Old 09-13-2021, 12:22 PM   #1
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
Default What are people running for bigger alternators? Stereo
I'm gonna putting my 2000w rms and 400w rms amps and sub and speakers in my car and I'm sure the stock alt won't love it, what higher power stuff are you guys using
Deb the 940T Tina XC90 T5
Old 09-13-2021, 09:28 PM   #2
doucheNozzle
doucheNozzle's Avatar
badvlvo was making some stuff
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'11 XC90 V8 - Torque Monster
Old 09-13-2021, 10:46 PM   #3
https://forums.turbobricks.com/showt...hlight=mechman
how psi stock cna sprout?
Old 09-14-2021, 12:02 AM   #4
Wilford Brimley
Those alts seem a little small for what I'm doing. Also gonna doing the big 3 upgrade. I thought the rule of thumb was 10amps per 100w rms? I d k that much about alts....I'd love to have a bigger mechman
Old 09-14-2021, 12:25 AM   #5
Dan
Fought Covid and won
Dan's Avatar
10 amps x 12 volts equal 120 watts, if 100% so it is a good rule of thumb
1985 Chevy TPI V8 740.
Old 09-14-2021, 04:50 PM   #6
Dvroofer
Dvroofer's Avatar
Make sure if you get one it can operate at higher rpms. I’ve been told the larger amperage gm truck cases they sell do not like higher rpms.
Dvroofer is offline   Reply With Quote
Old 09-14-2021, 04:58 PM   #7
Dvroofer
Dvroofer's Avatar
They actually had a compact 240 amp that I can’t find on their site anymore. Was there a couple weeks ago. Crap..
Old 09-14-2021, 05:26 PM   #8
white855T
Anything you do for an alternator will be a custom setup but it will be worth it.
Old 09-14-2021, 08:48 PM   #9
dbarton
Dejected by Volvo Corp.
dbarton's Avatar
If you have the money to spend I dont think you can do better than a Mechman 6 phase hairpin stator alternator. I dont have a big stereo, just serious AC, so I'm happy with 170 amps, but they make my model up to 370 amps at least. Mine runs at 14.7v steady when cold or hot and with as much load as I can throw at it. Mines in a large GM case.
RPMs shouldn't be an issue. Its rated at 20k rpm, which should work for 6500 rpm engine speed.
Dave
Old 09-14-2021, 09:25 PM   #10
Dvroofer
Dvroofer's Avatar
Originally Posted by dbarton View Post
If you have the money to spend I dont think you can do better than a Mechman 6 phase hairpin stator alternator. I dont have a big stereo, just serious AC, so I'm happy with 170 amps, but they make my model up to 370 amps at least. Mine runs at 14.7v steady when cold or hot and with as much load as I can through at it. Mines in a large GM case.
Dave
I was told certain ones they sell that use that gm case won’t work at higher rpms such as the 400 amp elite model, I should of clarified that. I definitely agree they have the best products. Finding the exact one has been my issue.I found them because of your write up. So thanks. Looks like they are adding lots of new products.
