Old 01-03-2017, 04:26 PM   #1
stonie
stonie's Avatar
Default which turbo for b280ft
after dynoing my car with my kinugawa 20T the result was 310hp and 620nm at the wheel at 2300 rpm... after 4500 rpm the engine needs more air than this turbo can bring.
which turbo should i take for my engine, my goal is 400-500hp but not at 6000rpm, more or less between 3500 and 4500 rpm so it should start boosting something about 3000rpm.
i thought about a gtx3076r , or is this to big?
should be with internal WG and T3 flange
stonie is offline   Reply With Quote
Old 01-03-2017, 04:27 PM   #2
3076 should be perfect
Old 01-03-2017, 05:18 PM   #3
stonie
stonie's Avatar
a/r ?
Old 01-03-2017, 08:01 PM   #4
doucheNozzle
doucheNozzle's Avatar
What's your budget?
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'11 XC90 V8 - Torque Monster
Old 01-03-2017, 08:05 PM   #5
Originally Posted by stonie View Post
a/r ?
Assuming that your TD05 is a 10cm unit, I would imagine something like this would be good:
http://www.atpturbo.com/mm5/merchant...Category_Code=
Old 01-03-2017, 11:47 PM   #6
Duder
Comes with a free Frogurt
Duder's Avatar
If you need the flow capacity from the GTX 76mm compressor wheel, then the 3576 is really the better choice. The larger turbine is more efficient at the lower speeds that the 76mm wheel runs at, compared to the 71mm or 67mm compressors that are also available with the GT30 turbine wheel.
In other words I'm suggesting either the GTX3071R or GTX3576R, and not bothering with the awkward middle child.
Old 01-03-2017, 11:57 PM   #7
Duder
Duder's Avatar
That 0.78 A/R turbine housing is another one that has been adapted to fit the turbine wheel, but not designed for it.
For the GTX30/35 family I'd stick with the 0.63, 0.82, and 1.06 A/R housings in single scroll variety, and 0.61, 0.83, 1.01 A/R for twin scroll. All of those were designed from the start to work with these turbos.
Old 01-04-2017, 12:10 AM   #8
Every damn time. How do I even manage that?
Old 01-04-2017, 07:57 AM   #9
stonie
stonie's Avatar
Originally Posted by doucheNozzle View Post
What's your budget?
if its possible not more than ~1000
i dont know if the gtx3071r with a/r .64 is big enough for this goal!?
and the gtx3576 is f*** huge
Old 01-04-2017, 09:40 AM   #10
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
pics of the engine?
Old 01-04-2017, 10:19 AM   #11
stonie
stonie's Avatar
Old 01-04-2017, 01:10 PM   #12
dieselboy
Whooty patrol
dieselboy's Avatar
Efr7064
'82 242t hy35 @28psi, ebay header, big intercooler, microsquirt ecm, rsi stg2 cam, arp headstuds, tremec tko600, 3" exhaust, 13" brembos, coilovers, saabspoiler, 245/40r17s, lots of yoshifab stuff.
'12 flex ecoboost "kats" car
'93 940 turbo lifted #trophyvo
'08 f350 4x4 v10 cclb
'97 f-350 4x4 offroad toy
'94 4700 dt466 International toterhome build
dieselboy is offline   Reply With Quote
Old 01-04-2017, 01:12 PM   #13
I thought you meant PRV. Slight disappoint
Old 01-04-2017, 01:18 PM   #14
Beep beep zip tang
The title would imply a 6cyl, might want to revamp the turbo recommendations.
Old 01-04-2017, 02:38 PM   #15
stonie
stonie's Avatar
damn your right, didnt thought about that. i made a 2.8 T liter out of a b230ft so i called it b280ft
Old 01-04-2017, 02:45 PM   #16
Beep beep zip tang
Well you might need that big turbo then, I thought the title was a typo. Much strokage I assume?
Old 01-04-2017, 02:49 PM   #17
stonie
stonie's Avatar
first oversize bore, the rest with crankshaft, crank and pistons , yes!
are you sure i need that big, i had now a td04 20T and i got 310 whp and 620nm ??
Old 01-04-2017, 04:15 PM   #18
DMFWallace
Ignoramus Bigotus
Holy crap that's a lot of torque. Custom cam? And what kind of exhaust manifold are you using?
'90 244 - Too many memories to crush
'92 944T - Need any 940 parts?
'96 854 GLT - Not mine any more but still in the family
'92 245 - For Sale?
'97 854R - Waiting to get fixed
'06 XC90 V8 - Family Hauler - Wifemobile
'04 XC70 - Impulse buy of the year
Feedback:http://forums.turbobricks.com/showth...ght=dmfwallace
DMFWallace is offline   Reply With Quote
Old 01-04-2017, 04:19 PM   #19
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
the EFR would be a good choice, on the GT side of things, I would imagine you'd want a .83 minimum hot side size, you need to be able to get the air out in addition to getting it in.
Megasquirt Tuning!
Old 01-04-2017, 04:27 PM   #20
stonie
stonie's Avatar
im driving the kg2t cam. ported oem exhaust manifold
Cam data: Intake lift 10.5mm (0.413")
Exhaust lift 11.9mm (0.469")
Nock angle 114 degrees
Duration 300 degrees
Old 01-04-2017, 04:33 PM   #21
Color me impressed. Intake manifold is original as well?
Old 01-04-2017, 04:50 PM   #22
stonie
stonie's Avatar
yes!
Old 01-05-2017, 02:33 AM   #23
nordmaschine
forced instruction
nordmaschine's Avatar
I came here for some JohnLane style PRV6 porn. Not dissapointed, though.
Jetronic is romantic.
- '86 780 TDIc - Bertone #301
Whiteblocks
Old 01-05-2017, 03:24 AM   #24
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Haha !! i also was expecting a nice V6 Turbo But daaaaamn. 2.8 Litres R4 how does this banger go?
Old 01-05-2017, 04:03 AM   #25
stonie
stonie's Avatar
i think with you can imagine how it goes when you know a gasoline engine from the 90's makes 310hp and 620nm at 2300 rpm @ the wheels!
no , really , is crazy to drive. i need to get the power between 3000 and 45000 rpm, now the car is shaking like titanic crashing ice when i give some throttle at low rpm.
