Old 11-04-2021, 02:38 PM   #1
Tfest
Hipsters ruin everything™
Tfest's Avatar
Default 1992 245 Quick Release Steering Wheel
Yo, now that the 5.3 is done I need to start researching what steering wheel **** to get. I'm ordering a Grip Royal designer wheel. What's the best, easiest to install and most reliable quick release steering wheel setup that I should get for this super Duchebaggery wheel that I'm ordering?
Lifted 240 Build Pages
TB Build Thread
Instagram Page
Tfest is offline   Reply With Quote
Old 11-04-2021, 03:03 PM   #2
culberro
culberro's Avatar
I really like the NRG quick releases that use the multiple balls to lock the hub. They do not develop play, and you never have to worry about having the wheel on crooked.
For a 6-bolt adapter, get anything but the OMP one:
https://drivenrg.com/products/nrg-sh...olvo-240-82-91
https://www.bneshop.com/products/240...c3ce5c51&_ss=r
Edit: Looks like all of the adapters suffer from the same issue with cancelling the turn signals as different points when turning left vs right.
Old 11-04-2021, 03:35 PM   #3
Originally Posted by culberro View Post
I'm not sure if the Momo adapter cancels the turn signals properly (just checked, it doesn't), but the NRG definitely does. It's an easy fix to the Momo if you have issues.
NRG and momo both use the same canceling design?
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 11-04-2021, 03:41 PM   #4
Tfest
Tfest's Avatar
I saw the NRG one and almost ordered it but it's 82-91? Mine is a 1992 with airbaggers. Still fits?
Old 11-04-2021, 03:48 PM   #5
rb92673
NRG is solid. I use a 2.5 series with a Momo adapter because 740. I don't have turn signals, so I can't comment on that.
Old 11-04-2021, 03:51 PM   #6
2manyturbos
It should. The steering column itself is the same, SRS vs. non-SRS. The only difference between the two is the casting for the turn signal/wiper switch.
Old 11-04-2021, 04:00 PM   #7
Tfest
Tfest's Avatar
Rad, thanks guys, that's all the info I need.
Old 11-04-2021, 04:35 PM   #8
towerymt
the real Towery
towerymt's Avatar
You'll want the earlier horn contact ring that's smaller diameter than the one on the airbag cars. Direct swap, did it on my '92 when I replaced the airbag wheel.
I have a bolt-on quick release that uses a hex shaped shaft. It will move the wheel closer. I haven't driven with it in a long time since I parked that car...but I don't remember having any complaints about it. You can also get ones that have a weld-on hex that removes the need for the adapter linked above.
1987 244 | Project Thread | The 87 | Now with 74 mods and counting
1992 244 | The 92
244s are drop dead ugly and suck.
Old 11-04-2021, 05:11 PM   #9
culberro
culberro's Avatar
You're correct, I updated the post. They must have changed the design. It used to be a solid block, but now it's a "U" channel so they won't cancel turn signals properly.
You have to fill in the gap between the two rails for it to cancel like a stock wheel.
Old 11-04-2021, 05:20 PM   #10
Easily improved with a 3d printed widget.
Old 11-04-2021, 05:30 PM   #11
culberro
culberro's Avatar
Or some bent sheet aluminum, or some epoxy.
It's just annoying that it has to be done.
