Old 09-24-2021, 01:35 PM   #26
Originally Posted by gsellstr View Post
Damn Harald, I did better on that in the the 140. Granted 4.1's and W50 at the time, with a TRASHED clutch that couldn't launch over 2k without slipping, but still...
Originally Posted by klr142 View Post
It’s a 16V NA race camshaft with turbo problem. Ok, maybe not, but maybe.
In the past I think the best I've seen was a 2.0 but it usually was more in the 2.1-2.4 range.
It's a combination of a skinny tire, and gearing that is too tall for the torque curve of the engine. You either bog or spin the tires through 45 mph with very little in between.
Old 09-24-2021, 03:07 PM   #27
qwkswede
faster than you think
On yes, you have it right. I fully condone Gary's heckling. But 16V Volvos are like a Honda with no V-TEC. There was a reason the cars came with a lower first gear in the transmission and 4.10s in the rear axle.
It's quite awful actually. I currently have 2 cars to drive side by side. My 16V turbo wagon, and an 8v turbo wagon with a 16T turbo. In some circles they might call that a "big" turbo. The 8v Volvo leaves stop lights like a normal car, and makes decent boost in first gear. The 16V car really needs a push to get across the intersection, and then you need to hold on for the jump to light speed.
It seems a bit hazardous to start spraying nitrous at 1700rpm in the staging lights holding the brakes and throttle wide open, but really it's the only thing I have seen that can overcome the complete lack of torque below 4000rpm.
And one more thing. The effective altitude at the track on Wednesday was 7200' above sea level. That really creates a lag problem
Old 09-24-2021, 04:11 PM   #28
gsellstr
gsellstr's Avatar
I've been able to stage my wagon down to a 2.0, with a little more on the table if they prepped the track down here. For reference, I can leave at around 5-6psi on warmed slicks here and I end up spinning thru the lights. PIR, I was launching at 9 on street tires and it hooked from the box.
RIP
Nick Fengler "fengler" 8/6/18
Bob Davi "bob davi" 10/2021
74 144 B20
90 745Ti
Old 09-24-2021, 04:22 PM   #29
My car is fun hp club
Both drag strips that I used to go to in NJ are closed and done. No east coast numbers from anyone in NJ.
Edit:OK it does look like there are days where ATCO is open. But all the major events are canceled.
Old 09-24-2021, 04:46 PM   #30
qwkswede
No event needed, Test n Tune hot laps are the best! Do it! Dooo IIIIT!
Old 09-24-2021, 04:48 PM   #31
qwkswede
Interesting Gsellstr. Your wagon gets down!
I just looked back at a couple past EvW threads and there are alot of sub 2.0 60' times from cars running in the 12s and 13s. I might need to find a bigger N2O jet.
Old 09-24-2021, 05:28 PM   #32
Doesn't seem like they prep PIR anymore. I get more off the line traction on the street...
Old 10-05-2021, 07:16 AM   #33
VupVups
VupVups's Avatar
I just registered, I wanted to know if it's still on this year, won't it be cancelled like in 2020? Because the situation is not the best(
VupVups is offline   Reply With Quote
Old 10-05-2021, 07:41 AM   #34
poulrais
poulrais's Avatar
RogerDee might have the time to hit the dragstrip before it closes for winter. He waited forever to get a set of head studs for his LS.
For me it'll be next spring if all goes well.
1990, Volvo 740 16v +T
poulrais is online now   Reply With Quote
Old 10-05-2021, 09:40 AM   #35
qwkswede
What did you register for? Did you go drag racing? Post your timeslip in this thread if you have one.
Old 10-05-2021, 09:42 AM   #36
qwkswede
Good luck gents. Can we hope to see some sweet LS powered single digit time slips maybe?
Old 10-06-2021, 03:50 AM   #37
VupVups
VupVups's Avatar
I haven't been interested in it that long, I want to go to cool competitions in real life, and all I've seen before is records. I've never raced myself. In fact, I'm a sucker for it. But I'm trying to figure it out.) I have a question, do the drag racer use electrical cars? And not too long ago I found some interesting accessories, adapters for all sorts of chargers. Do you use them? Just curious. I'm talking about things like https://evadept.com/best-extension-cord-for-ev-charger/. Very curious...
Old 10-07-2021, 12:07 PM   #38
qwkswede
The drag strip closes mid October in Denver Colorado. I wanted to squeeze in one more night before things shut down for winter. I really wanted a 12 second timeslip after being so close last month. And so I turned the boost up to an even 20psi and I did a little bit of tuning on the fuel and spark maps to make sure the power increased with the new higher boost. The motor seemed really happy, hopefully the AW71 would take it. I also made sure the nitrous bottle was filled and ready for spooling the turbo on the starting line. I'm still running about 35-40hp shot from the wet kit. The car leaves with some authority on the bottle. Much better than my 3 second 60' times without nitrous.
And SuperFridge did not let me down.
Best pass was a 12.33 @ 114mph
It was super busy at the track last night. All 8 lanes full with about 30 cars each. I waited 2 hours to get my first pass done. The pressure was on. With a couple more practice runs I'm sure I could cut a better 60'. I accidentally pushed through the start lights while trying to power brake the car both times. Something to work on next season. Could I even run an 11 with that 114mph trap speed? Maybe maybe....
Timeslips attached.
Old 10-07-2021, 03:01 PM   #39
klr142
Turbo, what?
klr142's Avatar
w000! And damn, that’s busy! I haven’t been to the local drags in a good while but I haven’t seen them THAT busy in 10 years or so. Good work!
Old 10-17-2021, 10:29 PM   #40
propav8r
F*ck Edgar
propav8r's Avatar
I'm the right lane.
'79 244 with a cam only 5.3, T56, 8.8 with 3.73 gears.
The car could do much better, but unless I get down to MMP later this year I won't be running anymore. This was the last night Commerce was open. They're tearing it down for condos.
Originally Posted by leecatd8209 View Post
I don't even know Scotty D, is he like Weldy?
nipple farts
Originally Posted by VB242 View Post
Space time farts
My Project
K-Jet to Megasquirt Article
Old 10-18-2021, 01:44 AM   #41
qwkswede
Awww maan! Not condos...
I'll get ya logged. That looks like a really fun reliable Chevolvo combo....
Originally Posted by propav8r View Post
I'm the right lane.
