Old 07-07-2021, 05:15 PM   #1
petercz
Default My ´97 940 Turbo M90 IRS aka Fart Express
So this is my 940 I bought it in 2014 with 385t km (now 501t km) from Netherlands. Started as a casual 940 with b230fk + m90.
https://petercz.rajce.idnes.cz/940/
Engine:
stock unopened b230fk
Vialle LPi
3" downpipe + 2,5" Simons catback
16t + Kinugawa wg actuator and dual stage boost control
Buchka wasted spark ignition
intake manifold spacers
do88 intercooler
3" maf
440cc injectors
BTI chips
Transmission:
M90 (with welded stop ring)
dogdish flywheel
Sachs -763 pp + diesel clutch disc resurfaced with Frenos HDS57 material
Suspension:
Bilstein HD all around
front Lesjofors lowering springs, rear Eibach 1300-500-0250
front dual swaybars
3.31 1041 rear axle
rear multilink mk1 irs with 3.31 G80
PU bushings here and there
25mm wheel spacers with variety of et43 wheels
strut brace
960 subframe braces
adjustable panhard rod
302mm front brakes
Interior:
960II seats and pillar trims and some other 960 goodies
Reveltronics UTCOMP board computer (AFR, EGT, coolant and oil temp, oil pressure, MAP etc...)
petercz is offline   Reply With Quote
Old 07-07-2021, 05:21 PM   #2
petercz
And some pictures overload
File Type: jpg 36464041_1996082793735055_8832326852375740416_n.jpg (73.8 KB, 406 views)
Old 07-07-2021, 05:28 PM   #3
petercz
Old 07-07-2021, 05:33 PM   #4
petercz
Old 07-07-2021, 05:39 PM   #5
petercz
Trans and clutch
Old 07-07-2021, 05:44 PM   #6
petercz
I think that's enough for today
Old 07-08-2021, 07:34 AM   #7
Swedbrick
Swedbrick's Avatar
Nice strut brace, who sells those? That boost setup looks pretty complicated, are you using both electronic and mechanical control?
Volvo 745 - Turbo, LH2.4, M90 swap, IPD springs, 25mm/19mm swaybars, 3.54 \w racingdiff lsd, track/daily
Old 07-08-2021, 09:16 AM   #8
petercz
Thanks, the strut brace is made by me
The boost control is pretty simple - one mbc for low boost and one for high boost and using the tcv as 2-way valve, I can switch between them.
Old 07-11-2021, 12:08 PM   #9
Swedbrick
Swedbrick's Avatar
Nice, neat fabrication job! The tcv setup is pretty smart, I might have to copy that at some point
Old 07-11-2021, 03:12 PM   #10
Volvo_Utrecht
945´s City of Utrecht
Cool display that shows the sensor data. How did you do that?
Volvo_Utrecht is offline   Reply With Quote
Old 07-11-2021, 04:03 PM   #11
petercz
Reveltronics UTCOMP-Pro + my custom 3D printed case
https://www.rajce.idnes.cz/f1465122616
https://www.rajce.idnes.cz/f1465122627
Old 07-21-2021, 01:25 PM   #12
moise
moise's Avatar
very good setup!
moise is offline   Reply With Quote
Old 10-04-2021, 07:32 AM   #13
petercz
Multilink mk1 irs swap in progress
Old 10-18-2021, 06:34 AM   #14
petercz
Suspension, brakes and fuel tank on, now I need to modify the exhaust and it´s done
Old 10-19-2021, 02:08 AM   #15
moise
moise's Avatar
is it autoblock?
Old 10-19-2021, 06:39 AM   #16
petercz
What is autoblock?
Old 10-19-2021, 07:44 AM   #17
moise
moise's Avatar
Originally Posted by petercz View Post
What is autoblock?
locking differencial
Old 10-19-2021, 09:41 AM   #18
petercz
It is and I swapped in 3.31 gear set like I had in the old axle
Old 11-06-2021, 02:15 PM   #19
petercz
Everything done, the rear, with Eibach 13" 250lb/in springs, is about 1.3" higher than front, but I think I´ll live with it for now.
Old 11-23-2021, 06:35 PM   #20
940 16 valve
940 16 valve's Avatar
Nice work! Where did you get the poly bushing for the upper control arm?
1991 940 - stock b234+t -retired http://forums.turbobricks.com/showthread.php?t=243308
1989 760 - T5 (B5254T2 with a 6 speed!) http://forums.turbobricks.com/showthread.php?t=341191
940 16 valve is offline   Reply With Quote
Old 11-24-2021, 07:16 AM   #21
petercz
Thanks These bushings are from volvofan.eu or you can get set for whole axle from poliprodest.com
Old 11-24-2021, 10:17 PM   #22
My car is fun hp club
Nice touch on the rear trunk with the single volvo letters.
