Old 12-31-2020, 05:27 AM   #1
pathfinder
Default 940 low budget mods (engine)
Hi to all. Merry Christmas
It's year 1997, 940 B230FK, auto transmission
Targeting mild uprade around 200bhp and 280-300nm
Will the all standard 13C, injectors and fuel pump, exhaust... by using Rica fuel and ignition chips ...will this can get 200bhp?
Hard to find 15G turbo. Could the 13C be hybrid using billet fins 16T ? I think can't go over 16T with auto transmission...bigger like 19T maybe causing lag
As for ori fuel pump, any idea of its lph flow? And original injectors.. what is the cc ?
Thanks
pathfinder is offline   Reply With Quote
Old 12-31-2020, 06:50 AM   #2
Fa182
Stage 1
Fa182's Avatar
Not really.
There are upgrade kits out there with the compressor wheel and a new housing, but by the time you bought all of that stuff to "upgrade" the tiny 13C, you'd probably be better off just getting a used 16T.
I'm guessing you're from Europe and I also had a hard time finding a 16T, so I bought one from swedishiron.com on here and it ran me cheaper with shipping from US to EU than getting a used one locally.
I believe he usually has 16T (or even 15G) turbos in stock. PM him.
0-280-150-804 injectors are 337cc - source: http://users.erols.com/srweiss/tableifc.htm#BOSCH
Other suggestion is to get an intercooler from KL Racing. That improved the noticeable torque much more than upgrading the turbo in my case.
But especially when you turn up the boost from the low stock 0,35 bar of the FK engine (I have a FT engine so stock was already at 0,55bar).
Also, I use chips from here, they're great: http://forums.turbobricks.com/showthread.php?t=355788
Old 12-31-2020, 09:11 AM   #3
pathfinder
Thanks for reply
Im from Malaysia. 940 FK sold here in 1996-1997. Mine odometer is 380,000km . Quite high. i will do engine top overhaul and overhaul the auto transmission before upgrade the power
Got to be realistic, can't go for too much power. Considering it's age.
15G is rare now. Some turbo shops here suggest to use original 13C with billet fins. How many billet fins should i use for strong and fast response from low to mid range rpm power band?
Plenty of 14T over here, or better use 14T with billet fins?
As for original spec fuel pump and injectors, do u think they are enough for 200-220bhp at engine?
Do u know the original fuel pump flow in liter per hour?
Thanks
Old 12-31-2020, 10:46 PM   #4
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
I think injectors and pump are fine
Deb the 940T Tina XC90 T5
Wilford Brimley is online now   Reply With Quote
Old 01-01-2021, 06:51 AM   #5
Sjeng
Sjeng's Avatar
Had a stock 940... B230fk, 360.000 km.
Increased boost to 0.8bar by adding springs to the wg actuator.
Works fine on stock ECU. Wouldn't go much above that though.
Old 01-01-2021, 01:07 PM   #6
jf.xv
The absolute easiest thing you can do is stick a manual boost controller on it and turn up the boost to ~12 psi. If you go much above this, you'll probably hit fuel cut on a stock ecu without chips. It does vary though, I saw 15psi before hitting fuel cut. You'll want a boost gauge as well to monitor what boost you're running.
The 15G isn't really that good an upgrade. The compressor is only slightly bigger than the 13c. The only real reason to use it is if you want a turbo to use a conical flange turbine housing that fits the stock downpipe, which is the most restrictive part of the stock setup.
You'll see the most improvement here if you get a 16T or bigger, with a straight or angled flange hotside, and put a bigger exhaust on from turbo back to suit.
Stock injectors and fuel pump are actually fine for ~200 hp at the flywheel. They provide enough fuel to run AFRs of about 10-11 at 15psi on a 15G (with V cam and custom chips).
I put it on the dyno when I had it on lower boost (9psi) prior to having chips made, it showed AFRs of mid 9s at the top of the rev range, and made 155 hp at the wheels, estimated 195bhp at the flywheel. At 15psi I'd expect that to be up to about 180 at the wheels so easily above 200 at the flywheel.
Also if you put bigger injectors on without changing the map via chips (or another method), then it will just run rich and you'll lose power and fuel economy. It's rarely worth changing injectors unless you're running out of fuel, or you want a better spray pattern for the same flow rate.
With a slightly smaller turbo and stock cam, you'll see a slight reduction from those numbers I saw, but probably not that much. If you want to see 200 hp at the flywheel, a decent intercooler and less restrictive exhaust will help a lot more than just throwing a bigger turbo on with no other changes. I'd say worth getting an MBC and boost gauge first, then IC and exhaust, as you'll see more of an improvement. You could probably get a 16T on there at the same time as doing the exhaust if you want to see a bigger improvement all at once and save effort on the exhaust.
1997 940 RHD
215whp
Engine: B230FK - 16T at 12psi, 3" exhaust turbo back, V cam, wasted spark. Speeduino standalone ECU.
Suspension: GAZ adjustable dampers front, Bilstein B4 rear, -40mm lowering springs, polybushed in all the right places, lower chassis brace
Wheels: 17x9.5 ET0 rear, 17x8.5 ET-7 front
jf.xv is offline   Reply With Quote
Old 01-01-2021, 01:43 PM   #7
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
I made 184 at the wheels with a boost controller set to 13 psi, chips (made and sold by me!) and no other mods. Stock injectors are getting fairly well taxed after that.
Injector size is not a tuning tool. You'll need to remap the car to work with the injectors you have should you decide to change them.
I sell chips for LH 2.4!
Old 01-01-2021, 03:06 PM   #8
Pull the frame weights.
