View Poll Results: What color for my Titan wheels?
Flat black 7 58.33%
Silver 4 33.33%
White 1 8.33%
Voters: 12. You may not vote on this poll
Old 06-06-2012, 11:40 AM   #251
HansW
HansW's Avatar
Yes, you need magnecor red! never looked back since. I think slowly but surely you have all the goodies I had on my car when I saw you last, -- how's about a 531 head?
Anyway, enjoy it when it's there. No plan for a continental trip this year, - had to spend money on the house.
940 classic Cd 1997
B230FT / M90L
530 head planed, KG 2T cam
Head gasket: Elring standard (Mls 0.35 was too tight, -- piston- head contact),
1041 axle 3.74, M90
15G at 0,85 bar
3" turbo back JT-superflow
3" Amm. + 42lbs injectors
STONI chips in 984 ecu and 167 EZK
Bosch WR5 DC+ (+15)
HansW is offline   Reply With Quote
Old 06-06-2012, 05:56 PM   #252
Roy 940
I have since your last visit the Magnecor KV85 leads in the car, and they're perfect! But I've to change it to be accorded to my new ignition setup... No news now for a 531 head, but I don't think I need it so much... Don't forget it, my actual 530 is ported and run very well if you remember...
I'll decrease the spending money in the car also, I'll plan some holidays with my girlfriend and my children's...
project Blue is Better
http://forums.turbobricks.com/showthread.php?t=247082
Roy 940 is offline   Reply With Quote
Old 06-10-2012, 01:06 PM   #253
HansW
HansW's Avatar
Ahh good idea, I decreased it close to 00,-- only service, test etc. -- I even walked away from a complete 740 GLT estate with B234 engine for 200 Euro, -- I can have it anytime, but other things to do in live,
Cheers, Hans
Old 06-10-2012, 01:30 PM   #254
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
So your car is running well, and your happy with its perfromance? Any big mods to look forward to in the future?
962j 815/692@27psi
THIS IS FORSALE V
Old 06-11-2012, 01:49 AM   #255
Roy 940
Yes, I'm happy how the car's run! Next mod to come (I hope this week) is the wasted spark ignition...I hope it'll increase a bit its performance...
Anyway, I don't know what to modify now... I can maybe afford a T4 turbo soon, but I'm not sure if it's a good idea to install it or not...
Old 06-14-2012, 07:17 AM   #256
Roy 940
Wasted spark is in the car!!!! I'll try it a few km and post pics soon!
Old 06-14-2012, 12:48 PM   #257
Roy 940
As said, here are the pics :
The stock dizzy plug :
The EZK mod :
Installed in the engine bay :
Old 06-14-2012, 03:59 PM   #258
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
nice but you do know theres a factoryplug for the distributor? ;)
btw... why is your board so big?
Old 06-15-2012, 01:18 AM   #259
Roy 940
I don't know it exist a factory dizzy plug...
Witch board you think is big?
Old 06-15-2012, 03:13 AM   #260
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
the wasted sparkboard... mine is half as big?? Rev.2? seem like...
wait ill search the partN°....
...searching...
...found...
2,67€
http://www.skandix.de/de/fahrzeug-te...welle/1001174/
/edit
say.. do you still use the 2mass flywheel?
Old 06-15-2012, 04:42 AM   #261
Roy 940
About the wasted spark board, I buy this one because I've found this one... It's running, so I don't pay attention at the size
The dizzy plug is a rubber part? How it stay in place? With my solution, no risk to loose it...
My car have the stock flywheel, so I think it's the dual mass unit...and I don't think to change it before a while, because my clutch is ok and I don't have so much money to spend now...
Old 06-15-2012, 08:19 AM   #262
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
no... some guy here in germany has a good sachs perf clutch for a singlemass flywheel... get the clutch from him and get a single mass from me... the dual one will kickoff one day with your motor.. believe me ;)
Old 06-15-2012, 11:37 AM   #263
Roy 940
How much?
Old 06-15-2012, 06:11 PM   #264
Roy 940
I clearly feel the difference now, the idle is smooth as silk, and my engine pulls really better everywhere in all the power band!
The wasted spark is definitely a very nice gain
Old 06-17-2012, 08:45 AM   #265
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
How much?
Ask user Bullweih ;)
if you buy it.. come back to me for single mass...
Old 06-17-2012, 05:28 PM   #266
Roy 940
I'll let you know
Old 06-19-2012, 02:49 PM   #267
HansW
HansW's Avatar
Hi Alex
I go with maddog -- I am pretty much at the limit of my dual mass flywheel and clutch, -- Clutch was new only 15 tsd. km. I have the sachs performance pressure plate (new) a disc organic from the diesel and an almost new dogdish flywheel sitting in the attic, waiting to go in, as soon as the old one gives up. I like your design of the plate for the back of the engine. At the time of my 740, I just used an old dizzy and replaced the shaft with a big bolt.
Happy Volvo Times!
Hans
Old 06-20-2012, 07:08 AM   #268
Roy 940
Hi Hans,
As soon as the stock one dies, I'll install a "real" clutch combo for sure...
Thanks for your comment about my "dizzy block off plate", the main idea behind that was to remove any kind of ugly parts at the end of the head...
Old 06-20-2012, 09:14 AM   #269
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Hi Hans,
To put another one in its place? ;)
This thing is not only made of Rubber... its a metalplate coated with rubber... also the B6304 has this (slightly larger foshore) but it holds perfect without a "hold in place" bracket ;)
Old 06-20-2012, 11:53 AM   #270
Roy 940
Mine is not ugly...
I don't like the "just plug" cap, I'm always affrais it pop out...
Old 06-20-2012, 12:11 PM   #271
The Full Banana
not yet good enough
The Full Banana's Avatar
there's a reason that ipd sells a plate to hold those plugs in
if yours doesn't leak or interfere, then run it!
-Tom 1980 242 T5
Old 06-21-2012, 01:11 AM   #272
Roy 940
Yeah, I was inspired by the IPD plate...
Mine don't interfere and don't leak, nothing to worriying about
Old 06-21-2012, 08:25 AM   #273
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Im just saying it holds on every 960 sold from factory ;)
Old 06-21-2012, 06:30 PM   #274
Roy 940
OK, but my car is a 940...so it cannot work on mine...
Old 06-22-2012, 07:08 AM   #275
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
uh.. therefore i posted the link to the one which fits the 8v heads ;) its also used on Pentaheads... ;)
