Old 07-21-2021, 12:06 PM   #1
89-240gl+t
Default Bennie The LS Swapped 244
Backstory:
Bought an Amazon about 8 months ago and completely redid the interior and got it to where I wanted it to be. I had no intentions of selling it but when a guy in Florida posted on the amazon Facebook page wanting to trade his LS swapped 244 I couldn't resist. We ended up doing straight trade sight unseen.
1989 244 build list
Lq9 Engine
4L80
Kaphlenke coilovers
intake fuel pump upgraded
Headers
Intake
Chevy SS intake manifold
Tune
upgraded brake master
Custom dual exhaust
Future plans
Going to be getting the interior back to where I want it, needs a bunch of little stuff but nothing major. Luckily the seats and door cards are all in really good condition.
Will be getting a custom tune by my buddy that owns a tuning shop
Rear end will be getting changed after the interior is all done
Want to swap in a bigger cam, valve springs, push rods and torque converter
First wash/detail, the cars paint is definitely not the best and was poorly done sadly. A lot of paint runs but will do the job, glad that the paint actually cam back to life
'84 242 Turbo
Rebuilt 93 B230FT block, KL Racing T3 Cam, Dual Valve Springs, 38/46 Valves, Ported, ARP Head Studs, T5WC, MSII-Extra, EDIS, Nathan Exhaust Manifold, Ebay Turbo , 90lb injectors, Full E85, 3" exhaust, Kaplhenke Coilovers Front/Rear Koni Race Single Adjustable’s, RX7 Brakes, IPD 25/25 sways
‘89 244 6.0
89-240gl+t is offline   Reply With Quote
Old 07-21-2021, 07:53 PM   #2
honeylake
Looks like a lot of fun to come! Can’t believe it got to you so fast….time to change your sig
honeylake is offline   Reply With Quote
Old 07-22-2021, 08:30 AM   #3
Jerd
Jerd's Avatar
This car looks fun! Once you get it where you want it, you should consider adding a bottle.
Jerd is offline   Reply With Quote
Old 07-22-2021, 11:20 AM   #4
esmth
Nice, Bernie is what the PO called my car too.
1991 244 LH3.1 M46 373k miles
Old 07-22-2021, 12:22 PM   #5
89-240gl+t
Haha will be doing that shortly!
Old 07-22-2021, 12:22 PM   #6
89-240gl+t
Haha I’m trying not to blow this motor up! Would be pretty wild!
Old 07-22-2021, 04:37 PM   #7
Nagrom
Nagrom's Avatar
Sweet ride! Great trade.
Nagrom is offline   Reply With Quote
Old 07-22-2021, 07:36 PM   #8
2turbotoys
Salaminizer
2turbotoys's Avatar
Looks like fun, nice score
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 07-22-2021, 11:50 PM   #9
89-240gl+t
needs a lot of little things but overall super happy with it, the motor and trans are very strong. Just gotta do some final touches
Old 07-22-2021, 11:54 PM   #10
89-240gl+t
Did some interior refresh as i'm waiting on a huge list of parts coming my way shortly.
Had these mirrors sitting around for awhile that were installed on my 242
What started as a simple vacuum quickly turned into stripping the entire interior
Refresh the rear belt cover with SEM Bumper Coater, SEM Color Coat seems to make this part in particular too shiny
Old 11-21-2021, 03:44 PM   #11
89-240gl+t
Its been awhile since I posted here but slowly getting things checked off the list
Added two layers of kilomat, helped out a lot with cabin noise. Still would like to add some more in the rear
When I first got the car it had some small tires on them so I changed them out for 225/50 all around. Definitely should have went with a smaller sidewall but it looks pretty dam good
The control arm bushings needed some attention, installed some superpro poly
resprayed the bumper/trim, grille, belt line trim and window trim
The major thing about this car that I do not like is that the previous owner had a very poor paint job done. When I was taping off the belt line trim the paint was coming off, I will be prepping the car for some 3m gloss black wrap. Besides the paint I'm very happy with how the car is coming along
Have some goodies on the way as well! Very excited to get these parts installed
SS2 Cam
PAC 1218 Springs
Titanium Retainers
Hardened Spring Seats
New Valve Stem Seals
7.400 5/16 chromoly pushrods
LS7 Lifters
Melling 10296 High Volume Oil Pump
LS1 Rocker Arms with upgraded Trunions Installed
IWIS Timing Chain Set with 58x Cam Sprocket, ARP Cam Bolts, Crank Gear and Dampener
ARP Head Bolts
BTR LS9 Cylinder Head Gaskets MLS Pair Turbo Multi Layer 4.100 Bore
New water pump
Crank Pulley/bolt
ICT billet accessor adapters
3600 stall
Locker diff
Old 11-25-2021, 12:46 PM   #12
honeylake
Lookin great!
I can tell you that the “sound barrier” layer on top of the deadening material makes a huge difference for sound levels.
