Go Back   Turbobricks Forums > General > article composition > the vault
Old 06-12-2013, 05:32 PM   #601
klr142
Turbo, what?
klr142's Avatar
Yes, that's what I have for my radiator screw in one. I don't know if it works in the Saab housing though, does it??
Old 06-12-2013, 05:35 PM   #602
Ansel+
ABG
Ansel+'s Avatar
I have no idea. I could just convert it to that, but I need a new lower radiator hose in that case.
Ansel+ is offline   Reply With Quote
Old 06-13-2013, 02:52 PM   #603
Bryce
Swag Brigade
Bryce's Avatar
I'll be installing my 77/82 this week and will let you know how it goes.
FEEDBACK THREAD:
http://forums.turbobricks.com/showthread.php?t=205041
Don't laugh, she wanted the D(L).
I'm a single working mother of 3, can you help me with my racecar?
Bryce is offline   Reply With Quote
Old 06-13-2013, 10:02 PM   #604
neptune
down to 11 cars
neptune's Avatar
Different threads and diameters. The SAAB ones are much bigger around than any screw-in 240 radiator switch I've seen. Should be able to get the same temp range senders though.
Owns 11 cars and only 4 run, so keep that in mind when taking my advice.
www.neptune242.com
1981 242 Turbo |1996 850R |1980 Coupé (Project)
1971 280SEL| 1978 280Z |1937 LaSalle (Project)
neptune is offline   Reply With Quote
Old 06-19-2013, 10:29 AM   #605
122power
dude
122power's Avatar
Does anyone have part numbers or temp ranges for those? The saab fittings that is.
Old 06-20-2013, 12:27 AM   #606
swedishiron.com
I sell Volvo parts!
The temp ranges that I have found in Saabs are:
92/87
82/77
77/72 (?)
Here's my feedback thread:
http://forums.turbobricks.com/showthread.php?t=25568
I ship small packages/purchases on Fridays, and larger ticket items via FedEx in the middle of the week.
swedishiron.com is offline   Reply With Quote
Old 06-20-2013, 11:49 AM   #607
klr142
Turbo, what?
klr142's Avatar
92/87
82/77
77/72 (?)
Those are ones you've actually seen stamped on the senders when they're still in their natural habitat? Have you seen them for sale at the different temperatures, before?
Old 06-20-2013, 01:20 PM   #608
PDX240
Back from the DEAD
PDX240's Avatar
Pull a lower temp Saab one out of the radiator, halfway down on the driver's side. That's where I find the 87/92 ones usually.
My Blue 1986 245DL
Pdx240 feedback http://forums.turbobricks.com/showth...ghlight=Pdx240
PDX240 is offline   Reply With Quote
Old 06-24-2013, 12:10 AM   #609
swedishiron.com
I sell Volvo parts!
PDX240 is correct - the senders that are installed in the T-fittings are for the AC fan (?). This one is usually 100/115 (?) or some higher range of temperature.
The sender in the radiator is for the engine fan (?) and is almost always a lower temp range sender.
Old 06-24-2013, 06:28 PM   #610
klr142
Turbo, what?
klr142's Avatar
I'm assuming those ones that are in the radiator fit into the T pipe?
Old 06-24-2013, 09:56 PM   #611
Ansel+
ABG
Ansel+'s Avatar
I ordered a 77/82 for the saab T and installed it last weekend. Much better, fan comes on at just below the middle of the gauge, rather than just above it like before. I'll post a part number when I'm off work.
Old 06-24-2013, 10:05 PM   #612
PDX240
Back from the DEAD
PDX240's Avatar
Yes, fits the Saab tee.
Old 06-27-2013, 03:15 PM   #613
122power
dude
122power's Avatar
So the volvo and saab threads are different?
Old 07-01-2013, 05:38 PM   #614
robiewing
VolvoRacr
robiewing's Avatar
Seems like theres a lot of confusion regarding how to hook up an e-fan using a newer model LH2.4 ECU. Because I know I was confused until I stumbled upon an extremely easy solution to get it working correctly.
