Old 11-21-2021, 06:29 AM   #1
smncutler
Question B230 slant mount in 122
Can a B230 be slant mounted in a 122 with an untouched B230 oil pan? I can't seem to find a straight answer. TIA.
smncutler is offline   Reply With Quote
Old 11-21-2021, 08:23 AM   #2
AndrewNance
Amateur hour!
AndrewNance's Avatar
Even though mine is upright, I’m going to confidently say yes. The b230 pan is flat with the engine at it’s normal angle, right?
'67 122 - b230, t5, 8.8
Feedback
Old 11-21-2021, 11:26 AM   #3
283SD
I saw one put in a 1800 years ago at the VSA meet in Saratoga, nice job!
Old 11-21-2021, 12:44 PM   #4
No it's bulbous.
how psi stock cna sprout?
Old 11-21-2021, 01:08 PM   #5
pat244ti
pat244ti's Avatar
If a 122 is anything like an 1800, there is a good chance you will need to make a good "dimple" in the back drivers side portion of the pan.
I put a slanted B23F in my 1800 for mockup with Yoshifab brackets. The pan would contact the back area of the lower control arm, after pulling it out and smacking it with a hammer a number of times, it was good.
- Patrick
83 244ti - rally
73 1800es - resto mod cruiser
83 244ti - road race
79 262c - road race in the works
08 c30 T5 - daily recce car - M66, Lifted 1.5'', 215/65/16 Falken All Terrains on Method MR502's, iPD skid plate
97 Dodge Dakota 5.2 4x4
70 Ford F100 2WD 351M/C6
Old 11-21-2021, 03:43 PM   #6
142 guy
142 guy's Avatar
In the Engineering World, that instruction would occasionally show up on field construction drawings, except it was worded Field to Determine.
Old 11-21-2021, 08:48 PM   #7
AndrewNance
Amateur hour!
Oh I guess I haven’t worked on anything else with a b230 in a while.
