Old 11-03-2021, 05:45 PM   #1
SoniX
Default Wheel fitment
Hello people
This question has been asked and answered many times but cant find an answer to my specific specs...
I've found some wheels.....
16x7.5j et40
Will they fit my 97 940 estate?
SoniX is offline   Reply With Quote
Old 11-03-2021, 05:50 PM   #2
spock345
spock345's Avatar
The offset seems wrong to me. et40 is the offset you would find on FWD Volvos. RWD cars like the 940 should mount something with an offset of et20-25.
1998 S70, grandma-mobile
Old 11-03-2021, 05:55 PM   #3
SoniX
I see, they aren't advertised as volvo wheels just a set of 5 OZ racing alloys I've found on facebook, which are 5x108 (The center bore I could get bored out if it were to small)
Im just not sure if the et would cause me fitment issues would hate to uy them only to find they touch the shocks.
Old 11-03-2021, 06:13 PM   #4
mikep
The MP
mikep's Avatar
They might work with spacers and longer studs.
Originally Posted by Alan29 View Post
RBS 69:420: "I’ve said these things to you so that you will have peace in me. With this order you have distress. But be encouraged! I have many more orders to fill and a sick new shirt dropping next week.”
Old 11-03-2021, 06:29 PM   #5
You could be in luck, IIRC late 960's use high offset 'FWD' wheels, but I don't know the exact year of the change.
how psi stock cna sprout?
Old 11-04-2021, 05:27 AM   #6
SoniX
Spacers were my next idea but again I'm not sure if they will then rub on the arch ���� only one way to find out
Old 11-04-2021, 05:44 AM   #7
Fa182
Stage 1
Fa182's Avatar
You will require spacers in the range of around 20mm.
You might be okay with the arches, but there's a chance it will hit / rub on the front strut if the wheel is too wide.
Offset of a 940 is usually between 20-25mm, depending on the wheel.
As an example, RWD Hydra wheels are 16x6,5 ET25.
You can do the calculation by yourself or use www.willtheyfit.com but it seems to be offline at the moment.
Late 960's and the S/V90's did, but OP's late 940 is using RWD offset, they did so until the end of their life in 1998.
Old 11-05-2021, 03:36 AM   #8
Triebwerk
As mentioned by Fa182 you will have to install spacers.
I drive 7x16 ET32 and needed 15mm to clear the front shocks.
16x7.5j et40 means these wheels go 14mm further to the inside... 25-30mm spacers...
regards Mathias
[Austria]
Triebwerk is offline   Reply With Quote
