Old 11-18-2021, 09:08 PM   #1
Dvroofer
Dvroofer's Avatar
Default Starter selection
I recently had my og starter die an honorable death. Picked up one at oriellys because it was in stock. Got it installed with fresh wires, check continuity tested the switch wire. Everything was good. Within maybe an hour of letís say 5 starts because Iím tuningÖ the new starter stuck on. Decided to check everything battery Volt ect. Put a charger on it and kicked over.. tried agin stuck on even with the charger on . My question is this is obviously a piece of junk. What starters does everyone run reliably?
Thanks Dave
Dvroofer is offline   Reply With Quote
Old 11-18-2021, 09:13 PM   #2
Mr. V
Mr. V's Avatar
Thanks Dave
I keep a used one on hand from Pick n Pull for the interim, but I'd prefer to have an OEM one professionally rebuilt for the long haul.
Old 11-18-2021, 10:14 PM   #3
tintintin
Yup the oreillyzone rebuilds are pretty low QC these days. Their business plan seems to be to cheerfully exchange your warantee (Lifetime, am I right?) returns numerous times until you get a good one. Too bad they don't reimburse your R/R costs.
You'll get way faster at the R/R the second, third, fourth, etc. times.
(A common cause is a sticking starter solenoid plunger)
