Old 01-22-2017, 12:23 AM   #1
Sliding242
Default Finished my B230ft swap but having issues
Hi guys, I think this is my first post here.
So I managed to swap and rebuild a b230ft into my 242 and I cant be happier to finally get this thing done but I have just a couple issues with some questions.
I picked up an MBC and and A/F gauge. I got it on and setup without any restriction through the MBC so there was no restriction when you would blow through it. After turning it up the slightest bit and taking it for a drive, I would floor it and I could feel the car start to FLY but then it all of the sudden has hesitation and doesnt even have stock power (like it cant even go as fast when I didnt even have the MBC on).
So it seems like it has fuel cut issues when it goes the slightest bit above stock boost which is about 6 or 7 psi?
Anyone have an idea, from what I have read I should be able to go up to at least 10 psi before having these issues.
I have seen people put a resistor on the MAF to increase fuel supply? but I dont think that it is the answer since I shouldnt have fuel cut problems at the moment
Sliding242 is offline   Reply With Quote
Old 01-22-2017, 12:25 AM   #2
Jack
junkman
Jack's Avatar
what engine management are you running ?
I love you even more Jack.
Old 01-22-2017, 12:38 AM   #3
sbabbs
sbabbs's Avatar
Make sure rubber intake hose hooked to the turbo intake isn't collapsing and causing motor to stumble.
Old 01-22-2017, 12:40 AM   #4
Jack
junkman
Jack's Avatar
good point. Had that happen
Old 01-22-2017, 02:47 AM   #5
Sliding242
LH2.4, Very interesting on the hose collapsing, very smart will check tomorrow.
Thanks
Old 01-22-2017, 04:09 PM   #6
doucheNozzle
doucheNozzle's Avatar
What's your wideband and boost gauge say?
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'11 XC90 V8 - Torque Monster
Old 01-22-2017, 11:22 PM   #7
Sliding242
You guys are so smart I would not have thought about the hose collapsing. I find that my filter is too small and creates to much resistance, causing the hose to collapse. Any recommendations on a good intake setup? BTW pulls pretty good, thanks guys
Old 01-22-2017, 11:32 PM   #8
sbabbs
sbabbs's Avatar
The hose collapsing is a common problem is why we all had that problem when we turned up the boost. Get better intake filter, cone filter perhaps. Also newer stock intake hose that isn't all soft could fix the problem or replacing intake hose with solid aluminum piece and just use the rubber to connect it at each end. That way you don't have a big rubber hose that will collapse. You might also be able to buy aftermarket silycone hose that is stock style but would be stiffer then rubber.
If you can get extra aluminum boost hose the one that goes between the intercooler and the intake manifold you can cut it and use the end that has the nipple on it for the PCV hose like the rubber stock before turbo hose has.
Old 01-22-2017, 11:47 PM   #9
Sliding242
So I do have a generic cone filter, spec-v I think. The hose is definitely soft but I have this stupid sensor in the hose, pct I think, wondering if I can just get rid of it but then what would I do about blow back? I am interested in your aluminum idea. Maybe I can move the pcv hose to the intake manifold instead of right before the turbo so that I wont get oil going through the turbo and intercooler once she gets a little older, I should set up a catch can as well (off topic)
Old 01-22-2017, 11:51 PM   #10
Beep beep zip tang
That's just a heater for the PCV hose in the intake I believe. Probably can do without it, I don't have one.
Old 01-22-2017, 11:55 PM   #11
Sliding242
Yeah, I figure I can do without it as well, what did you do with the hose? relocate it to the manifold? I'm pretty sure thats how they have it on the N/A motors
Old 01-22-2017, 11:58 PM   #12
Beep beep zip tang
I'm running a B21F, different PCV but I made my own maf/amm to turbo pipe and put a hose barb on it for the PCV.
Old 01-23-2017, 12:24 AM   #13
Sliding242
Gotchya, wondering if it would be healthier for the engine to run it to the manifold now, instead of right before the turbo, like I said oil will eventually be running through the turbo and intercooler, I dont like the sounds of that
Old 01-23-2017, 12:26 AM   #14
Beep beep zip tang
I forgot to mention I have an eBay catch can inline before the inlet to cut down on the oil and moisture.
Old 01-23-2017, 01:10 AM   #15
Fumomike
Fumomike's Avatar
Anyone have a link to a replacement stock intake hose for the turbo?
Fumomike is offline   Reply With Quote
Old 01-23-2017, 02:26 AM   #16
sbabbs
sbabbs's Avatar
That is why I said use a metal tube that has a nipple on it so you can put your PVC hose there before the turbo like stock. You should leave it there. Also as stated you don't need that temp sensor if you got it. I don't think the lh2.4 240 harness even has that in it if yourn't using that.
Old 01-24-2017, 12:47 AM   #17
That is why I said use a metal tube that has a nipple on it so you can put your PVC hose there before the turbo like stock. You should leave it there. Also as stated you don't need that temp sensor if you got it. I don't think the lh2.4 240 harness even has that in it if "you're" using that.
It's not a temp sensor in the intake hose. It's a heater.
Old 01-24-2017, 02:12 AM   #18
sbabbs
sbabbs's Avatar
We'll whatever it is, 240 lh2.4 NA harness doesn'ter not have it. But he could be using a harness from a 740 turbo or 940 for all I know, ain't much..
Old 01-24-2017, 02:18 AM   #19
Sliding242
yeah the harness from a 940, 240's dont have them.
What do you guys think about bypassing it straight to the manifold?
Old 01-24-2017, 05:58 AM   #20
JPS
about your power loss, wat kind a sparkplug wire's are you running? i had in mine, (12psi lh2.4 chipped) some b230f wire's, and it did not work at all. at about 3500 4000rpm it began to lose power, almost like fuel cut. i have now some b23et plug wire's, and it fly to 5000+ rpm.
JPS is offline   Reply With Quote
Old 01-24-2017, 12:02 PM   #21
ME93940Turbo
I notice in my B230FT the hesitation when you punch it before the engine is up to operating temperature. After that, it runs normally. I only have it cranked to 8.5 PSI, which I would consider a safe level. Always love going past 3,000 RPM. Nothing more addicting than that.
ME93940Turbo is offline   Reply With Quote
Old 01-24-2017, 04:45 PM   #22
Sounds like a classic misfire! Now you have to figure out if it's a misfuel or ignition misfire. If it happens under load it's probably a mis fuel due to an airleak. Ignition misses usually show up in the morning or when wet.
Old 01-24-2017, 08:20 PM   #23
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
NO. It is attached in the inlet for a reason - unless you go VTA you need the vacuum draw in the CC that that huse provides- there is no secondary vac line on the breather Nipple like NA
