Old 10-22-2021, 02:53 AM   #1
HiSPL
Fanking Champion 1993
HiSPL's Avatar
Default My Daily. An uber slow build with poor documentation
So in January of 2021 I picked up this 1988 Blue Green Metallic 244 beauty of an old-man car. It's a DL, no sunroof, manual everything, cloth interior workhorse. And it is actually in fine shape. Couple of little dents, a scratch or two, but over all pretty mint.
First thing I did was paint the centers gold.
I can't stand those plastic hubcaps so they got trashed. Found some dog-dishes and trim rings, painted the rims Rustoleum "Metallic Champagne Bronze" since it was the closest match to the pinstripe I could find. This is just a wire wheel and spray job. Nothing fancy. I also got some new Falken tires put on.
Beets taste like buttfeet.
Originally Posted by Lando
Tinnitus and hearing loss? Sounds like your ears could tolerate some Bose 901s!
88 244
06 XC90 V8
03 V70
Old 10-22-2021, 03:01 AM   #2
HiSPL
HiSPL's Avatar
I bought the car from an estate auction right here in town. The guy had clearly taken pretty good care of the car. The old tires that were on it still had the little nubs on them, but they were 19 freaking years old according to the build date. The Oil looked as clean as a new bottle. it has a new oil filter and the battery is good. Everything about the car screams "old man's pride and joy".
After the new tires I started driving it to work. Took it to a few local hang outs:
Just basically figuring out what it needs.
What it needed badly was a front end rebuild. So I did that. SuperPro Poly bushings, new tie rod inners and outers, boots, and ball joints. Not going to touch the springs/shocks yet. Waiting for coilovers. For now I'm rocking OE ride height. The shocks on the car are still good so I'm in no rush.
Old 10-22-2021, 03:25 AM   #3
HiSPL
HiSPL's Avatar
Then the rear muffler rusted out at the input side. I just removed the can and left the pipe under the car. Drove it this way for a while. Really wasn't too bad. After a couple months of that the joint at the output of the resonator failed and the pipe was dragging the ground. Stopped, ripped the pipe out and have been hating life for a few weeks now. It's way too obnoxious inside the car.
So now we break out the hot metal glue gun.
I've been collecting parts for a little bit and have started on a new 2.5" exhaust from the downpipe back. I cut the flange off the OE cat and hogged it out to match the ID of my exhaust pipe, which is a 2.5" 304 stainless builders kit.
There will be a Magnaflow high flow cat, into a flex joint, into a short 10 or 12" cherry bomb. This is the resonator. Then over the axle into a 24" cherry bomb where the original muffler was. Yep. 2 Cherry bombs. I don't think it will be too bad As long as I can route the piping like the factory. Plenty of bends, two mufflers and a cat, and the exit is past the bumper. Should be fine....
Boogers.
The short cherry bomb was welded on before, but never used. It's ugly, but idc. It's getting painted anyway. I hacked the original hanger off the OE resonator.
Practically stackin dimes!
My first crack at joining stainless to mild steel.
Blew a hole in her. I dropped the heat a little after this and all was good.
Fixed
A grinder and paint make me the welder I ain't....
My second joint went much better. Getting the hang of it.
I have a Lincoln 120V Mig. I'm using flux core on it because I hardly ever weld, so keeping a bottle here seems like a wasted expense. I pretty much followed this guys instruction to the T and I gotta say, it's working pretty well. My welds are not at all pretty, but they are going down smooth and getting good penetration. I don't think I have any leaks yet.
I'm using Blue Demon 309LFC-O wire and Solar Flux paste on the backside of the joint. I'm using a very high heat and very slow speed to get these results. The welding is easy. The guy holding the gun is just not that good.
Tonight after dark I removed my crash triangles to make room. I have to work tomorrow evening but I hope I can get out and do a little more tomorrow morning. We'll see.
Old 10-22-2021, 08:56 AM   #4
esmth
that's a good idea stealing the OE resonator hanger. I need to do that. I plan on doing a very similar exhaust but with 2 flowmaster HP2's in series with a 2.5" 240-like tailpipe squiggle but on the wrong side.
1991 244 LH3.1 M46 373k miles
Old 10-23-2021, 01:19 AM   #5
HiSPL
HiSPL's Avatar
Started out my morning not motivated to crawl under the car to do exhaust things.
So I took care of a little project I'd been putting off for a while. Mounting door speakers. I picked up some sweet little Audax 4" coaxials. Found them NOS on ebay. Audax is a french company that made high-end pro speakers and got a little into hi-fi and car audio stuff. Audax isn't around anymore, bought up by one of the bigger companies but they had some great products back in the 90's and 00's.
Problem is they were slightly too large to fit in the metal bracket left over after you cut the magnet off the stock speaker.
So I got out the die grinder with the angry end on it.
Now the basket fits but the speaker still won't sit down flush because the surround is just a touch too wide to fit inside the little metal return. So I took a little off the plastic basket with my bench sander. Just a touch on two sides.
Then it fit snug.
Now I have a proper 2 way front stage. This will be super cool when I really dig into the stereo. For now I just wanted the door speakers in place to listen to podcasts.
Old 10-23-2021, 01:29 AM   #6
HiSPL
HiSPL's Avatar
And I still found time to do a little more welding on the exhaust.
Old 11-25-2021, 01:16 PM   #7
HiSPL
HiSPL's Avatar
Mmmmmm. Spicy Eggplant.
Putting in some work over the long weekend. Happy Thanksgiving erbody.
Old 11-26-2021, 03:06 PM   #8
DanMarino
Congratulations. I miss my 1992 240 wagon. Hopefully, I can get one as a cheap project one day.
DanMarino is offline   Reply With Quote
