Old 09-17-2021, 06:35 PM   #451
rijk
rijk's Avatar
Default Good luck
Good luck with the build of your new workshop, Sander.
The B204FT to B234FT conversion
http://forums.turbobricks.com/showthread.php?t=182821
rijk is offline   Reply With Quote
Old 09-17-2021, 06:58 PM   #452
ortho stice
…underground?? Sounds cool.
ortho stice is online now   Reply With Quote
Old 09-22-2021, 01:41 AM   #453
JerryJS8
der Junge
JerryJS8's Avatar
An underground workshop in the Netherlands??? But if anyone is good at building below sea level, it's gonna be you guys
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 11-12-2021, 03:02 PM   #454
940 16 valve
940 16 valve's Avatar
Always love reading this thread! Any pictures of this underground workshop? Sounds very interesting.
Sander - what's your plan for getting a signal for the speedometer with the BMW rear end? I've been looking at solutions for my BMW diff - like yours - and how I might be able to fabricate a new tone ring to replace the BMW one with the proper number of sensor holes. Have you come up with anything, or does it somehow tie into your ABS solution?
1991 940 - stock b234+t -retired http://forums.turbobricks.com/showthread.php?t=243308
1989 760 - T5 (B5254T2 with a 6 speed!) http://forums.turbobricks.com/showthread.php?t=341191
940 16 valve is offline   Reply With Quote
Old 11-15-2021, 09:37 AM   #455
Sander
Good news everyone!
Sander's Avatar
Haha I live on a hill, no issues with water here
I have 2 options for that, option 1 is indeed the speedo output of the ABS unit. Option 2 (which I'm going with) is via my transmission controller. The stand alone unit I'm using needs a speed input and can handle basically anything for an input, including the BMW sensor type and tone ring. The controller can then output a fully definable signal for the speedo to read.
Your solution won't work with the BMW sensor in the Volvo btw. BMW uses a different kind of sensor. It's basically a contact point that gets closed by a magnet and opens when the tone wheel gets between it. That way it makes a 5v square wave signal that the Volvo can't read. You need the Volvo sensor too.
Old 11-22-2021, 05:10 PM   #456
940 16 valve
Thanks for the info Sander, that saves me a lot of time going down that rabbithole. Back to the drawing board then!