Old 01-01-2021, 06:37 PM   #9
PCH
Even with everything else 100% stock the high performance intercooler is gonna make you feel happier.
After that just add manual boost controller and go to 12psi (0.8bar).
Old 01-03-2021, 01:34 AM   #10
pathfinder
Thanks for reply
I think 200hp at flywheel is good enough. Need to up some power for enegetic long distance cruising on highways, which include hill climbing roads and need better power for overtaking. Never mind if power drop after 5500 rpm since it's not for racing. It should be good if can cruising steadily at 120 kmh- 160 kmh.
With 16T, do u think no problem with lag? mine is 4 speed auto. Laggy engine is not fun in city driving
About fuel pump and fuel pressure regulator, if maintain ori specs, can i use fuel pressure regulator ? or no need fuel pressure regulator if already have chips?
Any sample pictures of your front mount intercooler?
Old 01-03-2021, 03:08 AM   #11
PCH
Here is a good thread with info on the intercooler: https://www.turbobricks.com/forums/s...d.php?t=343520
Old 01-03-2021, 06:25 AM   #12
OttoB
Higher compression ratio helps with city driving. When I was replacing HG, the head was skimmed 1,5 mm. No bad side effects. Boost is 0,8 bar, wg actuator is from Subaru/Kinukawa.
Old 01-03-2021, 03:21 PM   #13
Janspeed
- the B230FK has an airbox with a restrictive intake orifice. It's easy to open up an extra orifice to match the ease of breathing to that of the HPT (B230FT) airbox. While you are doing that you might just as well remove the sound deadening foam that lines the inside of the airbox. That foam can cause problems if it comes lose and cloggs the airmass meter screen.
- all turbo engines benefit from a good easy flowing exhaust system. 2.5" or 3" with absorbtion mufflers instead of the stock baffled mufflers.
- the B230FK has an non-adjustable wastegate actuator. You can raise preload by adding some washers between the mounting bracket and the turbo to space the actuator away. This raises preload. But it's easier to install an adjustable WGA from a B230FT.
- the MBC is the easiest way to quickly raise boost and power.
Another trick to raise boost is to add a bleed-off-T in the WGA-hose. or maybe 2 of those or 3? Depends on how high you want to go. (the more air you bleed off the higher the boost will be but don't go over 12psi on a stock ECU)
Old 01-03-2021, 08:07 PM   #14
Fa182
Stage 1
Fa182's Avatar
Thanks for reply
Take it step by step.
Don't worry about the fuel system, you don't need to change anything in that system including the injectors with a 16T to start with.
It will be fine with a 16T.
My car is my daily driver and I'm very happy with the performance.
Obviously there is a bit of lag with the 16T, but it's perfectly fine for some spirited driving and overtaking when necessary. The upgraded intercooler did help a bit with the lag though as far as I remember when changing.
I usually use 3rd gear when overtaking from between 70-80, I have the manual M90 transmission though so I can't comment on the auto box.
My turbo doesn't even go into boost when cruising on a flat highway between 120 - 140, so it doesn't really matter what turbo you have installed.
Thanks for linking my thread, I almost forgot I made that one
Old 01-05-2021, 07:01 AM   #15
pathfinder
Thanks for reply
16T maybe fun with M90 manual gbox.
Last i test drive my friend FK with tuned ecu.Auto transmission. 15G turbo from 850-T5. This setup is good, got low rpm grunt until 5500rpm.
what intercooler u use?
Old 01-05-2021, 07:04 AM   #16
pathfinder
mean...FK low pressure turbo has higher compression ratio?
or bith FK and FT have same compression ratio?
Old 01-05-2021, 09:04 AM   #17
Lankku
Lankku's Avatar
FK and FT are same engines just with different boost.
242 DL -80 (was 4.6l)sold, 245 -88 "B6284T" sold, 245 -92 "B6284T",
245 -90
Old 01-05-2021, 01:08 PM   #18
Fa182
Stage 1
Fa182's Avatar
Thanks for reply
KL Racing, as written here: https://www.turbobricks.com/forums/s...d.php?t=343520
Old 01-06-2021, 03:59 AM   #19
pathfinder
Thanks for kind replies
Can anyone confirm, is it true the later model B230 FK and FT use forged pistons, rods and crankshaft ?
Old 01-06-2021, 06:01 AM   #20
OttoB
Crank is cast, rods are forged, piston high pressure cast.
All are good for over 400 hp.
Old 01-06-2021, 10:05 AM   #21
Bobo
Which years are concerned by the forged stuffs ?
Btw, I learnt a lot thanks to you guys
Bobo is offline   Reply With Quote
Old 01-06-2021, 11:34 AM   #22
Fa182
Stage 1
Fa182's Avatar
None as far as B230's go.
Some Penta AQ171 engines should have forged crankshafts and I've read the B234's could've had some as well, which would make sense since they're both 16v.
Only some of the B23ET's or FT's and most of the B21's came with forged crankshafts (and maybe) pistons, but not all as far as I'm aware.
This info is just from reading old topics on that subject.
Old 01-06-2021, 02:06 PM   #23
DavePolyakov
Remind me, how many pounds is that?
DavePolyakov is offline   Reply With Quote
Old 01-06-2021, 03:30 PM   #24
I think about 8 lbs each side. You pull the bumper, remove the four10mm nuts, and then fish the weight out with a coat hanger.
Some models have another weight on the firewall behind the dist. Some are internal to the cabin though.
Old 01-06-2021, 04:35 PM   #25
DavePolyakov
I think I'm going to do it, is there any noticeable difference in vibrations or not really?
