View Poll Results: What color for my Titan wheels?
Flat black 7 58.33%
Silver 4 33.33%
White 1 8.33%
Voters: 12. You may not vote on this poll
Old 11-08-2011, 01:53 PM   #1
Roy 940
Default project blue is better
Hi all,
Here is a short story about my DD 945 TIC ( I apologize for my bad english )
I've bought this car in 2002, just before my daughter was born. It'll replace my Alpine A310 V6.
Mods actually done :
Engine :
B230FK, with only 102300 km on it!
-0.5mm shaved 530 head with a minor porting job
-T cam
-90+ ported and polished manifold
-Ported 20T with a 11 blade billet comp. wheel + a 9 blade Iconel turbine wheel, @ 18/19 psi, + Forge adjustable 1.20 bar wastegate actuator
-full 3" JT exhaust with 200cpsi cat
-KL Racing intercooler replaced by a do88 intercooler
-3" throttle body
-Nathan intake + fuel rail
-Yoshifab phenolic spacers
-Bosch 3" 012 AMM
-Wasted spark ignition system
-Magnecor 8.5mm leads
-Bosch WR7DC+ plugs
-984 ECU
-Fred's chips/Hi Tuning chips Stage 2 ECU
-Fred's chips/Hi Tuning chips Stage 2 EZK
-Dale's gear ]
-Brand new Contitech timing kit
-3rd motor mount
-Bosch/Fiveomotorsport 52lb/hr (550 cc/min) injectors, resistor pack suppressed, 3.0 bar FPR
-Bosch 044 fuel pump + brand new in tank fuel pump
-Stock Bosch air filter in a '96+ airbox
-Catch can
Transmission :
-M90
-LUK clutch
-1041 rear axle, G80 equipped
Suspension :
-Kilen springs front -1/4 coil
-Poly bush
-Brand new front sway bar link + IPD Poly bushes
-Kaplhenke sway bar endlinks
-camber mod -0.75°
-caster mod +3mm
-IPD sways bar
-Stock lower brace now
-SAM upper strut brace
-Bilstein B6/HD all around
-all ball joint new
-960 lower reinforcement brace
Wheels :
-Infiny R1 rims, 7.5x17"
-Yokohama Advan Sport V105, 215/45 17 front
-Yokohama Advan Sport V105, 225/45 17 rear
-23mm spacer front
-28mm spacer rear
Interior :
-OMP racing seats
-OMP "velocita" steering wheel, 350 mm, leather...
-AEM wideband
-BSR boost guauge
[IMG][/IMG]
[IMG][/IMG]
project Blue is Better
http://forums.turbobricks.com/showthread.php?t=247082
Roy 940 is offline   Reply With Quote
Old 11-08-2011, 02:25 PM   #2
Roy 940
Pics :
Old 11-08-2011, 02:28 PM   #3
Roy 940
Old 11-08-2011, 04:42 PM   #4
Roy 940
Mods to be done :
-RSI Stage2 cam
-3" AMM + 500ccm/min injectors
-tubular exhaust header
But now, this car run pretty well...
I'll also find a dyno near my town, but the price scared me (180 chf per pull, 150 usd... )
Old 11-09-2011, 05:49 AM   #5
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Ouh man.. that intake looks awesome..
Fuelrail also... nathans Stuff eh?`;)
012AMM.. as said.. i beleive i got one for u, but havent been able to test it...
how much boost do you have?
Old 11-09-2011, 06:50 AM   #6
Roy 940
Yes, this nice intake is Nathan stuff!!! I like it so much !
I'll check my money, to buy your AMM, asap!
I've 0.95bar boost now, it's very good like it.
Old 11-09-2011, 09:24 PM   #7
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
who did your porting job? souper smooth.
Old 11-10-2011, 02:26 AM   #8
Roy 940
Thanks! I do it myself, after job time...
Old 11-10-2011, 04:34 PM   #9
Roy 940
I've found today 4x 850 T-5R rims in a very very good shape, for a very good price !!! Too much happy!
Old 11-10-2011, 05:53 PM   #10
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
i c MSD blaster there? also installed an 6a?
Old 11-10-2011, 06:00 PM   #11
Roy 940
No no, just Bosch "red" coil ( I don't remember the numbers ), and without MSD Blaster...
I never had any issue with this ignition setup...
Old 11-10-2011, 07:11 PM   #12
Beautiful port work.
Old 11-11-2011, 03:11 AM   #13
Roy 940
Thanks! I like to do it! When I've time, I'll mod my other head, with bigger ports
Old 11-11-2011, 03:42 AM   #14
Might have to send you some of my own hardware then
Also, pics of your Renault?
Old 11-11-2011, 03:54 AM   #15
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
You should go for 15g with straight flange..
That conical housing is crap... have the same here... bottleneck...
how did ya do the portwork? tools?
Old 11-11-2011, 05:35 AM   #16
Actually that conical housing looks more open than a stock flat flange.
Old 11-11-2011, 05:35 AM   #17
Old 11-11-2011, 05:55 AM   #18
Roy 940
Thanks for the compliments!!!
But I think the shipping price to my country will scare you...
I just have old pics of my Alpine, but I'll try to scan it and post it
Old 11-11-2011, 05:57 AM   #19
Roy 940
Right, I had open it more then a flat one... But it is possible to port it a bit more, but I was affraid to do it... I think the lifetime will be reduce too much!
Old 11-11-2011, 06:23 AM   #20
Roy 940
About tooling, just "normal" carbide tool, + a lot of sand paper and 3M Scotchbrite ( and oil )... Ah, and a lot of time...
Old 11-11-2011, 06:48 AM   #21
Roy 940
Old 11-11-2011, 06:55 AM   #22
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
the portwork rly looks great.. but the problem with conical housings.. you can see it on your pics.. the crack between turbine and wastegate... its almost factory.. but gets bigger.... even more when used under performance..
/edit
do you have also ported your manifold?` when i c your flange its heavily ported ;)
Old 11-11-2011, 07:47 AM   #23
Roy 940
Yes, you're right about cracks...but what I've seen ( and read ), it's not a problem...
It's a pic of my manifold in a previous post, you can see how it's ported...
Old 11-11-2011, 06:51 PM   #24
Roy 940
Leaky water pump fixed tonight... And I add new special anti-freeze + osmozed water, to improve cooling efficiency
Old 11-11-2011, 07:43 PM   #25
cookiemonster
cookiemonster's Avatar
holy fukin 90+ That is awesome i wish i could get my stuff ported like that!
2001 f250 powerstroke, 535hp 715tq
1983 c30 dually, 350/350 6/8 drop
91 240, m47, ipd springs, sweet cone filter!
cookiemonster is offline   Reply With Quote
