Old 01-19-2017, 11:01 PM   #26
lummert
lummert's Avatar
Originally Posted by Fumomike View Post
What about a Test Pipe+Turbo Muffler, that would give a good tone while not being too loud right?
Straight through muffler, not turbo muffler. Cheap turbo muffler has baffles and/or chambers.
Old 01-20-2017, 01:07 PM   #27
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
I am currently running no mid muffler on my car and am using a Thrush resonator ($30 @Vatozone) in the rear muffler location with zero drone at highway speeds.
-Stephen
#mclovethesenuts
-My car: White 1991 244, 330k miles. B230F LH2.4, AW70, R134a retro
-Wife's car: White 1990 244DL, T cam, 200k miles.B230F LH2.4, AW70 w/aux cooler, Virgos, tow hitch
Old 01-20-2017, 10:29 PM   #28
BDKR
Section 9
BDKR's Avatar
Originally Posted by Triebwerk View Post
Some people with sport exhausts install vibration absorber which can be found on a lot of modern cars (BMW, Audi) and they seem to work.
Example No 10
http://www.etkbmw.com/bmw/EN/search/...61/18307795604
BMW 330i No 20
http://static.bmwfans.info/images/epc/MTU2MDY5X3A=.png
Installed one a few days ago but test drive not yet done...
http://www.bilder-upload.eu/show.php...1484637764.jpg
Now that makes all the sense in the world. I suppose it works much like bar end weights on motorcycles.
For all you Dijkstra fanboys:
Old 01-21-2017, 01:03 AM   #29
Beep beep zip tang
Learn to hum at an inverse wave to cancel out done in your ears
Old 01-21-2017, 02:15 AM   #30
spock345
spock345's Avatar
Actually just clamping a small weight to the straight pipe where the resonator was moved the RPM at which the drone occurs in such a way that it doesn't drone while doing 65 down the freeway.
Old 01-21-2017, 02:57 AM   #31
Fumomike
Fumomike's Avatar
I am going to go turbo muffler flow master with test pipe, and get rid of my cat. (sorry to all the tree huggers).
Will let you all know how much louder it gets
Fumomike is offline   Reply With Quote
Old 01-21-2017, 01:03 PM   #32
spock345
spock345's Avatar
Can't get rid of my cat here in California. Although it is more pleasant to be downwind of the tail pipe when compared to the crap the pre-smog restrictions cars kick out.
Old 01-29-2017, 01:37 PM   #33
Triebwerk
Originally Posted by JW240 View Post
Nice. Curious about the results. Need to replace the exhaust cat-back on mine, will do stainless steel, maybe this helps if i run into a small drone problem. I imagine the Helmholtz (1/4 wave) resonator is more effective then.
My car is still not running (don't find the problem) but we installed one of this vibration damper to a Audi A4 1.8t 3" stainless exhaust and 400cpi sport cat who had a sirious drone problem and after a test drive today with me sitting in the front and back I can say, it works great! Drone has disapeard. I have never expect that it will perform that well. If it has the same effect at the Volvo I would be more than happy.
regards Mathias
[Austria]
Old 01-29-2017, 02:31 PM   #34
Doing your little part to make the world worse for the rest of us for no damn good reason. Check.
