Old 10-24-2021, 02:08 PM   #26
adamdrives
What size tires are you running and what grade of gas?
Not that those factors would explain such terrible mileage but they might help a little bit.
205/55 nokians and chevron 91
Originally Posted by dl242gt View Post
I only get about 16mpg with my car. It's too much fun to get good mileage with. 70mph is turning over 3k rpms on the highway and with these cars the mileage drops fast over 3k rpms at steady cruise.
The car doesn't feel like it wants to be cruising at 2500 or so, feels boggy, even before the cam. It feels clearer above 3k so that's just where I usually end up driving it. There is a spot around 27-800 that feels okay, but it doesn't feel like it really has enough power to be there and change speed though. Ok if theres nobody around and no hills.
Originally Posted by lookforjoe View Post
That's what I get with the 745, similar round trip & road speed. Only time it delivered "good" MPG's was on the longer drives - to the airports, etc.
Even all highway, minimal ripping the best I ever got was 15.5.
Feedback thread
78 242 DL m46 swapped
83 245T npr ic, ipd cam, 15g, SS 2.5" exhaust, race cat
05 S60R m66
adamdrives is offline   Reply With Quote
Old 10-24-2021, 02:15 PM   #27
Best case you're wasting your money with 7:5-1 compression running 91, worst case you're using a little bit more fuel and wasting your money anyway.
how psi stock cna sprout?
Old 10-24-2021, 06:16 PM   #28
adamdrives
you think running 87 I wont run into knock issues? I'm running 14 psi and its hard to keep it out of boost.
Old 10-26-2021, 12:53 PM   #29
An occasional ~5 psi max does everything I need to do.
Not trying to break the World Land Speed Record here....
Old 10-26-2021, 01:14 PM   #30
I remember you driving at an extremely leisurely pace when I visited ~10 years ago.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 10-26-2021, 01:41 PM   #31
Ya we never left the city streets so that's a given.
Old 11-04-2021, 12:00 PM   #32
adamdrives
Very good news! Solved my low power/sluggish responsiveness issue last night by setting base idle and correctly wiring the TPS with help from Lookforjoe. Can't believe how much of a difference it made. I think since I got the car wrecked and replaced the harness right away I may have never had the throttle switch wired correctly, because it always felt choked. Finally feels like it wants to go, pulls hard, cruises in vacuum with only light throttle inputs needed, I'm sure it's going to go more miles on a tank. I can finally feels my mods.
Relay setup for lh tps on k-jet conversion is very simple: yellow tps wire goes to pin 30, then ground 87a to manifold. Pin 86 gets switched power, 85 goes to pin 1 on tps. Now when you open the throttle, instead of yellow wire circuit opening, the relay grounds it, and you have proper iac/k-jet control. This is necessary because the k jet switch is open when the throttle is closed, and the lh switch is open when the throttle is open.
Note: its a bit of a chore to set base idle with the lh tps. Hard to explain, but I found it easier to start with throttle open more than it needed to be, then back off off idle screw so that I wouldn't lose my tps setting. It's much simpler to adjust the original switch.
edit: also thanks to John, who suggested I set base idle in the first place!
Old 11-07-2021, 12:39 PM   #33
My car is fun hp club
Glad you got that sorted out. Enjoy the boost. Boost is more fun than getting good mileage.
Old 11-07-2021, 02:44 PM   #34
adamdrives
True, but I also like to know everything is working right. That and not having to floor it in 4th to maintain speed up hills.
Old 11-07-2021, 03:22 PM   #35
Restore it to socks.
Old 11-08-2021, 04:24 PM   #36
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Well, it was when gas was cheap. In the current state of affairs, getting good mileage is more fun.
-J
1982 242Ti - black, B23FT/M46 combo.
@john242ti on IG
Old 11-08-2021, 07:39 PM   #37
-J
I just bought 10 gallons of 87 for $45 and change.
Old 11-08-2021, 07:53 PM   #38
@adamdrives I see no mentioning of your base timing advance and dwell settings. Sounds like your engine is running with 15* of ignition advance taken out everywhere. Are you 100% that all of the baseline ignition settings are done correctly? Is your cam timed correctly (as in, did you put it straight up AND make sure that the distributor is pointed the right way?)
Also, get rid of the MSD BTM. The mods that Cosbysweater suggested are way more effective...AFTER you confirm what is happening with a timing light.
Old 11-08-2021, 10:34 PM   #39
adamdrives
I'm not sure what you mean. All the timing marks line up at tdc. The mark on my crank pulley is at 15* looking at the marks on timing cover with a timing light, engine idling. Adjusted via the slot in distributor housing. Cam is set to zero. it's running all stock ignition.
Old 11-08-2021, 11:33 PM   #40
Have you ever adjusted ignition dwell and confirmed that the idle switch is working as intended? Does it jump to ~25 degrees as soon as you crack the throttle?
Old 11-09-2021, 11:40 AM   #41
adamdrives
Yeah, dwell should be listed in my original post. I don't recall but it was within spec. I just set up base idle and got the tps re-wired so its working right. I haven't re-checked since I corrected the tps, but my sluggish power problem was fixed already by setting base idle.
