Old 05-12-2021, 07:53 PM   #26
Carnage
Very cool build
Carnage is offline   Reply With Quote
Old 05-12-2021, 08:21 PM   #27
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
Adam - I have a couple gears I pulled from junk J types at Skyview - different colors are different gear ratios. Let me know if you want me to send them to try. Red was from early coarse spline M46, black from from later fine spline M46
Originally Posted by spock345 View Post
The last year for the M41 was '75. It would be an M46 in 1976 onward.
OK - faulty memory. It was the obvious coarse spline vs fine spline on the input shafts, switch from cast iron to aluminum cases then....
Old 05-13-2021, 02:28 AM   #28
adamdrives
Thanks guys, appreciate the love. Once the windshield is ready to go in I'll get her properly detailed and she should really look great.
Cool, I will pull current gear and see what it looks like. Trans donor car was an 80 I believe, maybe that's when it switched to fine tooth? Would make sense, because my speedo reads too high. Are the gears interchangeable?
Feedback thread
78 242 DL m46 swapped
83 245T npr ic, ipd cam, 15g, SS 2.5" exhaust, race cat
05 S60R m66
adamdrives is offline   Reply With Quote
Old 05-13-2021, 08:36 AM   #29
lookforjoe
lookforjoe's Avatar
The gears are interchangeable. They are tied to the ratio of the FD - and the speedo head is designed to match that - I think the old gauges have a number on the face of them - does yours? It doesn't really matter in terms of figuring out which one is correct unless you can access the old catalogs that list the gears by ratio
EDIT: this thread has info on the gears/ratios http://forums.turbobricks.com/showth...57#post6179557
Old 05-13-2021, 09:26 AM   #30
adamdrives
Sounds like I need to know the FD of the donor car to get the right gear. It was an 80 non turbo wagon. Wish I would have grabbed the cluster from it too.
My cluster is a 980. Not sure on rear axle.
edit: drank some coffee and it sounds like I just need to match my rear axle to the correct gear, right? Cluster is just for correction in tire size from wagon/sedan.
Old 05-29-2021, 10:44 PM   #31
adamdrives
Located the correct speedo gear thanks to lookforjoe (thanks dad), now just need a chance to install it. I've been busy with my 245t 15g swap and hammering out some gremlins. Beginning to consider swapping to efi to simplify and improve.
I'm not sure if I've mentioned it but the blower motor stopped working once I got the dash buttoned up. I tested it while I had the center stack out to verify wiring and it was good, but somethings not right now. I think I may have pulled a wire from the AC switch while I was tugging connectors into place. Once I have speedo I'll focus on that. I've been putting it off because I can't stand that center console and the messy wiring.
I ordered the correct windshield trim, now just need the glass guy to come around so he can remove the old glass, hopefully not break it, and install new clips. I'm debating ordering new glass myself from VP, but with shipping its about the same as letting him order it, and if I end up not needing it, I wont be on the hook for $250.
Old 06-19-2021, 08:16 PM   #32
adamdrives
Ended up getting the right speedo gear, only to still have speedo off. Looks like my car is supposed to have 195/70s (sedan/coupe?) on it, and it has 185/70s (wagon?). That would explain the speedo reading too high. At 67 actual speed, it reads 80.
Old 06-21-2021, 07:42 PM   #33
2turbotoys
Salaminizer
2turbotoys's Avatar
That is way too much difference to blame on the tires. Tires would cause 2-3 mph off, not 13 mph. Try the calculator link:
https://tiresize.com/speedometer-calibration/
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 06-22-2021, 03:30 PM   #34
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Wonder if the '80 donor had an OD unit from a 1983-85 non-turbo 240 on it. On those, the worm gear on the shaft is different. For the 3.31 rear axle, it uses the black speedo gear normally used in 3.91 rear axle cars. A red 3.73 gear would wind up being a 3.15 ratio, and a blue 3.54 gear would wind up being a 3.07...
1982 242Ti - black, M46. 1985 245Ti - blue, M46 - soon to be for sale.
@john242ti on IG
Old 06-30-2021, 09:02 PM   #35
adamdrives
Thats exactly the case. I took apart a spare OD unit and compared it to the drive from the original BW and they are not the same. I think all I need is the original speedo drive, which I can get, and all will be well.
