Old 03-05-2021, 04:26 PM   #51
Tfest
Hipsters ruin everything™
Tfest's Avatar
Single scariest thing I've read this year so far
Awe, being a dick isn't funny, Harlard.
Tfest is offline   Reply With Quote
Old 03-05-2021, 05:18 PM   #52
Ansel+
ABG
Ansel+'s Avatar
Originally Posted by Tfest View Post
ill make my own, tyvm.
Yeah really all you need to do is move the outer bolt holes out like an inch ish.
OG Gambler 500 registration is live if you didn't see!
Ansel+ is offline   Reply With Quote
Old 03-05-2021, 07:12 PM   #53
I'm sorry Tommy, it's all intended as good-natured ribbing between friends!
Old 03-05-2021, 07:33 PM   #54
Tfest
Tfest's Avatar
Old 03-05-2021, 07:48 PM   #55
cosbySweater
cosbySweater's Avatar
I would imagine for every inch you extend it you'd wanna lengthen the control arms the same amount. I could be totally wrong but as of right now with my tube extended 2 inches and control arms extended the same amount I can adjust the camber just as well as a factory car and it actually drives like a stock 240 down the highway
1995 Porsche 993
2013 VW Passat TDI
Old 03-05-2021, 07:49 PM   #56
Tfest
Tfest's Avatar
Constructive commentary, this is what I love. Thank you for the helpful information and I will definitely heed your advice!
Old 03-18-2021, 07:49 PM   #57
Tfest
Tfest's Avatar
Big updates coming in the next few weeks. Welder acquired along with boxed in lower control arms and a 2nd set of strut tubes because I'm sure I'll **** something up since I haven't welded in 20 years.
Old 03-22-2021, 02:46 PM   #58
D.E
tvĺförti
D.E's Avatar
Originally Posted by Ansel+ View Post
Are you planning on extending the control arms? Pretty sure you need to with that much lift as well as longer inner tie rods, Ebberoth found some from an early 2000s focus that worked.
740 inner tie rods fit and are longer.
'88 Volvo 245 - LH2.4, M47
'20 Volvo V90CC - D4 AWD
'64 Ford Taunus 17M, '78 Fiat 126P
D.E is offline   Reply With Quote
Old 03-29-2021, 12:35 PM   #59
Tfest
Tfest's Avatar
Got some work done this weekend. Tires fitted, 2" hub centric spacers and wired up the 7"rounds with the trim rings. This week I'll extend the strut tubes to lift the front.
Old 03-29-2021, 01:46 PM   #60
76RA24
looking nice
print turned out good... did it make it to thinigverse?
ABS print?
76RA24 is offline   Reply With Quote
Old 03-29-2021, 02:05 PM   #61
Tfest
Tfest's Avatar
Originally Posted by 76RA24 View Post
looking nice
ABS print?
PLA, I never thought of making my own thingiverse account... I usually just design, print, throw the file away since the designing part is so easy.
Old 03-29-2021, 02:32 PM   #62
Jack
junkman
Jack's Avatar
hows your lack of turning radius
I love you even more Jack.
Old 03-29-2021, 02:39 PM   #63
Tfest
Tfest's Avatar
scroll up a few replies and you'll see this little tidbit of information that I left for people like you to read
"This week I'll extend the strut tubes to lift the front."
There will be plenty of turning radius, I also plan on cutting the fenders if necessary.
Old 03-29-2021, 02:41 PM   #64
Tfest
Tfest's Avatar
Also, pic of the custom 2" hub centric spacers
Old 03-29-2021, 03:10 PM   #65
Jack
junkman
Jack's Avatar
are you going to extend the CAs and trailing arms ?
Old 03-29-2021, 03:34 PM   #66
C H O N K
Old 03-29-2021, 04:21 PM   #67
Tfest
Tfest's Avatar
The trailing arms seem good for now, I do have a spare set just in case but it really looks like they'll work out fine as is. The lower control arms are already boxed in and I have the metal to extend them by 2", which I am doing this week.
C H O N K
hecken big boi
Old 03-29-2021, 07:43 PM   #68
Tfest
Tfest's Avatar
Currently deciding on front strut inserts. What are the differences in dimension between the 240 and 740 front inserts?
Old 03-29-2021, 08:45 PM   #69
Duder
Comes with a free Frogurt
Duder's Avatar
Sweet build. You should buff out that 601 red paint!
Old 03-29-2021, 10:36 PM   #70
Same diameter. I think the grandpa series inserts are in the ballpark of 2” longer
Old 03-29-2021, 11:15 PM   #71
Tfest
Tfest's Avatar
That would be perfect, calling IPD tomorrow to verify. Thanks Harlard!
Old 03-29-2021, 11:53 PM   #72
Tfest
Tfest's Avatar
Thanks man. It's been fun so far. We're getting a dyc kit to plasti dip it. Havent decided on a color, maybe a desert sand, because beige...
Old 03-30-2021, 08:09 PM   #73
Tfest
Tfest's Avatar
Strut tube spacers from old strut tubes... boom.
Yes, I'm going to contact a local shop to cut these for me since this method didn't produce the best cut.
Old 03-30-2021, 08:13 PM   #74
Tfest
Tfest's Avatar
see, not good enough for my liking
Old 03-30-2021, 08:23 PM   #75
cosbySweater
22mm longer
