WeezilUSA
- Nov 12, 2002
- Vancouver WA
Dude,
Intercooler piping is the easy part. I don't understand what you would be going through the trouble of fabbing the new mani for if you are using stock intercooler as well.
What angle is the edge of your plenum compared to the runners?
On the second pic, you can see using a stock IC all you have to do is use a 45* elbow and your butter.
Let me know if you guys that are intersted in buying like the design, would like to see anything different, or keep rallying the way that I am.
Isn't it strange how the same manifold can look so different between 2 photos! I think it looks potentially nice in the first photo (given the mock-up end), but don't like it so much in the second!
There seems to be a greater vertical height difference between the throttle body and the runner of No.1 cylinder in the second photo (more side on) than there is in the first, and the impression it gives me is that the angle of the end is too steep and the turn of the bend a little tight?
If the angle of the throttle body can't itself be changed without effecting the line to the I/C, could the throttle body by pulled further forward in the bay to reduce this angle? I think it would also 'look' better with a more gentle taper at the plenum immediately post-TB leading into the more angular end.
I tend to go along with the 'gas inertia through the throttle body' theory, but like most of the comments here this is just my seat-of-the-pants guessing really without any kind of basis in fact, and who can say how well it will work in reality as-is with no testing having been done at this stage.
The rest of the actual fabrication work looks pretty ****** good to me.