Old 06-30-2021, 09:04 PM   #36
adamdrives
Yep, took a day or two to sink in that a few mms difference would not cause a 20% difference
Old 10-03-2021, 02:41 PM   #37
adamdrives
Hey John, thanks for chiming in on IG. This project is on the back burner but I want to get this speedo ordeal wrapped up. can you confirm which years m46 has the worm drive i'm looking for? Is it any year turbo, diesel, or 82-83 box that has the correct gear?
Old 10-04-2021, 03:35 PM   #38
John242Ti
John242Ti's Avatar
Adam,
No problem. 1976-82 non-turbo gas, all 240 Turbo, and all 240/260 Diesel.
Old 11-18-2021, 12:06 AM   #39
adamdrives
Been a long time since I gave an update here, just brushed off the dust and drove her home today from the shop. The dynamat definitely helped with tire and road noise but the motor is still very noisy in the cabin, I need to do the underside of the hood and maybe the firewall. Still a nice, smooth cruiser on the highway on the untouched suspension. OD works perfectly after the swap.
I was going to swap to modern a/c, but for now I'm just going to get the York working. I really had enough of dealing with wiring when I did the blower motor.
Did the front seals and fuel pumps, but she's still groaning. May try to add a fuel damper in the future.
Still need to deal with the driver seat foam and skin, and the rear backrest.
My glass guy has gone totally MIA, so I'm also going to have to figure out a solution for the windshield trim. I may try to DIY it so I can keep the original glass and trim and just replace the clips.
Old 11-18-2021, 11:52 AM   #40
propav8r
F*ck Edgar
propav8r's Avatar
That thing looks mint. Nice job.
Originally Posted by leecatd8209 View Post
I don't even know Scotty D, is he like Weldy?
nipple farts
Originally Posted by VB242 View Post
Space time farts
My Project
K-Jet to Megasquirt Article
Old 11-18-2021, 01:08 PM   #41
More pics requested.
Old 11-18-2021, 10:47 PM   #42
adamdrives
I'm going to polish it tomorrow or the weekend so I'll get some pics for sure
Old 11-19-2021, 02:57 PM   #43
89-240gl+t
And a frontend refresh, going to look brand new once we’re done with it!
'84 242 Turbo
Rebuilt 93 B230FT block, KL Racing T3 Cam, Dual Valve Springs, 38/46 Valves, Ported, ARP Head Studs, T5WC, MSII-Extra, EDIS, Nathan Exhaust Manifold, Ebay Turbo , 90lb injectors, Full E85, 3" exhaust, Kaplhenke Coilovers Front/Rear Koni Race Single Adjustable’s, RX7 Brakes, IPD 25/25 sways
‘89 244 6.0
89-240gl+t is offline   Reply With Quote
Old 11-19-2021, 11:48 PM   #44
adamdrives
Interior is next, I'm thinking black carpet.
Old 11-20-2021, 09:32 AM   #45
lookforjoe
lookforjoe's Avatar
I have an original bagged windshield trim clip kit, I don't know if it works with pre 80's trim though
Old 11-21-2021, 01:54 AM   #46
John242Ti
John242Ti's Avatar
^Should. Adam's car looks to have the 1978-85 style trim on it.
Old 11-21-2021, 12:56 PM   #47
adomz
Volvo 486 owner :D
adomz's Avatar
That's a great little car! Great work!
Adam
Errr.... 242... No engine no cringdingding...
=->Adam's youtube channel<-=
adomz is offline   Reply With Quote
Old 11-21-2021, 03:14 PM   #48
adamdrives
Did some detailing on Saturday...
Yuck, going to try to find new gaskets here.
Hard to shoot in this light, but there was a lot of discoloration like this on the car
It's hard to tell how nicely the roof and hood came out. After clay and polish the paint was really, really smooth.
The front end is currently under the expert care of 89-240gl+t for refinishing
Old 11-21-2021, 03:47 PM   #49
89-240gl+t
So impressive how well single stage paint comes back to life with some light polishing. Photos don't do it justice with how well the paint came out!
