Old 11-09-2021, 11:36 PM   #1
Tunatime
Default Engine Missing
Hi all volvo people I've just been removing things from my 940 ac condenser ect, front chassis weights,radio charcoal canister and iac valve. I've blocked of vacuum ports on manifold and iac and also blocked of the hose coming from intercooler piping to the iac valve and now it's got a misfire any suggestions also I've wound the little adjustment screw to make it idol. Any help would be great
Tunatime is offline   Reply With Quote
Old 11-09-2021, 11:39 PM   #2
Tunatime
Also I've just changed the fuel filter at the same time as all of this
Old 11-09-2021, 11:52 PM   #3
James M
Bored member
James M's Avatar
Maybe some of those "useless" parts serve a function?
Old 11-10-2021, 12:23 AM   #4
Tunatime
Seems weird that it would plenty of people out there remove the same things and have no issues. I may have bumped something could even be fuel pump
Old 11-10-2021, 12:44 AM   #5
Tfest
Hipsters ruin everything™
Tfest's Avatar
F u c k where did it go
Lifted 240 Build Pages
TB Build Thread
Instagram Page
Tfest is offline   Reply With Quote
Old 11-10-2021, 05:41 AM   #6
Shifted
Shifted's Avatar
Seriously... find that engine.
Maybe it beat the rest of it to the CRUSHER.
People just aren't smart.
Doing something because you enjoy it is a must in life.
Originally Posted by ME II View Post
Without mistakes there is no learning.
Originally Posted by miguels244 View Post
Yeah...buy cheap crap and watch your kid's jobs evaporate.
"The table is tilted folks, the game is rigged. And nobody seems to notice, nobody seems to care..." -- George Carlin
Shifted is offline   Reply With Quote
Old 11-10-2021, 10:47 AM   #7
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
Better go catch it.
I sell chips for LH 2.4!
Old 11-10-2021, 10:57 AM   #8
Bloody244
reinstall the iac and see if it works and your engine couldnt have grown legs so where is it?
'87 244 B230R @17psi 19t V16t cam (soon Stage 3 overboostracing.se 530 head) ACM H-beam rods Do88 intercooler Accumulator Mod AW71
Instagram @Blue__244
Rip '87 B230f+t it did not stay window free 25.06.2021
Bloody244 is offline   Reply With Quote
Old 11-10-2021, 11:53 AM   #9
Dvroofer
Dvroofer's Avatar
I put a bell on mine. I’d retrace your steps part by part until you find the culprit if you had it running well.
Dvroofer is offline   Reply With Quote
Old 11-10-2021, 12:12 PM   #10
JohnMc
JohnMc's Avatar
Whoa, I checked and now mine's missing too!!!
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 11-10-2021, 01:51 PM   #11
Tunatime
Lol in New zealand we say the the engine has a miss or its missing instead of misfire or we just call it f#$ked haha
Old 11-10-2021, 01:54 PM   #12
It's called "you ****ed up," followed by "revert your ****-up"
Old 11-10-2021, 02:06 PM   #13
My car is fun hp club
Well you gave these guys the chance to rick roll you and they took it.
All of the things you disabled on your engine may have caused a large vacuum or air leak. Air leaks can make the engine misfire. I don't understand why you would remove the idle management and charcoal canister. They are things that help your engine run better and pollute less.
Old 11-10-2021, 08:01 PM   #14
lummert
lummert's Avatar
If you removed the charcoal canister how did you vent the fuel tank? Did you also delete the vacuum source to the fuel pressure regulator? It probably needs that Idle air hose reconnected to the intercooler tube even if only to run a ball valve to control idle air.
Old 11-10-2021, 08:18 PM   #15
Dan
Fought Covid and won
Dan's Avatar
Too many variables. Check vacuum readings at idle, check plugs and wires
1985 Chevy TPI V8 740.
Old 11-16-2021, 01:29 AM   #16
Restore it to socks.
how psi stock cna sprout?
Old 11-16-2021, 02:57 AM   #17
Fa182
Stage 1
Fa182's Avatar
I've heard and read that this is a thing that some people actually do and always wonder what they want to achieve with this.
Maybe OP can explain?
