Old 11-04-2021, 08:34 AM   #51
ortho stice
Have you pulled the CBV off to check the diaphragm yet? This idea that the turbo is “bad” doesn’t make a ton of sense to me. Why is it bad? How is it bad? Throwing another turbo at it might put you right where you are today.
ortho stice is offline   Reply With Quote
Old 11-04-2021, 10:56 AM   #52
Urvanej
Passing smog test does not say anything about clogged cat. Ask me how I know...
Urvanej is offline   Reply With Quote
Old 11-04-2021, 05:33 PM   #53
Pull the down pipe.
Old 11-04-2021, 06:30 PM   #54
PCH
How difficult is to obtain exact psi boost reading and be done with guessing about the turbo?
Old 11-05-2021, 11:16 AM   #55
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
Originally Posted by Studie View Post
No clogged cat. The car passes SMOG with no problem with flying colors.
I'm thinking perhaps its time for a new turbo.
Doesn't test under load, which is when the restriction will **** your backpressure & kill boost
Not hard to unbolt the DP & wedge a screwdriver in there to maintain a gap (leak), drive around the parking lot. You will know immediately if the symptom is resolved.
Old 11-05-2021, 12:22 PM   #56
lummert
lummert's Avatar
If that is a low pressure turbo the waste gate actuator would be set at about 4 psi. When I was running one of these on my 88 765 I used a washer between the compressor housing and the actuator on each of the 2 bolts to move the actuator as it wasn't adjustable. Ended up with 7 psi.
Old 11-12-2021, 10:23 PM   #57
Studie
Re-seated the preloading arm to a bit more than half of the hole. Changed the fuel regulator and deleted the sponge in the airbox.
Added a whole tank with some octane boost and injector cleaner, ran the car for a long drive and voila we are back in business!
There is nearly half of the positive boost on the OEM gauge at WOT. Car runs well, flushed the engine, and replaced the oil with Liquimoly 5w40 + MOS2 treatment since we get super cold winters here, and planning to do the coolant tomorrow. Car is idling perfectly.
Will pull the downpipe and get the exhaust worked on over the winter, hopefully, see some more power with this dinky 13c turbo.
I guess it's time for a manual boost controller?!
Studie is offline   Reply With Quote
Old 11-15-2021, 09:43 PM   #58
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
You won't really get more than 12 useful psi put of it but fo for it! Even a small bump in boost really wakes these cars up
Deb the 940T Tina XC90 T5
Old 11-15-2021, 10:12 PM   #59
lookforjoe
lookforjoe's Avatar
Indeed - I'm only running 5-6psi on my 13c Regina +T, and it's night & day from a stock Regina/Rex
