Old 04-14-2021, 12:29 PM   #1
sheepbleat
Default Aftermarket Horns: Living my cycling team car dream
Hey TB,
Iíve got a 240 project car thatís beginning to take shape, and Iím getting into the fun parts. Part of that is installing this obnoxious horn thatís typically used in cycling team cars.
I havenít found any english instructions for this. Anyone else installed a ďfunĒ horn in their 240? Any tips/tricks/traps I should be aware of?
Looking forward to my next inspection,
Greg
Greg
My Feedback Thread
sheepbleat is offline   Reply With Quote
Old 04-14-2021, 01:29 PM   #2
Those are a cool sounding horn if I am thinking of the ones I hear from the tour de france races. When you install the horn you'll want to use a 40 amp relay wired in. You can trigger the relay with the existing horn wiring so then you just have to wire from the junction block on the inner fender to the relay 30 and wire from the terminal 87 to the horns. Then provide ground for the horns. The trigger terminals are 85 and 86 on the relay. It's a standard 40 amp four pin relay.
Old 04-14-2021, 02:42 PM   #3
sheepbleat
Thatís the one! I suspect it will be appreciated by my close friends and frowned upon by NY inspectors.
This is a huge help. Thank you. Will grab a 40 amp relay and have at it once the horn shows up. Looks like a pretty easy install and Iíll have plenty of room under the hood for it. Will try and grab a pic and a clip once itís done.
Old 04-14-2021, 03:13 PM   #4
dbarton
Dejected by Volvo
dbarton's Avatar
i have a 240 horn diagram for relay use in my Cadillac Horn Page: https://www.240turbo.com/horns.html
Dave
'84 242ti, fourth owner, mine since 2003. Always garaged since brand new. Old-school rounds because I like. B21FT, SDS EFI/IGN, TD04HL-15G, T5Z trans with modded 0.73 OD, 3.91 diff, unmodified G80.
Old 04-14-2021, 09:48 PM   #5
brian smith
I used one in a 145, and installed an extra rocker switch in the interior used for switching back and forth between the stock horn and the fun horn. State Inspection-friendly setup.
the howdeedoo:
Old 04-14-2021, 09:48 PM   #6
bobxyz
bobxyz's Avatar
If you go to the horn link you posted, click on the word "Attachments" (light gray), and look at the bottom 2014-09-12_FIAMM_tourhorn_instructions.pdf file, it has brief instructions.
The original Volvo horn button grounds one side of the horn pins directly, so you want the Trio MT3i B wiring for "grounded horn button".
Old 04-14-2021, 09:53 PM   #7
sheepbleat
This is genius.
Old 04-14-2021, 09:54 PM   #8
sheepbleat
Got it! Yes. Between this diagram and the one that Dave Barton shared I think Iím dialed.
Off to find a rocker switch, some relays, connectors, and a wire loom.
Old 04-15-2021, 07:05 AM   #9
dbarton
Dejected by Volvo
dbarton's Avatar
Will they actually fail a car because the horn sounds different?
Old 04-15-2021, 09:20 AM   #10
ortho stice
I assume there is a decibel limit.
ortho stice is offline   Reply With Quote
Old 04-15-2021, 10:18 AM   #11
sheepbleat
They really shouldnít. I made that comment mostly in jest.
Language around horns in the inspection manual is brief and just calls out that it has to function. Iím sure an inspector whoís having a bad day could try and sell you a ďproperĒ horn but it seems unlikely.
Old 04-15-2021, 03:38 PM   #12
Beep beep zip tang
Why not a Dixie horn ala Dukes of Hazzard?
https://www.autobarn.net/dukes-of-ha...te=google_base
Old 04-15-2021, 04:03 PM   #13
Khrrck
Professional Amateur
It's been done.
'87 240 budget wagon.
Old 04-15-2021, 05:39 PM   #14
A dixie horn will make you jump your car and ruin everything.
Old 04-15-2021, 09:15 PM   #15
brian smith
Not really, but if you've effed with your horn, and other things, then maybe because you are a "risk," they'll spend extra attention on your emissions profile, the existence and operation of factory equipment, and anything else that could make you go away and find someone else to attest to your vehicle's safety condition.
You want to accommodate this, not fight it, unless you have the kind of money not to be installing a "cycling team car" horn on a decrepit Volvo...
Old 04-16-2021, 07:54 AM   #16
dbarton
Dejected by Volvo
dbarton's Avatar
There probably is. Train horns come to mind. Extremely loud, but similar horns are on most semi trucks, which no one seems to mind.
