Old 08-23-2021, 02:21 PM   #76
JohnMc
JohnMc's Avatar
I'd use that on an ongoing basis, but I'd add a bottle of that ZDDP additive on the initial startup.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 08-23-2021, 02:22 PM   #77
intothelabyrinth
intothelabyrinth's Avatar
Sounds good, thanks. I should be putting it all back together in the coming couple weeks.
1986 245 Auto (RIP)
1986 245 Auto (RIP)
1988 245, M47
1989 245 Auto California Car (sold)
1993 245 Classic (Bro's Daily)
1988 245 (turbo manual swapped)
1990 245 (getting turbo manual swapped)
1991 245se (rat rod project, turbo aw71 swap)
1969 164 (trying to make it run)
Instagram
intothelabyrinth is offline   Reply With Quote
Old 08-24-2021, 10:05 AM   #78
cwdodson88
+1
Just keep them lifters happy.
The Build Thread
SVEA - PUSHROD TURBO!
Old 09-09-2021, 02:23 PM   #79
intothelabyrinth
I have cleaned up the gasket surfaces, and installed the cam, timing gears, and lifters. All the lifters move freely and spin. Just waiting on the head to get back from the machine shop before I slap it the rest of the way together. I actually was able to get oil to pump up by turning the oil pump by hand with a screwdriver. It started spraying out of the timing gear oiler, and pumped up to the oil galley that supplies the head. Felt pretty good about that. I test fitted the oil pump/ distributor drive gear, and distributor but didn't fully bolt them back on because I will prime the oil system before I fire it up the first time.
Old 11-15-2021, 03:10 PM   #80
intothelabyrinth
I put the head back on and have now traveled about 150 miles... I need to go thorough and inspect/set up the carbs and check my timing advance, but the car is running and driving, and it appears the bottom end was not worn out completely yet. I'm thinking I may be running a little lean at idle, and my idle speed may be a little low. She goes down the highway great, but idles a little rough at times. I had to take off the power steering belt because my pump sounds like it has marbles in it. Anybody have any links to rebuild instructions for the zf pump that came in a 1969 164?
1969 Volvo 164 rides again
