Old 10-29-2021, 11:35 AM   #1
pathfinder
Default 940T radiator fan and turbo
Hi
Just bought year 1997, 940 low pressure turbo. B230FK. Odometer is 235,000. I think low for a 24 yrs old car
Previous owner, did convert from electric fan and convert to old style clutch fan including the original shroud for clutch fan type. The only reason I can think of this fan conversion, is to get peace of mind driving in hot tropical country. Electric fan could stop spinning without warning
The car with it low pressure turbo, plus clutch fan... it's heavy to rev and slow response from engine. Some ppl suggest using heavy duty clutch fan.
Do you guys think, clutch fan robs too much power?
If i want to maintain clutch fan configuration, i need to do something to get much more power to compensate power robbed by clutch fan
Could TD04-13C use 15G compressor wheel? but still the hot side original turbine wheel, it's very small, afraid of trigger high EGT
is it possible to use TD04-16T from the S60-T5 2.3 on the B230 FK ?
I still have Rica fuel and ignition chips
thanks
pathfinder is offline   Reply With Quote
Old 10-29-2021, 11:59 AM   #2
FS: NOS 140/240/700 parts
NOS 1306259 Tropical Fan Clutch (reference thread) $60
how psi stock cna sprout?
Old 10-29-2021, 06:24 PM   #3
bobxyz
bobxyz's Avatar
If it's working correctly, the thermostatic clutch fan shouldn't be robbing power -- if it's cold, the clutch is only lightly engaged and the fan spins slowly compared to the crank. If it's hot, the clutch engages firmly until the temperatures drop. With the mechanical fan, you're going from crank-to-clutch-to-fan. For an electric fan, you're going crank-to-alternator-to-battery-to-fan, so probably a bit less efficient. On the other hand, the electric fan is more precisely ECU controlled, and can be turned on to help with A/C cooling needs.
Old 10-30-2021, 06:28 AM   #4
pathfinder
Thank u guys
My 940T temperature meter maintain below half and never reach half. Is this bcos good cooling effect by clutch fan system? Ahaa... cold aircond is important in my place hot tropical country
Old 10-30-2021, 06:40 AM   #5
pathfinder
A Volvo parts shop only have Vimo clutch fan. Is this heavy duty type clutch fan?
Old 10-30-2021, 10:50 AM   #6
pathfinder
With automatic transmission, could using 19T turbo cause too much lag?
Old 11-06-2021, 10:41 AM   #7
90volvo
Ive ran 19t with an auto, seems to be pretty decent. I wouldnt worry about it, get it up and running then tune it.
B230ft rebuilt -MS-Turbo-E85
1985 240 Work in progress.
Old 11-06-2021, 05:50 PM   #8
PCH
Thank u guys
With properly working thermostat the gauge should stay right in the middle. It will not be below that point regardless of what kind of fan you are using.
Old 11-11-2021, 11:23 PM   #9
pathfinder
thank you
im thinking to use back electric fan system. oem electric fan size is 16". how much CFM estimate from oe and oem electric radiator fan?
