Old 11-13-2021, 05:17 PM   #1
BeaverMeat
BeaverMeat's Avatar
Default 5.0 headers
A question for the 5.0 swap guys.
The OE headers are leaky… I’m at 37 ft-lbs and getting anxious about going tighter. The factory spec is 26-32. Right now they only tick when the engine is cold so I can live with that for awhile.
Shopping around for future replacements. What will fit in a 240 without modification? Are long tubes possible?
She’s built like a steakhouse but, she handles like a bistro.
Old 11-22-2021, 03:13 PM   #2
JimWilling
We're putting a 302 in our Lemons racecar, and we've had to modify both headers a little bit. Mostly to tuck them closer to the block. We're using a pair of mismatched random craigslist headers, but if you're starting from scratch, Ranger swap headers are pretty close to what you'll end up needing.
JimWilling is offline   Reply With Quote
Old 11-23-2021, 05:52 AM   #3
BeaverMeat
BeaverMeat's Avatar
The OE Foxbody headers fit nicely in my car. Just a small indent to fit around the steering shaft was needed.
Old 12-01-2021, 08:58 AM   #4
Sir Walter
If you measure how much space you have, then you could call up these guys and see if they have specs. If they don't, I'm sure the manufacturers would.
Sir Walter is offline   Reply With Quote
Old 12-02-2021, 12:45 PM   #5
kyote
Living The Dream
kyote's Avatar
Hit them with the big belt sander and get them flat?
Torque wrench? Really?
"Come on Man!" /Joe Biden Voice
Old 12-03-2021, 07:24 PM   #6
Kjets On a Plane
Kjets On a Plane's Avatar
Location: Californicated Oregone...suggestions for a way out?
^This. Scrub them flat on the belt rig or the mill & the fixture or on a table with a big mill-bastard fire for metal carefully and warm them up and properly drill & weld the crack?
'I mean...how hard can it be?' / Jeremy Clarkson voice.
Do you want more power & to deal with something (more) custom or just function/OE metal known to fit and work and be replaceable/in the junkyards on every F-body V8 & to fix the problem?
How PSI a stock can support?
Always Be Crushing!
