Old 11-12-2021, 06:53 PM   #1
90volvo
Default source to buy exhaust pipe
Well the last kit bought had 45-90- and straight piping. It was stainless steel, and I thought I was just a terrible welder but now that I have welded enough stuff, Ive figured out that the stainless is junk. Id be weld a pretty decent weld then all of a sudden poof- Id have a big hole to weld up. I necessarily dont need stainless so just good piping if it will withstand dp temps. Any source or brand you would recommend. Yes, I have a couple of local muffler shops but they kink 90 degree bends and dont carry any 3 inch. Thanks
I
B230ft rebuilt -MS-Turbo-E85
1985 240 Work in progress.
90volvo is online now   Reply With Quote
Old 11-12-2021, 07:01 PM   #2
HiSPL
Fanking Champion 1993
HiSPL's Avatar
Hack out factory exhaust bends from the junkyard or go to ebay/amazon and read the reviews. Your are taking a risk with ordering it, but it's the way most of us do it.
This place has a good rep, but I've never ordered from them:
http://www.mandrelbends.com/mandrel-...-16-gauge.html
Beets taste like buttfeet.
Originally Posted by Lando
Tinnitus and hearing loss? Sounds like your ears could tolerate some Bose 901s!
88 244
06 XC90 V8
03 V70
Old 11-12-2021, 07:35 PM   #3
white855T
I guarantee you are welding too hot. Many of you guys post pictures and I just have to chuckle. Its just exhaust pipe after all and you're trying to weld it like its 1/2" steel. Top quality ss piping is not cheap. There is a reason custom exhaust setups cost so much.
Old 11-12-2021, 08:22 PM   #4
how psi stock cna sprout?
Old 11-12-2021, 08:44 PM   #5
Marvelous3
Who engineered this?
Marvelous3's Avatar
I mean McMaster carr sells metal tubing.
2016 Chevrolet Silverado 1500 Blackout Edition
1991 245+Turbo 16 Valve Microsquirt
Need Lawncare service in Atlanta? PM me for a lawncare and maintenance quote
Old 11-12-2021, 10:57 PM   #6
oldschoolvolvo
oldschoolvolvo's Avatar
you can order SS or aluminized 3" exhaust tubing from Rock Auto, NAPA, Advance
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 11-13-2021, 11:44 AM   #7
shoestring
shoestring's Avatar
I use SPD Exhaust. That stuff is really nice and is ready to weld. Walker/Dynomax is pretty good too: 16ga, mandrel bent, readily accessible, reasonably priced and made in the US but you have to clean up the coating before you can weld it.
Old 11-13-2021, 02:21 PM   #8
culberro
culberro's Avatar
That is an understatement.
SPD products are some of the best out there. Their 321 is wonderful to weld. It’s so clean.
Old 11-13-2021, 06:02 PM   #9
My car is fun hp club
I ordered from Summit racing when I built my down pipe. A 3' piece of straight tubing, a 180 degree 3" mandrel bend and I had enough to make the downpipe.
Old 11-13-2021, 06:26 PM   #10
yolk
yolk's Avatar
i built myself a cheapo hf exhaust/pipe expander so i didn't have to start learning to weld on butt joints and it was a godsend, for anyone just getting their toes wet. its a lot more forgiving type of weld to make and, fwiw, the expander works even better when hooked up against a powered unit vs hand-pump.
yolk is offline   Reply With Quote
Old 11-13-2021, 07:00 PM   #11
283SD
What alloy s/s are we talking about? {cheap-409 or expensive 304-316 or321?]. I made my exhaust for the V8 Wagon in'91 out of 304 s/s, other than a little dirt it still looks good,340K miles later.
Old 11-13-2021, 07:14 PM   #12
Cwazywazy
Single jingle
Cwazywazy's Avatar
I like mandrelbendingsolutions. 200 bucks for a 3 inch 409 stainless builders kit, they do both expanded and non expanded ends. I've only used their aluminized steel kits though.
I don't know what I have
Old 11-14-2021, 01:02 AM   #13
msweeney
msweeney's Avatar
Ace Race Parts is also a great resource, especially for V-band assemblies and the like.
I spend a lot of time around race cars. A lot.
1975 245: Pea green, kinda rough. B230F swap, HX35, topmount header, external gate, NPR, dual plenum intake manifold, DSM CAS, MS3 3.57, T5 WC, front coilovers on raised strut towers, and a never-ending, ever-expanding list of dumb ideas
msweeney is offline   Reply With Quote
Old 11-14-2021, 12:46 PM   #14
283SD
Burns Stainless, Ca, used them many times.
Old 11-15-2021, 04:59 PM   #15
PaddyGarcia
Burns is also having a sale on blemished bends, worth asking.
PaddyGarcia is offline   Reply With Quote
Old 11-15-2021, 10:18 PM   #16
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
I have bought Squirrely Performance SS Mandrel bends off Amazon - decent quality. I agree with white855T - you are probably running way too much amperage on the welds. SS you can easily weld at 15-20 amps with a TIG - that's what I do & my welds aren't great.
Old 11-15-2021, 11:05 PM   #17
90volvo
Thanks for all the info guys. yes, Ive turned the heat down just fustrating to be welding a nice bead and all of sudden poof. you have a nickle size hole to fill. Guess the bright side is Im getting alot of experience and getting better. Thanks again.
Old 11-16-2021, 08:28 AM   #18
doleary
Also try aceraceparts.com they can be a little pricey but everything I have ordered has been good quality and super fast shipping.
doleary is offline   Reply With Quote
Old 11-19-2021, 09:49 PM   #19
sbabbs
sbabbs's Avatar
I use steel and use oxy acetylene gas welder on my exhaust way easier not to burn hole.
