Old 10-04-2021, 02:36 PM   #151
Tfest
Hipsters ruin everything™
Tfest's Avatar
Originally Posted by corivus View Post
I look forward to seeing the updates, will they(hoonigan) put you on their channel? I enjoy a lot of the build stuff they put out. It must being so frustrating and exciting to have everything you need to finish it on the way. I'm hoping to have a similar completion date myself but mostly going solo with the help of a few tber's at random when they have the time.
No, most likely we'll just show up as an Instagram story, we're not going for the glory. It will just be nice to go on a road trip and show the car off to friends in LA.
Lifted 240 Build Pages
TB Build Thread
Instagram Page
Tfest is offline   Reply With Quote
Old 10-08-2021, 08:14 PM   #152
Tfest
Tfest's Avatar
Trans cooler behind the headlight? Yes. Why? Because I can.
Old 10-08-2021, 08:14 PM   #153
Tfest
Tfest's Avatar
Also sneak peak of the big boi radiator
Old 10-12-2021, 02:07 AM   #154
Hilding
It is biutifuller.
Very inspiration.
Hilding is offline   Reply With Quote
Old 10-12-2021, 11:12 AM   #155
Old Iron
I Roll
Old Iron's Avatar
Awesome build!!
Turbobricked
Originally Posted by Anonymous View Post
No sarcastic replies from Redwood Chair necessary
Old 10-17-2021, 11:34 AM   #156
Tfest
Tfest's Avatar
Made some progress.
Harnes is 90% connected
Engine is completely assembled
Fuel system is almost complete
Should be running by next weekend
How many burnouts till the Spartan locker turns to dust?
Old 10-17-2021, 11:48 AM   #157
cosbySweater
cosbySweater's Avatar
Originally Posted by Tfest View Post
Made some progress.
I'd be more worried about the axleshafts then the spartan
1995 Porsche 993
2013 VW Passat TDI
Old 10-17-2021, 12:11 PM   #158
Tfest
Tfest's Avatar
Same motor/trans was in a different 245 wagon with stock rear end, no problems. IF and WHEN we do pop the rear end an 8.8 is easy enough.
Old 10-17-2021, 12:37 PM   #159
cosbySweater
Was that 240 lifted on sticky all terrains as well?
Old 10-17-2021, 10:50 PM   #160
propav8r
F*ck Edgar
propav8r's Avatar
Those mounts must sit the engine up higher than my setup. I've got the same manifolds and steering shaft, and have clearance issues around right turns. It was great for transmission clearance though.
Originally Posted by leecatd8209 View Post
I don't even know Scotty D, is he like Weldy?
nipple farts
Originally Posted by VB242 View Post
Space time farts
My Project
K-Jet to Megasquirt Article
Old 10-18-2021, 07:50 PM   #161
Hathos+
I own 2 cars now
Hathos+'s Avatar
Since i gave input on that steering column shaft does that mean I helped with this build?
Taro is never wrong.
Hathos+ is offline   Reply With Quote
Old 10-21-2021, 08:35 PM   #162
Tfest
Tfest's Avatar
SHUSH
we should be good but we'll see... Undercarrage clearance is perfect at least, nothing hangs below the crossmembers.
Well duh, you get to drive it too.
Old 10-21-2021, 08:35 PM   #163
Tfest
Tfest's Avatar
Looks like we might be starting it this weekend...
mmmm rad
Old 10-26-2021, 06:16 PM   #164
Tfest
Tfest's Avatar
Update from last weekend.
trans cooler mounted and plumbed
half the wiring completed
driveline installed
radiator shroud made
radiator mounts completed
Old 10-26-2021, 06:18 PM   #165
Tfest
Tfest's Avatar
Gotta...
complete wiring
make volvo shifty work with 4l60 shifty
plumb radiator
get exhaust
do big burnout
turn spartan to dust
replace with truetrack
Old 10-26-2021, 06:20 PM   #166
cosbySweater
drill some holes in the tstat and get a coolant bypass for the heater control valve if you are planning on using it.
i used a gm bypass in mine but these work well too
https://www.lojkits.com/collections/...r-bypass-block
the 240s suck for heat in the engine bay so these two things help the ls engines stay nice and cool, if you use just the stock heater control valve it will block coolant flow and cause cavitation in the pump and it will hover heat.
Old 10-26-2021, 06:33 PM   #167
Tfest
Tfest's Avatar
Interesting, I've seen this come up before but the previous owner of this motor didn't mention this. The 5.3 we have was also in a 245. Waiting on verification and will purchase this if need be. THANK YOU for being helpful, I love this forum for that reason.
Old 10-30-2021, 10:59 PM   #168
Tfest
Tfest's Avatar
It runs
https://youtu.be/PrvYiTSdNc8
Old 10-31-2021, 11:32 PM   #169
Tfest
Tfest's Avatar
Shifter linkage made
Old 11-01-2021, 06:25 PM   #170
Tfest
Tfest's Avatar
The fact that we're using the STOCK shifter really tickles my taint.
Old 11-01-2021, 10:33 PM   #171
Radtap
Radtap's Avatar
So when do we get to watch you jump it?
Radtap is offline   Reply With Quote
Old 11-01-2021, 11:15 PM   #172
Tfest
Tfest's Avatar
Soon
Old 11-04-2021, 02:59 PM   #173
Tfest
Tfest's Avatar
Still runs. Finished the wiring harness and ran the new power steering hoses.
Exhaust goes on next week.
Then we take it to a local tuner to dial everything in.
I'm expecting a very modest 330hp
Not bad for a $13,000 build.
Old 11-06-2021, 08:39 PM   #174
Jerd
Jerd's Avatar
Excellent! This being turbobricks I sorta half expected you to loose steam right towards the end of the install and decide to part the entire thing out and sell the shell for scrap.
Glad you keep making steady progress. Need more pictures.
Old 11-06-2021, 08:48 PM   #175
Tfest
Tfest's Avatar
Thanks man. It's basically done at this point. Going to start working on the Mercedes this spring. I'll take more pics and do a final pic dump soon.
