Old 11-06-2021, 04:10 PM   #1
baccara1
Default M46 j/p type overdrive versus p type
Hi
I currently have a 1988 740 with a j/p marked overdrive.
I have a newer p type and am wondering if it would be compatible with the existing m46.
It looks identical from the exterior.
Many thanks
Andrew
baccara1 is offline   Reply With Quote
Old 11-06-2021, 04:19 PM   #2
The Librarian
I don't believe you can stick a P type OD on a trans that has a J or J/P type. From what I understand the output shaft of the transmission is larger for P type OD's.
Old 11-06-2021, 05:51 PM   #3
baccara1
Many thanks for the info
Old 11-13-2021, 03:03 PM   #4
sbabbs
sbabbs's Avatar
ONly J/P marked overdrive on m46 I ever saw was on a 16v car. I don't know the size of the shaft hole is but yeah P has bigger shaft hole then J. Curious what the P/J size shaft hole is.
Old 11-14-2021, 09:41 PM   #5
745T+
745T+'s Avatar
That was at the old north Portland U-Pull It. You pulled the flywheel, and left the transmission. It went into my son's car, and was functioning perfectly when it was replaced with an M90. M46 transmissions have become scarce. They were plentiful 5-20 years ago.
745T+ is offline   Reply With Quote
Old 11-15-2021, 01:19 PM   #6
sbabbs
sbabbs's Avatar
Yes I remember it was you got that. I still have that other m90 I got from you, still gotta put it in one of these junkers one of these days
