Old 01-19-2021, 04:58 PM   #1
Gubbe
Default Ignition Chipping
Hello, I am new to the Volvo community and I have just bought a 84 240. My plan is to get a hold of a b230fk. I have just purschased a LH 2.4 wire harness and i also got a few ignition ecus with the buy, now for my question. I have looked at different discussions around this topic but i still feel like i didnt get an answer. Two of the four ignition ECUs i have, does have this "daughter" board that i have heard people talk about that you need when chipping. The 1st ecu name : Bosch 0 227 400 146. Second one: Bosch 0 227 400 149. These two does have the daughterboard in them, can i buy any "turbo" chip and stick them in there and call it a day or does not these ECUs work with the LH 2.4 or b230fk? Thanks. I will post up some pictures.
Gubbe is offline   Reply With Quote
Old 01-19-2021, 05:03 PM   #2
Gubbe
0 227 400 149 pics: https://ibb.co/PzGwgWv
https://ibb.co/gR7XxHd
0 227 400 146 pics: https://ibb.co/BVKp4PP
https://ibb.co/0fy9NJd
Old 01-19-2021, 06:00 PM   #3
sbabbs
sbabbs's Avatar
Yes you can put turbo chip in any chippable EZK box and it will work.
Old 01-19-2021, 06:25 PM   #4
Gubbe
Thank you. You wouldnt know the difference between the two ecus i have? Should i use one over the other? Or is it the same? Kind regards
Old 01-19-2021, 08:24 PM   #5
bobxyz
bobxyz's Avatar
146 is for B230F No EGR
149 is for B230FT EGR
You can chip either one. Keep the original chip, if it matches your motor, as a backup.
