I know cast iron.
Old 11-03-2018, 07:52 PM   #624
Atom D&D
Atom D&D's Avatar
Once I was sure the pan would clear, I made some pieces to bolt to the pan rail then braced them multiple times to the crossmember. This way I can pull both out and build mounts out of the car.
Then I figured out turbo placement and made a bracket so I can build parts out of the car there too. Going to weld a 90° on the outlet for right radius.
Old 11-04-2018, 05:15 PM   #625
Atom D&D
Atom D&D's Avatar
Last fixture for the weekend. This will make it so I can build the upper plenum at work and be sure it’ll clear parts in the car.
The crossmember with the pan rail fixture
