Old 11-15-2021, 11:59 AM   #1
VolvoLatAm
Default parallel flow condenser
are there any decent (aftermarket) parallel flow condensers for 240s on Amazon.com? I want to ship one directly to my country and amazon has free shipping
Old 11-15-2021, 12:25 PM   #2
white855T
This would be a direct fit. https://www.rockauto.com/en/catalog/...condenser,6708
Old 11-15-2021, 01:02 PM   #3
philski o'flood
philski o'flood's Avatar
how do you hook up the '93 condenser to the earlier AC systems
philski o'flood is offline   Reply With Quote
Old 11-15-2021, 06:19 PM   #4
kyote
Living The Dream
kyote's Avatar
You would need to make a new line from the condensor to dryer, using a 180* fitting and a 90* fitting, #6 in size. You would also need to put a new end on the compressor-condenser hose, or make a new one.
I installed this very condenser in an 83 the other day, but made all new hoses. Amazon hydraulic crimper on it's 3rd AC system rebuild and still kicking ass, highly recommended!
Old 11-15-2021, 07:48 PM   #5
philski o'flood
sounds great! What did you do for the evaporator?
Old 11-16-2021, 09:30 PM   #6
kyote
Living The Dream
kyote's Avatar
Luckily the stock one was in good shape. Ran ac flush, brake clean, and compressed air through it. Straightened the fins. Booger freezer with envirosafe.
Old 11-17-2021, 07:14 PM   #7
philski o'flood
^Sounds great. I found a direct fit parallel flow condenser at Swedish Car Parts, yikes $340 plus shipping.
Then remembered I had a real Volvo '93 version in the garage!
Old 11-18-2021, 01:56 AM   #8
kyote
Living The Dream
kyote's Avatar
Used these guys and some "custom" brackets to fit the 93 style to the earlier style 240
M6 Rubber Isolator Mounts HOMEKNOBS Shock Absorbers Anti Vibration Car Boat Bobbins for Mini Split Heat/Water Pumps, Diesel Engines, Harvester, Generator 4 Pack https://www.amazon.com/dp/B08CVGV48L...4FBJ4J25D6YHAM
