Old 11-08-2021, 02:12 AM   #26
Arn02
Arn02's Avatar
Nice work. V8, it just makes sense does it not?
Ambitious but rubbish.
The 245 GT
The Euromurican
Arn02 is offline   Reply With Quote
Old 11-08-2021, 07:53 PM   #27
corivus
Hey Shiny!!
corivus's Avatar
it fits so perfectly, and so much more of an aftermarket for performance upgrades at better price points.
corivus is online now   Reply With Quote
Old 11-09-2021, 02:18 PM   #28
Tfest
Hipsters ruin everything™
Tfest's Avatar
Agreed, reliable 300+hp with better MPG at a better cost? No brainer.
Why did you not go with a standalone harness? Our harness from BP was plug and play. It's one of the main reasons our V8 swap only took 30 days.
https://www.bp-automotive.com/
Lifted 240 Build Pages
TB Build Thread
Instagram Page
Tfest is offline   Reply With Quote
Old 11-09-2021, 07:51 PM   #29
corivus
Hey Shiny!!
corivus's Avatar
Because I am a glutton for punishment and I can say I did it all if I make my own stand alone, honestly though I should just grab the BP one. seems everyone is going with that for ease of use.
Old 11-09-2021, 07:56 PM   #30
Tfest
Tfest's Avatar
It is an honorable challenge to take this on yourself. You'll know a hell of a lot more about your electrical system than I ever will.
Old 11-09-2021, 07:59 PM   #31
corivus
Hey Shiny!!
corivus's Avatar
hah thanks and thats one way to say it! honestly I am just as tempted as I was when first taking on making a new harness to use the bp one.
edit: to add just shot them an email to see if they had a harness that also includes a/c, I'm going to make a fuse setup for that as well as a/c is a must in az for a DD
Old 11-10-2021, 08:27 PM   #32
cosbySweater
cosbySweater's Avatar
terminator x is the answer, so much better then a stock ecu, gives you alot more room to grow once you get bored of the stock power level
1995 Porsche 993
2013 VW Passat TDI
Old 11-11-2021, 10:23 AM   #33
corivus
Hey Shiny!!
corivus's Avatar
Sadly backorders from April with Holley are still not filled and the current fulfillment date has changed from 11/19 to 12/30... correction apparently its tbd now. Otherwise I'd have had a Holley unit back in September.
edit: i will be using them next year for another project because part of me just wants to be all motor so I can retain a/c.
Old 11-26-2021, 05:36 PM   #34
corivus
Hey Shiny!!
corivus's Avatar
Quick update, mostly playing with wiring right now, waiting on hoses to come so I can start making my radiator lines. Of course the holiday's are delaying that, but I'm hoping to do the first test start this year, if not its not a huge deal. The Current DD I have is pretty comfy and the wife keeps jokingly asking if I'm gonna sell the 740SE (the answer is always no). Its a NA 00 V70 manual that's been fully optioned out, if it was turbo I'd be keeping this long term.
Also I can't find my n/a upper and lower radiator mounts so I just used the old turbo ones, everything clears which is nice but damn I want it to look cleaner now. who cares that I'm just going to be pulling the harness after I do a test start to sheath everything.
Nearly finished up the harness just gotta run switched power to the connectors to the a/c compressor and also make a connector for 12v+ signal request from the Volvo ECC to the GM ECM at pin 17.
Also I wanted to be able to place the tach module further away from the exhaust, this required extending the harness but once that was completed I mounted the tach module where the battery used to sit. I reused the volvo grommet for the gm dbw harness while extending it and it fits real nicely. I will still probably just go get a proper grommet from the hardware store so I have something that sits in night and snug. this one is a little loose and I don't want to have any engine noise in the cabin like my red 740 did.
And started planning on routing my wires since I wanted them to tuck a bit more once covered. So far its a lesson in patience but I've already had to undo some of the loom to make things exit in different places to get the harness as a whole to tuck around the engine neatly. On a side note is there any sort of extra shielding I should do near certain places on the harness?
