Old 11-16-2021, 06:42 AM   #1
mblue240
mblue240's Avatar
Default '89 No start
I parked the car and now a few days later it won't start. It cranks fine, but won't catch. Before I beat my head on a wall trying everything please help confirm my memory.
With LH2.4 I should hear a fuel pump run just before turning the key to crank?
I jumped fuse 4 and 6 (found fuse 4 blown, did not blow again after several crankings) and confirmed the main pump cycles.
If the main pump cycles, but the in-tank has gone out the car won't run?
Today was my first time trying to fix the issue, but it was pouring rain. Having other vehicles to commute in I decided to move onto other projects that wouldn't leave me miserably wet. I'll get out in the next couple days and confirm whether or not it's a fuel issue.
-Michael
Tbricks build
Yep, Michael is right.
Old 11-16-2021, 08:07 AM   #2
cleanflametrap
cleanflametrap's Avatar
Yes, for about a second.
Fuse 4 runs the tank pump and the oxygen sensor's heater. I've seen mangled wiring at the sensor under the car cause the fuse to blow.
Normally the car will run without the in-tank pump given enough cool fuel in the tank.
Check the timing belt is turning the cam. Try a squirt of carb cleaner or starting fluid to verify ignition. Check for key-on voltage at the orange wire on the AMM.
-Art
Old 11-16-2021, 02:31 PM   #3
My car is fun hp club
Also check the main system fuse on the inner left fender. If it's corroded the car will crank but won't start.
Old 11-16-2021, 02:34 PM   #4
Since it is an 89, the first thing I would check is the 25A blade fuse above the battery. Even if the fuse is not blown, it can have a hard layer on the blades that does not conduct electricity.
Old 11-16-2021, 04:14 PM   #5
cleanflametrap
And one foolproof way to do that, not relying on visually inspecting the multiple connections made in that fuseholder and wiring, is to see battery voltage backprobing the orange wire on the AMM (red/black on a 92/93). Good voltage there with the key on ensures the 25A fuse wiring can pass a full load.
Originally Posted by cleanflametrap View Post
... Check for key-on voltage at the orange wire on the AMM.
It also checks the function of the system side of the fuel relay.
Old 11-16-2021, 10:12 PM   #6
^YES.
That is about as simple as it can get. Build/buy/use incandescent test lamp and use as shown above.
Put the same lamp between the coil negative and a good ground. Key on LAMP ON? Cranking-lamp blink?
Old 11-19-2021, 07:40 AM   #7
mblue240
mblue240's Avatar
I checked the basics, even made a jump wire for the fuel pump relay like Dave Barton suggests. Turn the key and the car started right up....then I realized what I did. The car has a persistent water leak, comes in on the firewall and pools up in the floor. I do my best to dry things out, but the car is damp all winter. I ran a space heater in it last night and I think that dried out any moisture in the computers.
It did the same thing a few years ago and I just spaced it. I had enough though, I'm fixing the leak. I pulled the seats and flooring out today. The space heater has been running for 12 hours and I'll give it another 12 to really dry out.
Old 11-19-2021, 05:36 PM   #8
cleanflametrap
Maybe we should add "check for water in the electronics" to the no-start routine. Common place for the water is in an FI relay which has been left dangling from its wiring, eliminating the drip loop it had when installed.
Common leak point is the grommet in the firewall where the wiper motor is sealed. Water entering the cowl vents forms a river dumping directly on this grommet.
Old 11-20-2021, 12:16 AM   #9
mblue240
mblue240's Avatar
My relay is dangling, so I'll add that to the to-do list.
