Old 11-22-2021, 02:22 PM   #1
Ron740
Default Volvo 740 bigger wheels, help needed.
Hi guys,
want to put some nice wheels on my 740.
the idea is that i want around 17 inch' with many spokes.
Now i dont now what measure wheels fits good to the 740.
original wheels is:
5x108
65.1mm wheelhub.
Offset: 25
195/60/15
what kind of offset do i need? 25 offset is very low in my country. most wheels are around 35. can i get more offset and compromise it with wider wheels? hope yall understand my amateur english XD
Just want some nice looking wheels, without spacer crap or other adjustmends.
wonder how these fit with offset 38: https://www.marktplaats.nl/v/auto-on...Mzc2MDYwNjcuMA..
Greets.
Ron740 is offline   Reply With Quote
Old 11-22-2021, 02:33 PM   #2
Ron740
With ET i mean Offset.
Old 11-22-2021, 05:26 PM   #3
Lankku
Lankku's Avatar
ET38 will rub on the front struts. Bigger ET means the wheel goes inwards. You need spacers or wheels with same or smaller ET as original.
242 DL -80 (was 4.6l)sold, 245 -88 "B6284T" sold, 245 -92 "B6284T",
245 -90
Old 11-22-2021, 05:58 PM   #4
Fa182
Stage 1
Fa182's Avatar
The only 17" wheel that came originally on 7/9 was the Polaris wheel and that was 17x7. Don't know what ET it had, but I'm assuming 20.
As Lankku said, you will need a spacer to get the ET near 20 if they are the same width.
Not sure what width those Alfa wheels are, but I'm assuming a 20mm spacer will do the job.
Take care of the center bore, 7/9 have 65,1mm.
Old 11-23-2021, 12:59 PM   #5
Bust out the tape measure, and go to town:
https://www.wheel-size.com/calc/
Old 11-23-2021, 07:26 PM   #6
sbabbs
sbabbs's Avatar
Those front wheel drive volvo 17 inch Tethy's with lots of spokes fit well on 740 with 25mm spacer on front and 32 on rear I think it was. I will look for a pic.
https://i40.photobucket.com/albums/e...ars/740008.jpg
Old 11-24-2021, 03:13 AM   #7
GSWAGON
my other ride is a exmark
Originally Posted by Ron740 View Post
Hi guys,
original wheels is:
5x108
65.1mm wheelhub.
Offset: 25
195/60/15
Greets.
with 38+ offset, you would need a 20-25mm adapter to run them on a 740.
87 765 GS Wagon LT4/T56 13.1@111
90 740 Turbo M46
90 780 Bertone Turbo
99 SL500 AMG Sport
08 Corvette JSB LS3 6 speed
08 Escalade AWD- wifes daily
15 Ram CCSB Hemi 4wd
Life is short, so live it! You are only old when your dreams are replaced by regrets.
GSWAGON is offline   Reply With Quote
