Old 01-30-2021, 10:44 PM   #176
Beep beep zip tang
Nice work, does it fit the driveshaft?
Old 01-30-2021, 11:07 PM   #177
DavePolyakov
I need to get the front driveshaft shortened at the driveshaft shop and they will remove the old bearing and install this one. I was having a real difficulty removing the old one, I'm sure they can do it much easier with their hydraulic press.
Old 02-01-2021, 09:01 PM   #178
DavePolyakov
Just got home after dropping off my driveshaft and new support bearing at the shop. I'm a little concerned, the diameter of the front shaft is 2 inches, but the ID of the Spicer bearing is 1.77 inches. This is also the size of the bearing IPD says should fit these shafts. Is the diameter a little bit smaller where the bearing sits? Will it fit?
Old 02-01-2021, 09:45 PM   #179
Beep beep zip tang
It should
Old 02-01-2021, 11:15 PM   #180
DavePolyakov
That's what I thought too. The guys at the driveshaft shop were pretty alarmed when they saw the Spicer mount.
Originally Posted by VB242 View Post
It should
Old 02-05-2021, 10:09 AM   #181
Beep beep zip tang
Thumbs up
Any word on how this turned out?
Old 02-06-2021, 02:47 AM   #182
DavePolyakov
Here it is. 4-cylinder dampened slip yoke with a shortened front shaft that is 16.5 inches front U-Joint center on the yoke to the middle of the Spicer bearing. It was raining all day today, I need to get longer bolts then I will install it tomorrow and upload a photo. Tasca messed up my first order for a rubber block that I need to install the clutch cable to the pedal and it's coming in a few weeks so I think I'll have to wait until then before I can drive it. It's confusing a 45mm or 1.771 inch ID bearing fits the two-inch shaft
Old 02-06-2021, 07:39 AM   #183
Beep beep zip tang
Thr part where the bearing sits is thicker and cut down.
Old 02-07-2021, 01:17 AM   #184
DavePolyakov
I just got back from my first drive with the T5! I went on the drive without measuring my driveline angles, assuming they were off. There was vibration from 1800-2500 at least. Not super aggressive but definitely there. I'll fix my angles in the next couple of days and that should improve things. I think I accidentally measured my front shaft 0.5-1.0 inch shorter than it should have been. The edge of the damper is basically flush with the end of the transmission as seen in the picture. This is probably sticking out a little further than ideal right? However, I think I will have to lower my center support bearing to achieve better angles and this will push it back in a little further but I'm not sure by how much. Also, when I measure the diff where should I place my phone on it? I don't exactly a flat spot that's would be accurate. I'm using the Tremec app.
Old 02-07-2021, 01:38 AM   #185
carver
Involvoed
carver's Avatar
Yeah, that's a bit too much sticking out, you only want about 3/4" to 1".
For the phone app try using the rib on the side of the diff, should be inline with the pinion.
Old 02-07-2021, 02:36 AM   #186
DavePolyakov
Ok, I'll give this a go. If I still have vibrations after correct angles should I consider getting it lengthened to 17 inches? Don't know how I measured it this far off, darn it.
Old 02-07-2021, 01:46 PM   #187
gsellstr
Vintage anti-ricer
gsellstr's Avatar
You can also put the diff yoke so the caps are top and bottom, driveshaft caps will be on the sides. Then put a socket on the bottom cap, phone on that. That allows you to measure from the joint itself.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 02-07-2021, 02:56 PM   #188
DavePolyakov
Will do. Im just mainly concerned about the length of my front shaft, it seems to short. Iíll probably have to spend another couple hundred bucks to get it lengthened and balanced again.
Old 02-08-2021, 01:57 PM   #189
DET17
Reformed SAABaholic
Fix angles first, length second.
"Cut it twice, and it's still too short!"
