Old 05-09-2019, 01:03 AM   #1
GeneralBurrito
GeneralBurrito's Avatar
Default Has anyone used Retro Turbo's camber plates?
I have recently been getting a clunk in the front which I really think is failing strut mounts. The rubber was all cracked and nasty looking back when I was throwing an angle grinder at my coils, which made 2 coils fall off. I would like to go OEM Volvo, but for around the same price as 2 stock rubber mounts, I can get RT's camber plates that are mild steel.
http://www.retroturbo.com/?product=v...ber-plates-txr
Old 05-09-2019, 04:15 AM   #2
classicswede
Volvo upgrades
or you can get stainless ones https://www.classicswede.co.uk/V2_24..._14936909.aspx
Old 05-09-2019, 06:54 AM   #3
GeneralBurrito
So other than being made of different steel, is the CS one any better than the RT one? They both look like they have pillow ball bearings, but the CS has a bit more camber adjustment.
Old 05-09-2019, 10:33 AM   #4
You should also consider these.
https://www.bneshop.com/collections/...t-strut-mounts
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 05-09-2019, 10:35 AM   #5
gsellstr
Vintage anti-ricer
gsellstr's Avatar
I have the 7/9 version of ^^^^, been really happy with them.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 05-09-2019, 10:51 AM   #6
GeneralBurrito
I really just want some decent mounts until I get coilovers, which I'll go all out on.
Old 05-09-2019, 02:53 PM   #7
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
if we had an advertisement jar, we would have 3 bucks in it now.. :D
Old 05-09-2019, 06:05 PM   #8
GeneralBurrito
We need every single company that makes strut mounts for 240s on this thread.
Old 05-09-2019, 06:07 PM   #9
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Or support the guy that resides on the board and makes a quality product with a quality track record, that's also here in the states.
Old 05-09-2019, 08:55 PM   #10
boostin'xr4
OV FIRE
boostin'xr4's Avatar
Ben's products all the way. You get parts that are engineered, not just created. Worth the money 100%.
'74 145 - B20, M40, Weber 38DGES
'82 244t - B21ft, MS, E85, H cam, 50trim, T5 swap, etc.
'94 945t - MS, E85, 1500cc's, top mount, 6262, Cd009, etc.
boostin'xr4 is offline   Reply With Quote
Old 05-09-2019, 09:50 PM   #11
GeneralBurrito
I'm sure I'm going with Ben's coilovers with all the good things added onto them, just not at the moment since I have college and summer classes.
Old 05-09-2019, 09:58 PM   #12
mrak
Beefsma by Design
mrak's Avatar
The way I look at it, is you can get two OEM rubber mounts for 165 off FCP, which I've heard in rumor have dropped in quality, or you can get Ben's for 185. Plus if you get coil overs later, I'm sure you can resell Ben's here on the forum.
mrak is offline   Reply With Quote
Old 05-09-2019, 10:50 PM   #13
The ones from Ben also fit coilovers and those parts are available with the easy steer option.
Old 05-09-2019, 11:02 PM   #14
boostin'xr4
OV FIRE
And they make a huge difference. You wouldn't believe how much the stock upper mounts negatively affect handling.
Old 05-09-2019, 11:16 PM   #15
PeaceEngineered
Sarcastic Optimist
PeaceEngineered's Avatar
You can get Ben's mounts, use them in place of stock because they will outlast the replacement factory pieces, save up coin, buy Ben's coilovers and reuse the plates. Simple. I highly recommend them.
2013 Audi Q5
Sold- 2006 V70R
Old 05-10-2019, 01:23 AM   #16
klr142
Turbo, what?
klr142's Avatar
“For a street car, the first or third will be the best options.
For a race car, the second or third will be the best options.”
Why do you say this? Option 2 makes more sense in my mind for a street car because more caster is harder to steer. What am I missing? Cool variation of the Group A product, I’ll probably have to get some someday.
Old 05-10-2019, 01:50 AM   #17
More caster gives more high speed straight ahead stability and a slower turn in. At low speeds it will cause higher steering effort. Volvo took advantage when adding power steering by using ball joints that added caster.
Old 05-10-2019, 10:46 AM   #18
I like having more caster in these cars, it makes them more calm on the highway and it puts a nicer weight into the steering. If anyone has these and coilover springs, position 3 is the way to go unless you need max - camber then you can get a little more in position 2 before you start cutting.
Old 05-10-2019, 11:24 AM   #19
Wren
Porkchop Sandwiches
Wren's Avatar
It's not a rumor, it's a fact that the currently-supplied Volvo OE mounts are junk. I bought a set of the new crop and they began to split with zero mines on them. They were so bad that I took them out and returned them to the dealer and got a refund.
Get Ben's and you won't be disappointed.
Old 05-10-2019, 12:22 PM   #20
740atl
rb67 life
740atl's Avatar
Ben,
what type of cutting is required (ballpark) to run position 2?
Old 05-10-2019, 12:50 PM   #21
klr142
Turbo, what?
klr142's Avatar
Ben, what is the ride height difference over stock with these installed?
Well, yes, more caster is more better up to a point, but I wouldn't say I'd prefer more on a street car than a race car... If the real reason is the camber can be more aggressive in position 2, then I understand. How much more caster are we talking? This should be an easily measured thing so you could state what it should be adding vs. stock mounts.
Wow, that sucks! I got some OE ones years ago and they've been fine for me for many hard miles(too low for stock length struts and too weak springs/struts). Apparently they aren't that good anymore which really sucks!
Old 05-10-2019, 12:58 PM   #22
Originally Posted by 740atl View Post
Ben,
You can run pos 2 w/out cutting but to get full adjusment (which is more camber then most people will want) you have to clearance the strut tower for the strut shaft and also trim the edge of the strut mount.
Old 05-10-2019, 01:01 PM   #23
For the height, this is pretty easily answered by looking on my webpage and seeing this picture.
Obviously no one wants 30 degrees of caster but this is a strut suspension and we are moving the top so you wont get that much by making changes. Certainly not enough to get past that point.
About 1 degree more. between 1-2 and 3 1 and 2 have ~.5 from stock.
Old 05-10-2019, 01:15 PM   #24
You should come by and drive the v8 car. It has 6deg of caster. It drives very well around PDX.
Old 05-10-2019, 04:25 PM   #25
klr142
Turbo, what?
klr142's Avatar
https://cdn.shopify.com/s/files/1/02...g?v=1448034268
I looked on my phone but apparently didn't come across that picture. I can't remember though, does the strut sit at the bottom(top in those pictures) of the mount as pictured? Meaning the difference is that your mount will lower the car about 1/4" from whatever it was at with the stock mounts?
And sounds good on the caster add, thanks!
I'm sure it does and I agree I should! Who would say no?! Hah