My Volvo, 1990 780, B230. Newer model ECU 954.
Using the pin out info listed here...
http://www.nord-com.net/stoni/lh_ezk.html
Low speed connected to pin 10.
Using a spare Bosch connector, (same one that plugs into a fuel injector). Pulled the connector from the Bosch connector and snapped it into the pin 10 connection on the ECU wiring harness and ran it to the low speed side of the fan relay. Havent tried pin 11 yet for the high speed side of the relay but pretty sure it will work too. Also an empty slot in the 1990 ECU wiring assembly harness.
Fan turns on low after about 30 seconds after the engine starts, turns off with the ignition.
Tried terminal 7 and 22 but both are grounded until turning on the ignition.
Wire to low speed side.
Fan hack.
And tha 780 (aka.Toni)
Originally Posted by TrickMick View Post
it *usually* ends up being some form of BASIC fail....
GOOD CATCH....I *hope* you logged the experience so
you can go back,and refer to it if faced w/a similar set
of "symptoms"!!
robiewing is offline   Reply With Quote
Old 07-03-2013, 08:13 AM   #615
boosted740
boosted740's Avatar
Default Thermo Switch P/N's
For those people who are looking for part numbers for the thermo switch to fit the Saab T
Napa Part #'s
FS150 92°C/87°C
FS193 82°C/68°C
FS194 87°C/77°C
All of these are 2 prong switches with M22 thread
boosted740 is offline   Reply With Quote
Old 07-04-2013, 01:23 AM   #616
Bryce
Swag Brigade
Bryce's Avatar
Napa Part #'s
FS150 92°C/87°C
FS193 82°C/68°C
FS194 87°C/77°C
Excellent info! I sourced mine online but local is always nice!
Old 07-07-2013, 06:19 PM   #617
Ansel+
ABG
Ansel+'s Avatar
Thanks for the 2.4 info!
Old 07-16-2013, 05:12 PM   #618
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
Watch out for fans catching on fire.
Hello My Glorious!
Old 07-16-2013, 10:18 PM   #619
robiewing
VolvoRacr
robiewing's Avatar
Don't fan the flames, use water.
Old 11-23-2013, 06:03 PM   #620
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Laaaaate Edit - Clutter. All was/is well now.
Old 11-25-2013, 05:31 AM   #621
Jack
junkman
Jack's Avatar
Dude pm me and I'll help you out
This thread is about 98.234567% too much
The correct info is easy
I love you even more Jack.
Old 12-02-2013, 10:07 PM   #622
Bryce
Swag Brigade
Bryce's Avatar
I can help you out too. I've wired up about 4 of these now and will be doing my 5th pretty soon.
Old 12-04-2013, 01:38 PM   #623
J_Jones
J_Jones's Avatar
Does anyone have a part number for the 77/82 switch from Autozone/Advance/Oreillys/Napa? I have found them through online stores, but if I can get the switch from one of the local parts stores I get the warranty through them and it's much easier to walk into the store and switch it out if it does go bad.
I see the Napa part number for the 77/87 posted above, but that is a little higher of an opening temp than I would like.
Thank you
Old 12-04-2013, 01:40 PM   #624
boosted740
boosted740's Avatar
Napa Part #'s
FS150 92°C/87°C
FS193 82°C/68°C
FS194 87°C/77°C
These were from NAPA and I have not been able to source a 82/77 from them. I will look again to see what they have listed.
Old 12-04-2013, 02:00 PM   #625
J_Jones
J_Jones's Avatar
Yeah, I got on Napa's sight as well and saw those same ones. Went to their catalog and couldn't find an 82/77 in there either. I think that I found one via Advance: Beck Arnley 201-1545. I am going to run by there today and see if they have one to check out. Autozone and Oreilly have a ton of different listings for the 87/92 but haven't been able to find the 77/82 yet. If/when I or someone else find one at a local parts stores, we should update the OP with all of the numbers.
