snailmale
- Sep 26, 2018
- SiO2 Mound
Fuel issues continue to plague my 245 and its B21FT and hopefully you all can help. Not sure if it's just one thing that needs tweaking or multiple problems that need to be looked at.
In the last 12 months I've done the following:
There's probably more in my build thread.
But every time I turn the key, the following happens:
1.) I put it to ignition position 2 and let it build up fuel pressure. Car sounds fine.
2.) Clutch in and turn it to Engine ON, engine fires up and dies unless I pretty much keep it floored hard. Car will turn on and run bad. Tach needle bounces up to 2.5-3k but revs freely if I keep my foot down.
3.) Foot comes off accelerator. Car sounds fine and then promptly stalls with a metallic squelch.
4.) Under the car is a steady drip of fuel from the right-side where the distributor and airbox sit. The airbox lid will be drenched in fuel and I've seen the lines going to the injectors weep a bit, though I've mostly solved this with the second round of copper washers.
I've noticed that the hex-head fitting between the main supply line and the metal fuel line with the arrow pointing out seems to weep a bit, though I've yet to see anyone suggest turning it a bit.
4.1) Car will do warm starts. I'll give the banjos a good tighten and it pretty much repeats steps 2-4.)
For fun, I popped the boot off the air flow sensor and wiggled the plate up/down a bit. I could feel some engagement with the piston in the distributor, though it didn't feel linear. Unfortunately I have not gotten around to making the fuel pressure tester, but I will say that the lines all ejected pressurized gasoline into my face/a towel at a very forceful rate. The car also runs, which suggests it's getting some quantity of fuel, air, and spark, though it's unclear why it's not getting enough of the first two in a way that makes it happy.
Question to you all: I was wondering if this was a sign of a bad distributor, bad idle valve, or some combination of ungodly problems that come with pushing fuel at its designed pressures through the old K-Jet system? Any other paths worth exploring?
Thanks for humoring me.
- New Bosch fuel filter
- Dave Barton harness that I verified was all plugged in
- Cleaned distributor piston & replaced O-ring
- Drained and refilled tank with fresh 91 octane
- Changed all copper washers twice and 2x checked they were all torqued
