Old 06-01-2021, 12:53 PM   #51
amishmafia00
Has anyone else had issues with the Deeworks adapter not lining up correctly with an M46 bellhousing?
amishmafia00 is offline   Reply With Quote
Old 06-01-2021, 04:32 PM   #52
thessejway
\_( ͡❛ ͜ʖ ͡❛)_/
thessejway's Avatar
I just used it and had no issue at all.
Is it possible you got the wrong adaptor or Bellhousing? Here are some images of mine if you want reference
____________________________________________
1993 945t Build Thread
Old 06-02-2021, 10:30 AM   #53
amishmafia00
Is than an M46 also? do you know what your casting number is?
I don't see any similar adapters on the site. My bellhousing has a sticker on it that says
M46 NR 1208230
Fabr NR 113?28 (can't definitively read the ? digit)
Casting number is 1023531
Old 06-02-2021, 10:52 AM   #54
thessejway
\_( ͡❛ ͜ʖ ͡❛)_/
thessejway's Avatar
Yeah it's an m46 bellhousing
Unfortunately I don't have access to check the casting number at the moment, nor have I been able to find images of it. But here are some images of the m46 trans it came off of if that is any help.
Old 06-02-2021, 11:19 AM   #55
amishmafia00
Default Pictures
I just noticed that I can turn the bellhousing on the adapter to a point where the holes are all off by the same amount in the same direction. Like the zero point was off for that operation. I was trying to post pictures but not having much luck
Old 06-02-2021, 11:42 AM   #56
thessejway
\_( ͡❛ ͜ʖ ͡❛)_/
thessejway's Avatar
Hard to tell, but comparing your images to mine, looks like you might have a slightly different bellhousing, possibly an m47? But I really don't know
Old 06-02-2021, 11:49 AM   #57
amishmafia00
those pictures were before I realized they were all off the same amount. In that position I am able to put one bolt in. The sticker says M46, Even if it were an M47 it's supposed to work. I contacted Deeworks.
Old 06-02-2021, 11:49 AM   #58
thessejway
\_( ͡❛ ͜ʖ ͡❛)_/
thessejway's Avatar
Very possible.
I think Deeworks Cuts the center hole to order based on the type of cd trans you have
Old 06-16-2021, 02:44 PM   #59
TheLoganZilla
Originally Posted by SEslayer View Post
I can confirm the original clutch i ran with the setup was to small. it worked, and got me going, but it unevenly wore the flywheel and pressure plate.
it was the cheapest way to get the car going and it does work, its just not ideal.
it lasted me long enough to save the nearly $2000 Nzd i needed for the better setup.
The cheaper alternative that i was going to get was the clutch upgrade that Yoshifab sells, the main reason i diddnt was so in future i can buy shelf stuff for my car locally.
Im currently going through this swap myself and am considering different clutch options. When he said that the 235 mm kit would allow him to use off the shelf options in the future, what options are he talking about? I dont know of any stock nissans that use a 235 mm clutch and pressure plate. Does the 250 mm stock VQ35DE clutch fit on the yoshifab flywheel?
1993 Volvo 940 Turbo Wagon
IPD Lowering Springs w/ Bilstein shocks/struts, IPD Sway Bars and Poly Cone Bushings, 3 J-Tuning Exhaust, TD04HL-19t, CD009 manual swap
My Feedback Thread
TheLoganZilla is offline   Reply With Quote
Old 06-18-2021, 06:34 AM   #60
jtbechtold
He mentioned to me a toyota truck clutch.
jtbechtold is online now   Reply With Quote
Old 06-18-2021, 10:35 AM   #61
TheLoganZilla
Thats interesting, because I believe that while Toyota pickup truck clutches are 235 mm, Toyotas use a 21 tooth input spline. The Nissan trans has a 24 tooth spline. I may be missing something, or the Australian pickup is different from the American one.
Old 11-02-2021, 06:02 AM   #62
Volvo740brick
Default Shifter location
How far forward or back is the shifter. Im looking at that collins shifter in the thread description just wondering how much modifications were needed for it to fit. Also if the adapter plate was in the way of the clutch and flywheel.
Volvo740brick is offline   Reply With Quote
Old 11-02-2021, 01:15 PM   #63
rb92673
Volvo 745:
Here is a picture looking up:
and here is a picture looking down:
I don't think the Collins shifter has a reverse lockout. The reverse lockout also makes it easier to find 5th. My first shifter did not have a lockout and 5th was a pain.
Old 11-06-2021, 09:14 AM   #64
poulrais
poulrais's Avatar
Originally Posted by rb92673 View Post
Volvo 745:
For a 740 I would get the SerialNine shifter. That's what bought.
https://www.serialnine.com/product-p...ter-relocation
1990, Volvo 740 16v +T
poulrais is online now   Reply With Quote
Old 11-21-2021, 03:13 PM   #65
mooseturb
Default Questions re Dynamic Damper +
For those that ae running a completed swap several questions:
The trans that i got came with what Nissan refers to as the Dynamic Damper, a bunch of weights mounted at the back end of the trans. Have you left it on or taken it off will no ill effects ?? I am asking because I'm making a new trans cover and should I leave room for it?
What sensors that are on the trans have you been able to use ?
mooseturb is offline   Reply With Quote
