Old 11-02-2021, 09:26 PM   #1
90volvo
Default dana 30 to 1031 u joint
I have a 90 Volvo 240 and I think my ujoints is the 1021 series? Im in process of adding a gm trans; I can get driveshaft really cheap if I can run a 1031 series ujoint. I could run a conversion ujoint 1021 to 1031 if they make such a thing. If not is their a flange that will bolt to the stock pinion flange?(if that makes sense)I tried ordering a flange and the bolt pattern is way bigger than the pinion flange. Thanks for any help.
B230ft rebuilt -MS-Turbo-E85
1985 240 Work in progress.
Old 11-03-2021, 12:49 PM   #2
90volvo
Well I abandon the flat drive shaft flange and ordered this so I can run the 1031 u joints. Which, I can save about 150 bucks on a driveshaft. For reference here is what I purchased.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 11-03-2021, 01:02 PM   #3
culberro
culberro's Avatar
That's good to know on the drive yoke.
Old 11-03-2021, 02:22 PM   #4
Broke4speed
Broke4speed's Avatar
If it fits, then I think that might be the way I go for an eventual T5 swap. I kinda hate the flat flange, even though it's a purely irrational feeling.
1984 244/ AQ140A / M46
Old 11-03-2021, 03:33 PM   #5
gsellstr
gsellstr's Avatar
I think you mean 1310 joints, not 1031's. 1310's are a standard joint, which was also used by Volvo on many of the later flanges, got them on my wagon currently.
RIP
Nick Fengler "fengler" 8/6/18
Bob Davi "bob davi" 10/2021
74 144 B20
90 745Ti
Old 11-03-2021, 09:52 PM   #6
90volvo
you are correct my error. So did little research and seems 1984 and earlier has the 1310 u joints and from 85 on has the 1210. At least thats what rockauto is showing me. Thanks for help and will let everyone know if that yoke that I ordered fits.
Old 11-04-2021, 10:14 AM   #7
Broke4speed
I really hope it does, because that would make things a LOT easier .
Old 11-05-2021, 01:34 AM   #8
gsellstr
gsellstr's Avatar
Not sure on the 1210, as my wagon, factory driveline, has 1310's as well. Could be wrong though...
Old 11-05-2021, 11:21 AM   #9
Beep beep zip tang
Pretty sure the I had 1300's on the original driveshaft on my 1980 242.
Deviant Volvo collector/cat herder.
Old 11-05-2021, 11:50 AM   #10
90volvo
I know my 90 240 driveshaft has ujoints that are smaller than 1310, I also have m47 driveshaft and its the same as the auto? But yeh, I hope the yoke I ordered works. It should be here today.
Old 11-05-2021, 09:14 PM   #11
Lacquerbeast
Default Flange
Spicer makes a flange adapter. Don’t know the number off hand, but I purchased 2 twenty years ago. Used one, still may have the other on the shelf. If you can’t find the unit online….email me. Fdbadge1@gmail.com. I’ll sell you my unused spare or get you the number.
Lacquerbeast is offline   Reply With Quote
Old 11-05-2021, 11:47 PM   #12
gsellstr
gsellstr's Avatar
The old number for the spicer flange for 1310's is 2-2-237, forget what they changed it to. Bought one years ago when I had a 1pc made.
Old 11-06-2021, 06:09 PM   #13
90volvo
I recieved this yoke and it fit the Dana 30 perfectly. Just thought let everybody know just incase someone wants to go down a similar road. Also with the 4L60e bolted up and with this yoke looks like my driveshaft needs to be 46 1/2 inches long. That allowing 1 inch of travel on the trans yoke. Im probably goning to order a 2.5 diameter driveshaft just cause the tuneel is so tight.
Old 11-06-2021, 06:19 PM   #14
Broke4speed
Sweet! Thanks for the heads up! This adds another option .
