Old 11-03-2021, 10:34 PM   #401
HiSPL
Fanking Champion 1993
HiSPL's Avatar
Originally Posted by Swedbrick View Post
For that price I'd think they would include a control system.
Still looks like a neat package.
Beets taste like buttfeet.
Originally Posted by Lando
Tinnitus and hearing loss? Sounds like your ears could tolerate some Bose 901s!
88 244
06 XC90 V8
03 V70
Old 11-04-2021, 10:52 AM   #402
cwdodson88
https://cascadiamotion.com/productli...les/42-idm-190
I think that these are coming in at around 7k. Solid build. They're kinda fun. They run a wavetrac LSD standard 8.3:1 and 11,000 rpm limit (voltage dependent), have full integrated motor and controller cooling pump, just add you own radiator and axles. Then all you need is DC source/BMS/Charging and you can run it. Talks over CAN in case you want to get fancy with a dash/vcu setup.
The Build Thread
SVEA - PUSHROD TURBO!
Old 11-04-2021, 11:05 AM   #403
culberro
culberro's Avatar
$7k is very reasonable for that setup, is the transaxle sourced from an OEM vehicle or your own (BW?) design?
Most important question: where’s the rwd version?!
Old 11-04-2021, 11:13 AM   #404
+11111
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 11-04-2021, 11:29 AM   #405
JohnMc
JohnMc's Avatar
Mount it lengthways and make it AWD.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 11-04-2021, 11:31 AM   #406
You could just mount it in the back and use a De Dion axle
Old 11-04-2021, 12:07 PM   #407
culberro
culberro's Avatar
That's it, I'm selling my Volvo and getting an Alfa!
Old 11-04-2021, 12:31 PM   #408
culberro
culberro's Avatar
Originally Posted by blkaplan View Post
+11111
Seems like the iM series is what a rwd vehicle would use.
https://cascadiamotion.com/integrated
So what's the cost on the different levels of iM packages?
Old 11-04-2021, 03:47 PM   #409
cwdodson88
like stick axle?
Its a BW design that has been modified to suit the aftermarket and OEM alike. 430nm of tq at the motor, and all in at like 260#s. That whole unit is small enough to fit in the back of just about anything. Take a Honda s2k rear subframe and cut out the diff, and swap in the tip of the gearbox.
The gearset is the same as the BW 31-03 gearbox. So there are several ratios available from like 5-10:1.
The iM series is basically as universal as it gets its an integrated motor and inverter/control module. Porsche bellhousing bolt pattern, and the BW e series gearbox mounting. There is an off the shelf Transverse gearbox option that looks like an autotragic, but its a single speed with low reductions (2-3:1) and then theres an offset billet box thats 2.6:1 and would mate to a t-case or direct to diff... We have done a few Ford 9" IRS prototypes and it looks like we might have something like that in the catalog by this time next year.
Old 11-04-2021, 03:49 PM   #410
cwdodson88
That'd be a good question for Sales. Its not much between the iM-0225 and the iM-0375, but going to the iM-0425 is a huge jump...
Old 11-04-2021, 03:51 PM   #411
cwdodson88
just buy two.
Old 11-04-2021, 05:08 PM   #412
culberro
culberro's Avatar
Originally Posted by cwdodson88 View Post
like stick axle?
Yes. I'd like to ev my horse drawn carriage good sir
Old 11-04-2021, 10:26 PM   #413
cwdodson88
There is a longitudinal option. It’s a 2.68:1, so second gear ish that would pair well with a 3.73, that and 400+nm should get a brick moving. Speed limited-ish, but 11k, 2.68:1, 3.73;1, 26” tire… top speed wouldn’t be slow.
Old 11-04-2021, 11:30 PM   #414
gross polluter
They see me trollin'
gross polluter's Avatar
Looking over that gave me a really bad idea of dumping the 2JZ out of the rustang and putting two of these in there instead.
1981 Piper Cherokee Archer II | Garmin GTN 750 | Ly-Con O-360
Old 11-05-2021, 10:16 AM   #415
cwdodson88
Its looking like our battery modules are suffering from the semiconductor shortage.. BMS fixings and such have affected timelines for full release.
But, I put together a BOM for a modified Tesla model 3 pack ~75KWH that comes in just under 12k with charging, cooling, heating, BMS and the connection bits.
Depending on how the next year moves, you might see a pretty ok decrease in price on all things EV.
Old 11-05-2021, 12:19 PM   #416
12k including that battery pack?
What kind of range would that be on something like a 240?
Old 11-05-2021, 01:02 PM   #417
JohnMc
JohnMc's Avatar
$12K for a battery pack plus $9k for a motor/controller, if I'm reading that right.
Old 11-05-2021, 04:17 PM   #418
cwdodson88
Somewhere in around 200. Figuring the typical miles/kWh at 3mi/kWh with some reserve for capacity depletion over time. And throw a +/- 15-20mi in either direction based on terrain and aero.
And yeah, 12k would be pack only.
Old 11-05-2021, 05:21 PM   #419
Swedbrick
Swedbrick's Avatar
It's a shame hydrogen fuel cells are not really commercial yet, the battery investment is a big hurdle for the average hobbyist. Although given the platina in those, they'd probably be similarly priced per kg as a catalytic converter
Volvo 745 - Turbo, LH2.4, M90 swap, IPD springs, 25mm/19mm swaybars, 3.54 \w racingdiff lsd, track/daily
Old 11-05-2021, 06:41 PM   #420
So looking at 21k or so for a battery pack + motor.
If you had to guess,,, whats the best and worse case scenario for price reductions next year?
Old 11-06-2021, 11:56 AM   #421
cwdodson88
Best case 10% reduction, worst case, another 15-30% increase in tariffs coming out to 10-15% increase in consumer costs.
But with the used market for batteries growing, the pack costs should be declining pretty rapidly.
