Old 11-16-2021, 01:39 PM   #1
Elvolvito
Elvolvito's Avatar
Question Ď88 Volvo 244 Alternator Advice/Recommendations
I recently bought an alternator for my Ď88 244 & it came non-functional. Itís a Remy brand remanufactured alt & Iíll be returning it within a few days. With that being mentioned, what alternator would you fellow forum members recommend? I have this one currently on my watchlist & was wanting to know if it would be a good purchase? (https://www.ebay.com/itm/140-Amp-Vol...-127632-2357-0)
Thank you.
El Volvito
Elvolvito is offline   Reply With Quote
Old 11-16-2021, 01:53 PM   #2
Fa182
Stage 1
Fa182's Avatar
Why do you need an alternator with such high amperage? Unless you have loads of accessories installed and really need it, that's way too much.
Are you sure everything else in the circuit is fine (grounds, exciter circuit etc.) before ruling out the alternator?
Old 11-16-2021, 01:56 PM   #3
Elvolvito
Elvolvito's Avatar
Yes, everything else has been ruled out. Days of electrical testing & an alt bulb replacement has led me to the decision. As well as my mechanic also saying itís my alt. I tried replacing the regulator as well & it didnít change my situation. My previous thread explains the entire situation. I also wasnít really aware what having an alternator with more amps really means, does it put more strain on the electrical system?
Old 11-16-2021, 02:28 PM   #4
My car is fun hp club
That's a fair price imo for a 140 amp alternator. The stock alternator is 80 amps for your car. With all the extra amperage you'll be able to run some extra lights and more accessories. If you want to afford it that's a good upgrade.
Old 11-16-2021, 02:30 PM   #5
JohnMc
JohnMc's Avatar
Pick-n-pull 940 100A Denso works pretty well, and is really cheap. If you can find one, that is.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 11-16-2021, 04:41 PM   #6
VolvoScout
VolvoScout's Avatar
Would the + and - cables need to be upgraded to a larger gauge to support a 140 amp alternator?
Old 11-16-2021, 04:52 PM   #7
Elvolvito
Elvolvito's Avatar
Donít believe so judging by what the pictures demonstrate.
Old 11-16-2021, 05:34 PM   #8
The need for upgrading the cables is based on what accessories you plan on adding to the original current load. If you are going to add a lot of high power stuff then yes upgrade those cables. If you aren't going to add much you'll be fine.
Old 11-16-2021, 06:18 PM   #9
spock345
spock345's Avatar
I got one for $20 from the local yard. It worked great.
1998 S70, grandma-mobile
Old 11-16-2021, 08:04 PM   #10
bobxyz
bobxyz's Avatar
The big cables directly off the battery to the starter/engine are already sized to start the car (hundreds of amps). If you really have 140Amps of accessories (efan, search lights, A/C, earthquake stereo, arc welder), you might want to upgrade the smaller battery+ to junction box cable, the alternator-to-starter + cable, and the short alternator- to ground cable. They're probably ~10 gauge now, and going to 8 gauge would keep the voltage drop under a volt. Just make sure you crimp them really well.
Old 11-16-2021, 10:17 PM   #11
Elvolvito
Elvolvito's Avatar
I donít even have 140amps worth of accessories currently. I just figured it wouldnít be a bad investment to have all that extra power in case I wanted to add some decent speakers & a light bar in the future.