Old 02-08-2021, 03:25 PM   #190
DavePolyakov
Yes, I will go under the car today and get it right. The fact I messed up the measurement the first time is such a slap in the face. I swear it was correct. If the vibration is gone after I fix angles, am I hurting anything if the yoke is out that far? I probably should get it lengthened even if the vibration is gone, but it's probably going to be 200ish bucks, which totals my modified driveshaft to over 500 bucks. ****
Old 02-08-2021, 05:40 PM   #191
carver
Involvoed
carver's Avatar
Here's mine... 3/4" out the back.
Thinking you might want to get that looked at, not much engagement on your setup. Measure 20 times cut once....
Yeah that sucks, I'm out about that much for everything with my custom aluminum 3" one piece setup with the monster yoke, including balance.
Old 02-08-2021, 06:08 PM   #192
DavePolyakov
It looks like your yoke is almost flush with the fin with the three bolt holes whereas mine is flush with the tail shaft. That's probably closer to a 1.5-2.0 inch difference. Also, because mine is a two-piece setup my yoke doesn't even move in or out at all during driving. It should be in at least 3/4 if not a little further because it's not ever going to bottom out. I'll probably end up going back to NW drivelines sometime this week.
Old 02-08-2021, 06:27 PM   #193
gsellstr
Vintage anti-ricer
gsellstr's Avatar
You want it to be maybe 3/4" out from fully inserted, so yeah, you're pushing it with the limited insertion. Running it that way can lead to increased wear in the bushing and splines along with more chance of vibration.
Old 02-08-2021, 06:38 PM   #194
Yep, you don't want it butting up against the seal as it needs wiggle room
Old 02-08-2021, 07:37 PM   #195
DavePolyakov
It's already leaking and it's a brand new resealed transmission. I have an idea though, could I buy a driveshaft spacer for the rear shaft, drill new holes for the center support bearing, and that might solve the issue for less money? Something like this might work?
Old 02-08-2021, 08:16 PM   #196
DET17
Reformed SAABaholic
Perhaps, regarding the spacer. Didn't YOSHIFAB make some sort of T5 spacer? Perhaps he could one off a unit for you with custom thickness. CNC program written just change a variable or two.......
Have you fully articulated your rear suspension to ensure the furthest travel of your T5 yoke, forward? As I'm sure you know, that clearance is designed to allow for full suspension travel.
Old 02-08-2021, 10:13 PM   #197
DavePolyakov
Yeah, Yoshifab does make a spacer for 240ís using a Mustang shaft. Is the ford 8.8 rear end the same size flange as the 740? I should have no problem finding a spacer if thatís the case. Iím a novice when it comes to understanding suspension systems, how else can I move the slip yoke inward other than lowering the CSB further? Iíve already lowered it around an inch with washers, but I still need to lower it even further to get better angles. Extending the rear shaft with a spacer might make good driveline angles impossible to achieve but I think Iíll buy one and see if I can make it work. If I can get it to work Iíll have saved at least 150 instead of going back to the driveshaft shop. If it doesnít work Iíll just return it anyways. No harm no foul.
Old 02-08-2021, 10:16 PM   #198
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Not sure where you're at, but my local shop only charges about $150 to retube and balance. Since you aren't doing joints, bearing, or any pressing, that should be all they are doing, shouldn't be that bad. Probably on par with getting a spacer made, but you'd be doing it the right way, not the 'right now' way.
Old 02-08-2021, 11:36 PM   #199
carver
Involvoed
carver's Avatar
Yeah that sounds like the correct plan of action. Bet they'll go a little easier on you because you were just in as well. NW Drivelines has been good to me.
Old 02-09-2021, 10:47 PM   #200
DavePolyakov
Getting it lengthened would be the most legit way, but I think I found a perfectly fine solution. I drilled new holes for the CSB one inch further on the plate and mounted it up. The slip yoke built into the two shafts has about two inches with no splines, so all the splines are still contacting even though it's moved out one inch. Here is a picture of the connection with the two shafts and the new clearance with the T5 yoke. I'm going to go on my first drive in a few minutes to go buy some more washers to lower the bearing even more. Is there anything wrong with this? All the splines are still contacting where the two shafts meet.
